Brand New Defender Series Style 2 Piece Front Door Kit - Defender Source
Old March 15th, 2016, 06:39 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
This kit is brand new and comes with everything you need for the 2 front doors including anti-burst handles, strikers, latches, barrel locks, bottom seals, etc. These doors can be picked up in Phoenix or shipped in two large boxes.
$650 plus actual shipping costs.
PAIR OF BESPOKE SERIES STYLE DOORS TO SUIT DEFENDERS 1983- PRESENT
This is the full kit that you need to do the swap over from push button doors to this 2 piece type!
The parts in this kit are:
  • PAIR OF BESPOKE MADE DOOR BOTTOMS
  • PAIR OF FULLY GLAZED SERIES 3 DOOR TOPS
  • RH & LH ANTI BURST HANDLES
  • RH & LH STRIKERS FOR HANDLES
  • 2X DOOR TOP LATCHES
  • 2X DOOR TOP TO BOTTOM SEALS
  • 3 BARREL LOCK AND KEY SET
In this kit, these are the only Series style defender door bottoms you will find in the world that are made specifically to convert all Defenders to the simpler and more robust Series split doors.
These doors and tops are steel framed with aluminium skins as per factory spec
Before today the only option to do this yourself is to buy standard series 3 or series 2 door bottoms and tops and modify and add various brackets to make them fit Defenders. The main problem was that the check strap bracket is completely different and in the wrong place on standard series doors.
Also normal series doors lack the lever thatís pushes the interior light switch on and off which also acts as part of the intruder alarm system from mid 1990 models onwards. These are made by the same company that makes Defender push button doors so the same jig and bracket has been used on these doors so it is in exactly the right place. Our bespoke doors bolt straight onto any Defender 90/ 110/ 130 1983- present and replicate all of the original functions your vehicle needs. No extra modification or welding is needed; these simply bolt onto you existing hinges!
Benefits of converting to 2 part doors:
1. Much cheaper than new Defender push button doors
2. Much simpler and less to go wrong as there is no winding window mechanism to go wrong!
3. Much less rot prone
4. Lift up handles are much stronger against theft prevention as the lock design is stronger
5. Lift up handles are off-road safe as they do not protrude out of the door like the plastic push button handles do.
6. Much more elbow room inside the cabin
7. Removable door tops if you have a soft top or just wish to let more air in!
Old March 15th, 2016, 11:17 PM
Tarmac
Matt Marks
1988 Defender 110
Please call Matt about doors. 916-601-4090. Thanks
Old March 16th, 2016, 09:49 AM
86Defend110
Jesse
Sold
Sold pending payment
Old March 16th, 2016, 03:08 PM
86Defend110
Jesse
Paid
Payment received.
Old March 16th, 2016, 03:15 PM
jon110's Avatar
jon110
Jonathan Barron
1987 110
Do you have any more of these kits or know where i can get them.
Thank you
Old April 16th, 2016, 09:12 PM
RoverNY
Darrell
1987 Defender 90 ex-MOD
2 Piece Door Kit
Please let me know if you have any more of these or if you can let me know where to find them.
Thank you,
Darrell
Old April 17th, 2016, 10:33 AM
Naplm00
Matthew
These exact kits are on ebay. Co. Uk
Old June 29th, 2016, 01:49 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Has anyone bought these and installed them? Wondering the quality since the price seems rather inexpensive considering what you get.
Thanks in advance!
Old June 29th, 2016, 08:02 PM
tijnes
Martijn
110
I've installed a pair of them. Got them from sp4x4 in the UK. The door bottom is same or similar quality as the original. The tops are fine but the front piece of glass doesn't slide back like the others I have had Not a big deal to me and for the money well worth it.
Old June 30th, 2016, 12:43 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Thanks. That's all I needed to hear. They look really great and so does your truck! Very cool.
Thanks again!
Old June 30th, 2016, 01:06 PM
86Defend110
Jesse
If you do buy a set, get them from SP4x4 in the UK. Even with shipping they are much cheaper than the Ebay sellers. Especially now with the British Pound dropping....
Old June 30th, 2016, 01:35 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
I have a set of just the door bottoms I'll sell. I'm not sure what I'll ask for them. I'll make an ad with pix tomorrow.
Old July 1st, 2016, 05:31 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Hey Martijn, did you do the switch to replace the '83/'84 style latches that give out and are impossible to find? The passenger side door of the Old Land Lady is giving me hell and I was thinking about just converting to the full passthrough style latches.
Also, A 90???! That's not your style!
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
defender, door, doors, front, glass, kit, new defender, puma, series, two piece, window
1 Piece Tunnel Covers R380 (New Style) FS SafariHP The Vendors Loft 11 July 24th, 2017 09:20 PM
Brand new folding side step defender new style budzny For Sale - Parts 7 December 9th, 2015 02:33 PM
Early style rrc grille center piece J. Pound For Sale - Parts 4 April 5th, 2015 02:40 AM
Front Door Hinge Kit for Defender (TD5 Style Heavy-Duty) with Stainless Bolts 89Defender90 For Sale - Parts 6 March 18th, 2015 05:31 PM
2-piece to 1-piece roll-up doors J4hand Defender Technical Discussions 2 March 25th, 2009 09:42 AM
