Cams, lifters, timing chains - Defender Source
Old March 8th, 2006, 07:28 PM
vesparover's Avatar
vesparover
brian bertolini
Exclamation Cams, lifters, timing chains
Hey everyone, I have a few things for sale:
crower cam 50229 paid $175 from d&d, installed and removed. $100
isky custom ground cam 268 deg/ .485 lift. 109 lobe 224 deg duration at .050. very hot cam 12,000 miles $100
Crower lifters from d&d installed & removed $50
Timing set from d&d silent roller chain $20
Brian Bertolini
deweyberts@yahoo.com
Old March 9th, 2006, 12:00 AM
Shane@EVS
Roverhybrids
Can you tell me more about the cams?
Like will they work in a 3.9 without computer problems?
Old March 9th, 2006, 07:27 AM
vesparover's Avatar
vesparover
brian bertolini
The crower will work fine with stock injection, the isky cam would need a carb or diff. fuel injection
Old March 9th, 2006, 08:15 AM
Brian, I'm intreasted in the isky cam. I like power, is it set up for more HP or tork? And if you don't mind what injectors were you planning on running?
Old March 9th, 2006, 08:26 AM
vesparover's Avatar
vesparover
brian bertolini
Hey mike, It's set up for torque. I would say you would need to run a carb or megasquirt. I was going to do away with the fuel injection, and run an edelbrock intake and 4-barrel carb.
Brian Bertolini
Old March 9th, 2006, 11:42 AM
Shane@EVS
Roverhybrids
I'll take the crower stuff and the chain.....uh how much use on the chain?
I'm sending you a PM and email.
Old March 9th, 2006, 05:29 PM
vesparover's Avatar
vesparover
brian bertolini
There's about 50 miles on the chain- so it's new.
Old March 9th, 2006, 08:40 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I'll take the Isky if it is not gone. I sent you an email.
Kevin
Old March 9th, 2006, 09:53 PM
vesparover's Avatar
vesparover
brian bertolini
the isky cam uses a cam retainer plate
Hey everyone interested in the isky cam- It's for a 4.6 or any other rover that uses a cam retainer.
Brian Bertolini
Old March 10th, 2006, 08:33 AM
But it has the gear on the end for the distributor correct?
Old March 10th, 2006, 05:40 PM
vesparover's Avatar
vesparover
brian bertolini
Correct Mike- It was made with the dizzy drive, but needs a cam retainer plate.
Old March 10th, 2006, 11:20 PM
vesparover's Avatar
vesparover
brian bertolini
Alright, I only have the Isky Cam left. Must be someone out there that has done the 4.6 swap and wants this hot setup.
Thanks for looking
Brian Bertolini
Brand New RUD Grip 4x4 Tire Chains Steve Friedman For Sale - Parts 0 February 23rd, 2006 04:41 PM
Kick A$$ Snow Chains Mike Hippert For Sale - Parts 5 November 1st, 2005 08:05 AM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
snow chains and 4x4 Best way. paulb Defender Technical Discussions 14 February 28th, 2005 01:51 PM
Why didn't anybody warn me timing chains are so annoying? Hans Misc. Chit-Chat 4 January 16th, 2005 11:40 PM
