ARB air lockers differentials for sale, fresh rebuild - Defender Source
Old October 27th, 2015, 12:06 PM
rover2a's Avatar
rover2a
Gar Hendry
1967 series2a
I did not think there would be this much interest in ARB diffs, so I moved my post to the for sale section, I hope it helps, so I am posting one reply and everybody can get all the information they requested.
I have for sale a pair of freshly rebuilt Land Rover ARB Air Lockers. They were rebuilt by GBR in Salt Lake the end of last year, never installed.
They started out with very few miles on them, but had been sitting in one of my old Discovery’s and not moving for several years I had them rebuilt before I was to install then in a new discovery. Alas that never happened.
The gear ratio is 3.54:1, standard gearing for a 1997 discovery series 1.
They are 24 spline
They come with switches, wiring, air hose and ARB air pump, all used but fully working.
I am looking to sell everything together
PM with questions.
Will fit D90, RR and other rovers
I am looking for around $2200 for the setup plus shipping.
See photos for how they are set up.
ID:	133270   Click image for larger version
ID:	133272   Click image for larger version
ID:	133274   Click image for larger version
Old October 27th, 2015, 12:48 PM
rover2a's Avatar
rover2a
Gar Hendry
1967 series2a
I believe it is the RD56, I have a photo that should help in identifying the model.
ID:	133277   Click image for larger version
Old November 16th, 2015, 02:47 PM
rover2a's Avatar
rover2a
Gar Hendry
1967 series2a
Still available, $2000 with free shipping
Old January 2nd, 2016, 02:21 PM
rover2a's Avatar
rover2a
Gar Hendry
1967 series2a
It has come to my attention that if you are looking are these difs i have converted the the rear diff to use a universal joint instead of the flex coupling so it is the same as the front, this involves a change to the drive line
Old January 2nd, 2016, 05:08 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
If anyone wants to split this up I'm interested in one complete diff only.
Semper Fi!
Old January 2nd, 2016, 05:56 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Im interested in the pump if you are willing to split them up
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 2nd, 2016, 06:26 PM
rovertrader's Avatar
rovertrader
Dale
I can use the front diff if sold seperately...
Old January 2nd, 2016, 09:59 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
I may pick up both. PMed.
Old September 14th, 2016, 05:07 PM
rover2a's Avatar
rover2a
Gar Hendry
1967 series2a
bump
Old September 14th, 2016, 08:14 PM
FWIW I prefer the 56s (which is what you have)....when I switched to 128s I was pissed to see they changed the copper air line routing to go OVER the ring gear! Makes no sense....56 design is much more "install friendly".
Screaming deal for $2k shipped by the way....
Old September 14th, 2016, 10:57 PM
yeah but when you measure the run out on the rd56 after shattering a ring gear, you will see why they went with a different design on the 128.
yes, screaming deal, GLWS!
FWIW I prefer the 56s (which is what you have)....when I switched to 128s I was pissed to see they changed the copper air line routing to go OVER the ring gear! Makes no sense....56 design is much more "install friendly.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 15th, 2016, 09:36 AM
deepseaoutlaw
phil griffin
1985 defender
rover2a i sent you an email.
Old September 15th, 2016, 10:07 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Not to derail but more esplaining esse?
I busted a ring gear on a RD56 years ago...still driving on that same carrier now.
Rent my
Old September 16th, 2016, 12:43 PM
rover2a's Avatar
rover2a
Gar Hendry
1967 series2a
all is sold, thanks for looking
Old September 16th, 2016, 01:30 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Gar congrats on sale.
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old September 16th, 2016, 03:47 PM
I'm guessing that DB is referring to the ring gear flange on the RD56. It was redesigned for the 128, mostly increasing the thickness. Usually the failure mode is catastrophic...if it doesn't break, then it doesn't really have problems.
Old September 18th, 2016, 10:41 AM
Not to derail but more esplaining esse? I busted a ring gear on a RD56 years ago...still driving on that same carrier now. .
You got lucky and it didn't bend, or you didn't check it and you are even luckier. Mine was out by over 50 thou. This would make it impossible to get the backlash set up correctly.
In case you are really bored:
https://youtu.be/BMyH4AjTneo
Present:
1987 RRC- "Chewy 2"
Past:
differential, for sale, rebuild
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
Front and rear differentials built with 3.54 gears ARB Air Lockers $1950 ron For Sale - Parts 3 December 4th, 2012 09:11 AM
ECR fresh NAS 110 rebuild with 300tdi, $160,000 evilfij The Flea Market 100 March 17th, 2011 01:11 AM
GBR TruTrack and Detroit lockers with 4.11 differentials bharris For Sale - Parts 9 July 16th, 2010 12:15 PM
Fresh (Cold) Air Intake D-90 CDeWan Defender Technical Discussions 8 November 4th, 2008 02:24 PM
