ARB 3.54 gears third complete - Defender Source
Old October 5th, 2012, 10:03 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile ARB 3.54 gears third complete
ARB 3.54 gears third complete$800
newer gears fresh build
plus shipping
Old October 5th, 2012, 02:26 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Dumb question, but are all early land rovers running the same gears? I have an 85 90, but it has full drivetrain and axles from a mid 90's disco. I have no idea of what the gearing ratio is.
Old October 5th, 2012, 04:52 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Unless your ring/pinion gears have been changed, then it should be 3.54. You can estimate the ratio on your axle by jacking up one wheel, putting the transmission in neutral, and counting how many rotations the pinion/driveshaft makes with one full rotation of the tire. Should be 3 1/2 rotations
Old October 5th, 2012, 05:07 PM
ron's Avatar
ron
Ron
90's discos run the stock 3.54 gears
Old October 5th, 2012, 06:57 PM
Damn, timing sucks. I would be all over this a few months from now. Best of luck. Anybody else have one of these they'll sell in the spring? Get ready.
Mark Kellgren
KM4BOR
Old October 5th, 2012, 07:04 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Is unit 24 spline?
John Karlsson
Hope Valley, RI
Old October 5th, 2012, 07:31 PM
the rover shop
shayne young
PM sent
Old October 5th, 2012, 11:41 PM
For the most part, all coilers run 3.54 gears. The earlier trucks use the coarse spline pinion, and the later trucks use the fine spline pinion. I believe they pinion splines changed somewhere around '93. The differential side gears are either 10 or 24 spline depending on year/vehicle etc.
Leafsprung trucks use 4.56, although there were some early trucks with 3.90 gears. All with coarse spline pinions.
-Jeff
Leafers use 4.7 (not 4.56) and some very very early series I trucks had something close, but not the same. I have never seen a factory 3.90, but I always learn something new.
Old October 6th, 2012, 11:02 AM
ron's Avatar
ron
Ron
yes 24 spline
Old October 6th, 2012, 11:34 AM
John_Karlsson
John Karlsson
Originally Posted by ron View Post
yes 24 spline
Too bad. I need ten splines.
Thanks!
John Karlsson
Hope Valley, RI
Old October 6th, 2012, 02:35 PM
ron's Avatar
ron
Ron
so change the half shafts to the stronger 24
Old October 9th, 2012, 03:23 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Does it come with any air lines or the hardware for the diff? What else is needed to run them other than the air compressor? Does it come with the mouthing hardware and switch?
Old October 10th, 2012, 09:10 AM
ron's Avatar
ron
Ron
just the diff... I think the compressor will have the switch and line .. its a very easy install
ARB locker ready to install 3.5 gears ron For Sale - Parts 11 October 18th, 2012 11:48 AM
Complete OE stock third with ARB diff. Not crazy about selling.... Feeler? :) Roving Beetle For Sale - Parts 10 April 9th, 2012 12:49 PM
Detroit Locker, Complete 3rd - 3.54 / 24 spline axle souza For Sale - Parts 7 August 14th, 2011 09:50 PM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
