Axle shafts CVs Fans Swivels and PS parts - Defender Source
Old January 30th, 2015, 03:24 PM
Post Axle shafts CVs Fans Swivels and PS parts
Stock D90/110/D1/RRC 24 spline axle shafts
Great condition rears with just a little polishing on the spline contact area- no appreciable wear. $50/pair (2 pairs available)
stock 24 spline Front halfshafts with ABS CV's $100/pair
AEU2522 CV's with 23/10 spline inner shafts $50/pair (not pictured) with hubs and stub axles make it $100 (shipping will suck for you)
Ford Taurus electric fan working/tested $100 Great for Tdi or other 4 cylinder setups
Disco 200tdi Clutch and Fan Not seized $75
2.25 petrol PS pump and bracket with double groove crank pulley. Pump worked but was a little grumpy. Can switch for later style pump if you change your lines from banjo style. I can include the banjo fitting and bolt for this style pump $100
D1 or D90 teflon swivels great shape $100 pair. Or take the complete outers with hubs and stub axles for $150. will be a bitch to ship.
All items OBO- Prices are *plus shipping* from DC zip code 20010
Can bring some of this to Winter romp. Or deliver to Rick Newman for NoVA Happy Hour/RURR connection.
ID:	112334   Click image for larger version
ID:	112336   Click image for larger version
ID:	112338   Click image for larger version
ID:	112340   Click image for larger version
ID:	112342   Click image for larger version
ID:	112345   Click image for larger version
Old January 30th, 2015, 03:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Interested in the Taurus fan. Any truck to making it work for a 200tdi radiator? And does the wiring have to be modified? I am assuming it is a "pull" setup?
Old January 30th, 2015, 03:44 PM
Its a puller and I think you might have to trim the integral shorud to fit the tdi hoses. John Red90 on here has a good post somewhere about fitting one. You'll need a controller switch of some kind. this is just the fan and the factory shroud and the wiring for the fan motor as pictured
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 30th, 2015, 03:52 PM
My writeup is here: http://www.landroveraddict.com/forum...threadID=56139 For control I suggest the DCControl dual relay controller, http://www.dccontrol.com/relay_controllers.htm
Old January 30th, 2015, 04:05 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Interested in your balls Bobeck! call them licked for now and sending you an email
Old January 30th, 2015, 04:08 PM
Balls licked
Present:
1987 RRC- "Chewy 2"
Past:
Old January 30th, 2015, 04:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks! Will read up on it after I get some D work done in the garage
Old January 31st, 2015, 06:48 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
David
If I am converting 92 rrc abs from 10 to 24 spline do I need the hubs or just the axles? I have 24 3rd members already ready to go.
~ Semper Fidelis ~
Old January 31st, 2015, 11:43 AM
Originally Posted by speedpin View Post
David If I am converting 92 rrc abs from 10 to 24 spline do I need the hubs or just the axles? I have 24 3rd members already ready to go.
Probably need the hubs and stubs for the classic. Jeff huff claimed those so you'd need another set or talk him out of them. I think he'd be willing since it sounded like he didn't really need them. Though you'd need another set for the back as well I think.
Present:
1987 RRC- "Chewy 2"
Past:
Old January 31st, 2015, 07:25 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Adam, shoot me a message and we can work out what you need
axle, fan, part, parts
Can you retrofit "suffix a" RRC CVs and short end axles to a NAS 110 front axle? evilfij Defender Technical Discussions 2 April 13th, 2013 10:18 AM
GBR heavy duty front shafts/CVs! crown14 For Sale - Parts 2 February 9th, 2011 12:26 PM
Rover Gear and a Beer Ashcroft D2 CVs & 1/2 shafts Fivespddisco Misc. Chit-Chat 1 February 10th, 2010 09:44 PM
GBR diffs, half shafts, and CVs... FEELER... bharris For Sale - Parts 9 November 11th, 2009 10:40 AM
TruTrac, 24 Spline Shafts, CVs mudrover For Sale - Parts 6 June 15th, 2004 05:29 PM
