Bench Seat & Seat Belt Bracket Feeler - Page 2 - Defender Source
Old August 28th, 2010, 08:08 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Is this a 94 vs 95/97 thing? My truck was not prepped for a rear seat installation at all but Charles' was and he doesn't have any mounting holes in the sidewalls of the tub that would accommodate any type of bracket. I (like Charles) also believe the seat itself is slightly different...very interesting though
Old August 28th, 2010, 09:06 PM
Nope. Barry's is a 94 Arles Blue.
Old August 28th, 2010, 09:55 PM
jack SF
jack baran
95 ST yellow
the seat requires 2 brackets to hold it into the floor on the front. than 2 brackets are required in the back on the tub to prevent the seat from jumping up in a sudden stop. in the TECH ARTICLES section there are installation instructions and there are diagrams off the brackets.
Old August 28th, 2010, 10:07 PM
As jeff said my truck never had those rear brackets. But on closer observation my seat is setup to use them. Next time I'm on a computer I'll check out those brackets but it would be nice to see a picture of the seat in the locked position if anyone has one.
Originally Posted by pendy
I'm here for the D's
Old August 28th, 2010, 10:17 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Does anyone in the DC area have these brackets? I would like to take a look in person if possible. I will post a note on the NOVA HH thread as well
Old August 28th, 2010, 11:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Charles
Glad your seat has the pegs. I think my pics shows it in the locked position. Since the 94s didnt come with the seat I have seen some bad installs namely my truck. Who ever put my seat in put the bottom seat belt brackets on the inside of the truck and not the outside. The seat belt anchors go under the truck and the bolts come through, on my truck the anchors were inside the truck with a few bolts holding them in. Easy fix but made me wonder about some of the installs. Not surprised at all some trucks are missing brackets.
Old August 29th, 2010, 09:34 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Barry, thanks for the heads up on this bracket. I was curious about why the rear of the seat didn't have a locking/fastening mechanism. I will definitely seek this bracket out and add it to the list of pieces to be made as I plan to haul my 2 year old around in the back of the 90 when weather permits! If I can't find one locally I may bug you for more photos and dimensions.
Old August 29th, 2010, 10:15 AM
Yeah I guess 4932832149 shows it locked down. I'm not convinced this is a critical feature though. Other than the seatbelts not holding the additional mass from the seat itself (which is on a pivot upward, so a small fraction of the full weight of the bench in most scenarios other than a rollover), those brackets don't do much for you on impact.
But dimensions would be good.
Old August 29th, 2010, 10:22 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Should we move this thread to the Technical Discussions to get more exposure and not muddy up the for sale section?
Old August 29th, 2010, 11:32 AM
bjf's Avatar
bjf
barry f
94 ST #395
Charles
I don't know about you but I wouldn't want to sit in that seat without the lock downs. Especially if I wasn't wearing my seat belt and I went over a bump. Think about the children!!!!
Old August 29th, 2010, 08:30 PM
I totally agree if you are not wearing your seat belt, all bets are off.
Do you want it moved Jeff? Free bumps otherwise.
Old August 29th, 2010, 08:37 PM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
The D90 belt I have are hard to use because they are shorter belts than the OEM D90 ones. You pretty much need to fully extend them to snap into the female end which often results in the belt locking up -- then I have to play with the belt for a minute or two to get it too release.
I had thought of having a local machine shop make a hanger for the top mount effectively "lengthening" the belt (which I think I have seen someone else post before). Is anything like this in your kit? If so, I would be interested in saving the time and putting in an order for a set of those. Thanks!
Heston
Old August 30th, 2010, 08:27 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I'm planning to swing by Loic's house soon to check out the brackets so we can leave it here for now...hopefully I will have a more complete set of brackets soon!
------ Follow up post added August 30th, 2010 08:32 AM ------
I am running a set of Disco belts in the rear of my truck which have the same issue of being a little shorter. To compensate for this I made the mounting bracket for the retractor a little taller and also mounted the lower belt a little higher on the tub wall. I also made a plate for the Y belt that moved it's mounting location forward about 1 1/2". The combination of these mods made it so I could sit in the seat and buckle the belt...I am a good size boy (6' - 240lbs) so I figured that I would call it close enough and most folks who sit back there should fit without a problem!
Otherwise, I have seen others who added a 1-2" drop bracket at the upper mount which can easily be fabbed up.
Old August 30th, 2010, 12:15 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
I'm not sure how it's going to play out once installed, but I bought a rear seatbelt kit from JC Whitney. The female parts are 18" long, almost identical to OEM, and I believe the length of the belts is more than adequate. They were $75 for the pair. With OEM or Jeff's seat belts, it should work...Ill have more information in the coming weeks hopefully.
Also, Jeff, I want those machined parts!
Jerod
Old August 30th, 2010, 12:55 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Got your email Jerod, just been slammed and have to go back through to figure out what they actually cost! I'll get back to you later this week
Old August 30th, 2010, 11:01 PM
kenco's Avatar
kenco
Ken D
94 / D-90 soft top - arles blue
count me in for a set...
ac, bench, bracket, rack
95 D90 Seat Belt & anchor for bench seat grinch79 Wanted 0 April 9th, 2007 03:12 PM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
Seat Belt Bracket popeohana Defender Technical Discussions 1 February 17th, 2005 03:30 PM
Seat Bracket dimensions, anyone? bd90 Defender Technical Discussions 1 August 26th, 2004 08:12 AM
Wanted: Forward facing rear bench seat zed111 Wanted 0 July 26th, 2004 01:52 PM
