Brass Radiator Plugs - Defender Source
Old February 14th, 2009, 08:54 PM
Abrooks's Avatar
Abrooks
Tony Brooks
with o-ring, $12/ea.
Old February 14th, 2009, 09:11 PM
I will take 2...
Old February 17th, 2009, 09:22 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Looks like these are going to be $4 to ship in the lower 48 -- same price for 1 or 2.
Old February 17th, 2009, 09:40 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I will take 2... pm'ed
Old February 17th, 2009, 10:11 AM
Kilgore503
Nathan Turpen
NAS 94 Defender 90
Do these fit the holes left when removing the oil cooler lines?
Old February 17th, 2009, 10:15 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Nope, they fit the top of the radiator and the top of the water pump housing -- where the black plastic ones live. For clarification, they do not have the enormous slot on top for a leatherman, they require a socket to install/remove. They include an oring.
Old February 17th, 2009, 10:34 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I need a few. How many do you have? Trade for hose?
legend in my own mind
Old February 17th, 2009, 10:42 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Well, it turns out I'll need some more. I have a (very) few left but will get some more in. I'll see if I can't get the price down a bit as well.
Jim you know I'll take care of you, pm me with a quantity. You should have the oil cooler now as well, yes?
Old February 17th, 2009, 11:15 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I need to pick up one from ya. Let me know when you get some more and I will swing by.
B
Old February 17th, 2009, 11:37 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Anyone else interested before I get some more?
Old February 17th, 2009, 12:37 PM
Kilgore503
Nathan Turpen
NAS 94 Defender 90
Not to keep hijacking, but anyone know where to get plugs or caps that would close off the openings left by removing the oil cooler lines?
Old February 17th, 2009, 03:57 PM
pendy's Avatar
pendy
jim pendleton
89'd90
What are you trying to do? You can remove the sandwich adapter from the oil pump to get rid of the oil cooler lines.
Old February 17th, 2009, 04:14 PM
Kilgore503
Nathan Turpen
NAS 94 Defender 90
Hey Pendy,
I've already removed the oil cooler lines and the sandwich plate. Just screwed the filter back on. Everything is working as it should, and haven't noticed any difference in temperature or performance. I just need to plug the open holes in the radiator so it doesn't fill with dirt or debris. I was just curious what plugs I should use.
madcowdungbeetle
Carter
I'll take a pair.
Old February 17th, 2009, 06:26 PM
You guys do know these are 1/2" BSP plugs used on millions of household radiators worldwide. They really should only be a few dollars.
Look up ERR4686B which is the Britpart number. ERR4685 is the O-ring.
Old February 17th, 2009, 06:51 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Wish you'd posted that a very long time ago . . .
If anybody that has paid for them wants to return them, I'll happily refund the purchase and return shipping.
Actually, check that. Just to avoid the appearance of impropriety, I'm going to refund everyone's money and have you keep the plugs.
Tony
Old February 17th, 2009, 10:19 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Hey Pendy,
I just usually put plastic caps over them. Left over from new lines. You may even have som around.
Old February 17th, 2009, 10:27 PM
Maybe in the UK, but nothing in the home depot here matched up.
Old February 18th, 2009, 10:44 AM
Sure, just buy them out of the UK. The pound is worthless ATM, shipping is cheap. Not sure why the local Rover parts places don't carry them. Personally, I buy everything out of the UK. Cheaper and faster than the USA....
Old November 29th, 2009, 09:53 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Tony, do you still have some ?
- Charles Eames
radiator
Ammo and brass FS stu454 The Flea Market 2 December 7th, 2009 03:09 PM
Brass radiator plug ERR4686 JFD Defender Technical Discussions 9 November 30th, 2009 09:10 PM
D90 rotors, pads artm Defender Technical Discussions 12 April 12th, 2007 01:19 PM
Brass Radiator Plug Billakris Defender Technical Discussions 18 May 11th, 2006 11:35 AM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
