Any Takers...? - Defender Source
Old January 11th, 2010, 11:30 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Any Takers...?
I have a brand new(not reman) 1.4 Lt230 with the highly sought after 49% low Maxi-drive gears installed for the low range. I was going to use it for a buggy project of mine that kinda got side tract. I payed around $5k for the parts/labor/shipping. Take'n offers!
Old January 11th, 2010, 12:48 PM
What kind of range are you looking for? Also, is there anything you need or want to trade for?
Old January 11th, 2010, 02:04 PM
5,000$ for a transfer case
Old January 11th, 2010, 09:09 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
holy crap! What does it do that makes it worth 5000 dollars?
Not knocking you I really want to know...
Old January 12th, 2010, 01:15 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Sorry, I can only tell you what it ought to do...
Old January 12th, 2010, 06:06 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Shoot, you can get an Atlas II for half that!
Semper Fi!
Old January 12th, 2010, 08:18 AM
maybe 2
Old January 12th, 2010, 10:49 AM
JPBrown's Avatar
JPBrown
James Brown
91 & 2000-110 -93 130 wagon, 88 d90
I have the same set up in one of my trucks, I paid 5k and it is worth it!
Good luck with the sale
Old January 12th, 2010, 11:17 AM
I am interested... Trying to justify the cost v. an under-drive. Are the gears too low to drive easy obstacles? Will I need to run some of the trails in high range?
Old January 12th, 2010, 08:31 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
It being a 1.4 ratio high range puts you back in your rev range on the road and cruise'n trails but the 49% low range makes it to where you don't even have to try any more....just aim and shoot and it walks right over whatever it is. The add-on under drive leaves you with more junk under your rig to get hung on and an extra shifter to deal with. An Atlas I or II ain't got shit on this set-up and you don't have to have any modifications. What do you have to trade?
Old January 13th, 2010, 11:07 PM
DD90's Avatar
DD90
DD
94 D90
Agree it's a better setup than aftermarket but how does the 1.4 get a better rev range??
Isn't the 1.2 "built" for that engine application, ie 3.9?
Old January 14th, 2010, 06:07 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
The 1.4 would work depending on how big you went with your tires. And to add to that....the 1.2 is a general box made for economy/power/common driving with no lust for life! Hope that helps.
Old January 14th, 2010, 10:48 PM
cdb
Clark Bowen
"The add-on under drive leaves you with more junk under your rig to get hung on and an extra shifter to deal with"
No.
There are no issues with the underdrive getting hung up on anything as it is way up out of the way.
Yes, there is another shifter, but now you have much more flexibility than the MaxiDrive gears.
I seldom use first, low, underdrive but it is there if you want it. Sometimes I use first, high, underdrive, etc. Much more flexibility than either the standard gears or the MaxiDrives.
And yes, it is expensive, but it adds a whole different dimension to the D90. I've driven a D90 with the MaxiDrive gears and I have an underdrive and for what's worth I think the underdrive is much more valuable - and fun.
2011 RR HSE -
2001 GMC 2500 4wd
Garage Cleaning - Everything Must Go!! m.michaels For Sale - Parts 13 February 7th, 2006 03:02 PM
Found old Series in NJ Junkyard - Takers??? mudrover Misc. Chit-Chat 4 January 24th, 2006 10:55 AM
