Brembo Brake Rotors-front - Defender Source
Old December 30th, 2011, 03:38 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
New Front Rotors for D-90,Disco 1, RRC. Brembo P/N FTC902. $110 shipped
ID:	45430   Click image for larger version
Old January 1st, 2012, 07:39 AM
rovertrader's Avatar
rovertrader
Dale
These look correct for a 90, but not stock D-I or RRC unless the 90 calipers are fitted. Can you confirm? I could use these on a project- thanks.
Old January 1st, 2012, 07:49 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Yes, you would need wider calipers to fit.
Semper Fi!
Old January 1st, 2012, 09:22 AM
the rover shop
shayne young
yep...ventilated v non ventilated... RRC and D1 had solid non-ventilated rotors...and if you change range rover calipers to defender calipers you have problems with the brakes...2 lines in on RRC 1 on defender...different braking system due to power abs vs non abs on defender...Ask me how i know...LOL...
Old January 1st, 2012, 11:49 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
From what I've read, the caliper has to be taken apart and spacers put in for the rotors to fit.
Old January 1st, 2012, 11:53 PM
the rover shop
shayne young
Not quite..range rover classics have a completely different braking system...they have 2 brake lines going into each front calipers...I believe one is power brake and the second is manual braking...
Old January 1st, 2012, 11:56 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
Ok....so...the product description is wrong? But any which way....its a project...not just plug and play...
Old January 2nd, 2012, 02:06 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
RRC's do have a vented front rotor.
Unknown Author
716-898-8153
Old January 2nd, 2012, 09:02 AM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
Ok. Then brembo is dumb for having the part # for all three rovers imo.
Old January 12th, 2012, 06:40 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
/bump
Old January 13th, 2012, 08:01 AM
RRC, have the twin/dual hoses and vented front rotors. I use the same rotors on both of my trucks. I have been trying to find more information on running the Defender calipers on my Classic, there isnt much out there.
Old January 13th, 2012, 09:57 AM
the rover shop
shayne young
Early Range Rover classics had solid rotors...I think they went to the ventilated rotors on ABS models...probably in early 90's... the reason for the twin line calipers is because they needed a manual system in case of ABS pump failure... I converted my whole system over to the NON abs vacuum brake booster system and eliminated the whole electric brake pump and sometimes problematic hydraulic booster assy... went to defender front calipers and she work great...hey, if defenders didn't need abs then why should a much heavier Range Rover...LOL...So yes, I believe these will fit the later RRC...
Old January 25th, 2012, 10:05 AM
hye1978
Paul
1962 Series 2a
Are these still for sale?
Old January 25th, 2012, 12:11 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
Yes I still have them
Old February 14th, 2012, 06:59 AM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
/bump
Old February 14th, 2012, 07:01 AM
90$ shipped?
brake
1984 110 front brake pad part #? tommyd Defender Technical Discussions 0 July 21st, 2009 04:37 PM
13mm Front Brake Calip. Unit Bolt chrisvonc Wanted 2 July 31st, 2008 08:50 AM
Brembo Rotors on eBay Glenn_Guinto Defender Technical Discussions 15 March 29th, 2005 05:11 PM
Front Brake Calipers 1of40 Defender Technical Discussions 7 December 30th, 2003 12:46 PM
