Ceramic Coated Exhaust Manifolds - Defender Source
Old April 16th, 2009, 02:29 PM
kingstonman's Avatar
kingstonman
Joshua Bohm
2001 DII & 97 P38 Vitesse
Ceramic Coated Exhause Manifolds
will fit Defenders, Disco 1's and RRC's
Benefits include:
  • Reduces manifold temperature by approximately 300 degrees, will withstand up to 1800 degrees.
  • Corrosion protection
Pricing Pick Up / Shipped
Manifolds $350 / $367
Manifolds with Basic Kit $433.60 / $450.60
Manifolds with Lock Kit $457.60 / $474.60
Basic Kit includes : Exhaust Studs
Stud Nuts
Manifold Gasket
Flange Gasket
Bolts
Washers
Lock Washers
Lock Kit includes: everything in the basic kit but adds Lock Plate
Call Josh at Columbia Rovers 503.227.3766
or email parts@columbiarovers.com
www.columbiarovers.com
Name:	Ceramic manifolds.JPG
ID:	18831   Click image for larger version
Name:	ceramic manifolds1.JPG
Old April 16th, 2009, 02:47 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Any reason this wouldn't fit a D2? Atlantic British has the same part number for D1/D90 & D2s for the genuine ones
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old April 16th, 2009, 03:07 PM
kingstonman
Joshua Bohm
Yeah my bad, i just left it out. they will fit dII's as well.
Old April 17th, 2009, 11:36 PM
cdb
Clark Bowen
Pardon my ignorance Josh, but how does the ceramic coating reduce the temperature of the exhaust manifold by 300 degrees?
Do you mean in the engine compartment?
Seems like a huge drop. I thought V8 temperatures were in the 400-500 degree range at the exhaust manifold.
If they do, in fact, drop the temperature that much how would they work on a turbo diesel (300 TDi)?
Clark
Old April 18th, 2009, 08:56 AM
It reduces the OUTSIDE temperature of the manifold. Obviously the gas inside is still the same.
Old April 18th, 2009, 10:06 AM
cdb
Clark Bowen
"It reduces the OUTSIDE temperature of the manifold. Obviously the gas inside is still the same."
Thanks. I wasn't sure if there was a increase in heat transmission with the coating or a decrease.
Because there is a decrease in the heat transmission are the exhaust gases hotter and if so it would seem to be a bad idea on a TDi?.
Clark
Old May 26th, 2009, 12:25 PM
kingstonman
Joshua Bohm
We just got a couple more sets of manifolds back from being coated. Let me know if your interested.
Josh
503.227.3766
Old May 26th, 2009, 12:47 PM
Id like to know more about the benefits of coated manifolds, obviously cooler underhood temps. It seems to me that keeping all the heat inside of the manifold would make the heads hotter?
Old May 26th, 2009, 01:28 PM
kingstonman
Joshua Bohm
The coating does reduce the temp in the engine bay. The coating works as a thermal barrier keeping the heat within the manifolds. by keeping heat within the manifold, you're going to accelerate the exhaust gas velocity which reduces back pressure and reduces fuel contamination due to reversion. by reducing the surface temp of the manifolds the surrounding components will see less heat as well.
exhaust
Ceramic Coated Manifolds, 3.9, 4.0, 4.2 Method PHX For Sale - Parts 36 September 18th, 2008 03:11 PM
F/S Ceramic Coated Exhaust Manifolds Paul Grant For Sale - Parts 0 November 9th, 2007 05:33 PM
Coated manifolds kellymoe Misc. Chit-Chat 6 November 9th, 2004 09:05 PM
installing exhaust manifolds mattdh Defender Technical Discussions 28 August 19th, 2004 03:57 PM
WTB used exhaust manifolds kellymoe Wanted 1 February 13th, 2004 01:51 PM
