coil sprung front dana 60 - Defender Source
Old August 31st, 2015, 07:19 AM
M.A.R.S.
Drew
R.R. classic
For sale chevy dana 60 narrowed and brackets welded on as to fit under defender, discovery, or range rover classic using radius arms. axle is not complete and missing parts to reassemble, but the hard work is done. here are some of the items it will need. Do to the fact that the outer knuckle is so large you have to run coil over shocks or have a two inch spacer under the spring to clear knuckle at full turn. would also need gears, outer knuckles and spindles, brakes, outer shaft and u joints. The short side axle is a standard axle. the long side axle is a factory axle that has been narrowed. the hubs were brand new but have gotten wet at some point and started to rust. has been sitting in my garage for about 8 years. I may be forgetting something as its been a long time since I started this project and don't have a need for it any longer. best contact is marsemailinbox@gmail.com $900 or obo
ID:	128374   Click image for larger version
ID:	128376   Click image for larger version
ID:	128378   Click image for larger version
ID:	128380   Click image for larger version
Old August 31st, 2015, 07:36 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Nice! I wish I had a coiler to put it under.
Old August 31st, 2015, 12:57 PM
M.A.R.S.
Drew
R.R. classic
Thanks, i can sell you a truck to put this under if you need a project.
Old August 31st, 2015, 02:36 PM
slorocco
Dan Prasada-Rao
I bet you could! I have too many projects already. Getting ready to do more of a stock build on a series 109, plus my old 109 with the Cummins needs some love as well. I keep breaking the front Salisbury in that one so it's getting a Dana 60 front which I've already got sitting in the back yard.
Old September 1st, 2015, 10:01 PM
Ruthiford
Jason
1986 D110
What is the overall width when assembled?
Be sure to tell them Large Marge sent you....
coil
Series IIA coil sprung chassis bcourtney Series Technical Discussions 11 July 21st, 2013 07:11 PM
Trailer Project (Coil sprung series tub) 1962siia88 Smaller Projects 9 July 1st, 2011 07:17 PM
TLR selling out his coil sprung parts stock Uncle Douglas The Flea Market 8 November 6th, 2009 10:45 PM
FS new galv. 109 coil sprung frame ECR For Sale - Parts 7 July 7th, 2009 10:59 AM
Coil sprung series vehicle w/ diesel engine geneseemtn Misc. Chit-Chat 19 February 26th, 2006 09:52 PM
