All I want for Xmas is some Equipe Bumperettes! - Defender Source
Old December 21st, 2013, 05:31 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
For sale a pair of Equipe Bumperettes with corner panel kit. Brand New...Never Installed $300 shipped Click image for larger version
ID:	86501 Click image for larger version
ID:	86502 Click image for larger version
ID:	86503 Click image for larger version
Old December 21st, 2013, 05:33 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Originally Posted by tebby View Post
For sale a pair of Equipe Bumperettes with corner panel kit. $300 shipped
Old December 21st, 2013, 06:19 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
These are the shizzle. I recentlly ordered a set from COR4 for my 110.
Semper Fi!
Old December 21st, 2013, 06:50 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Wolf...did you use these exact ones for a 90...or did you order a 110 spec pair?
Old December 22nd, 2013, 12:59 AM
Wolf Fabrication
Sterling Archer
'08 D3
Ordered a 110 set. The newly designed COR4 ones are pretty slick.
Semper Fi!
Old December 22nd, 2013, 09:43 AM
If I didn't already have a custom set of corner guards similar to these I'd be all over them...price is great, these should move quickly.
Old December 22nd, 2013, 09:45 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Nice design, but looks like trimming of the tub is required. Once you go trail rig, no going back here.
Old December 22nd, 2013, 09:48 AM
I'm pretty sure no trimming is required...though I know one of the Equipe pics show a truck that way, the tub should fit inside of the surround bar without issue (from similar sets that I've seen).
Old December 22nd, 2013, 10:14 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
TRIMMING of the corners required!!! I was a bit misled with the whole "trimming" of the corner when I purchased. I thought these were just bolt on with the triangular side piece. Full disclosure here...what I see as common sense...I see no way around not trimming!!! I'd imagine there would be additional alterations required if you have a 94NAS (square lights)...but not sure of the configuration of those. I'm assuming all the rear corners of the UK trucks 1980s and later are the same as NAS? I actually like the design/look of the trimmed corner...but I'm after the other Equipe Bumperettes (that terrafirma knocked off...with the triangular side).....any trades out there???
Old December 22nd, 2013, 10:17 AM
And I stand corrected....my bad!
Tebby...you may want to contact Huff ('jefhuf' / Lelofab.com) to see if he's still fab'ing sets of these, they WILL fit any NAS or ROW 90 without trimming of corners.
Old December 22nd, 2013, 10:37 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Jason...if I sounded harsh I wasn't directing it towards you. A little bitter with previous communication of these things
Old December 22nd, 2013, 10:46 AM
Ha, no I didn't interpret it that way at all! I was more directing it to Russell's (correct) comment and my mis-information since I thought they'd fit.
Old December 22nd, 2013, 12:11 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Timing is everything... I would have picked these up in a sec but I just bought and installed the ones being made by a by a board member (think its Jeff)... They fit perfectly by the way...
Screen name is JSQ...
Old December 22nd, 2013, 12:53 PM
That sounds like Huff...
Old December 22nd, 2013, 02:51 PM
down_shift's Avatar
down_shift
Russell
Lav, you are 0 for 2 -- for another cup of java. ;-). That is Jack Quinlan of the "Truck Shop". The same set on my NAS 90.
Old December 22nd, 2013, 02:57 PM
Rugbier's Avatar
Rugbier
Gustavo
The Equipe requires modifications to fit with a NAS tire carrier to lay flat
Options are to modify the guards or the carrier mount ( by the crossmember )
NO SIGNATURE
Old December 22nd, 2013, 05:46 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
As several others have said these will require modification if mounting to a NAS truck. Shameless plug since I was already mentioned but I do make sets of corner guards that will work on NAS trucks that wrap protect both the corner and protrude from the rear crossmember like the Equipe guards do (unlike JSQ's).
Disclaimer, no offense intended for JSQ, just pointing out that my guards are different than his.
Old December 22nd, 2013, 05:59 PM
down_shift's Avatar
down_shift
Russell
Worth mentioning for all of these guards is if the NAS step bumper may be retained.
Old December 22nd, 2013, 06:05 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Good point Russ, with my guards it will not be. Basically I have designed mine for those that have "crossed that line!
Tebby, sorry for dirtying up your thread
Old December 22nd, 2013, 07:38 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
JSQ guards retain the NAS bumper...
WTB Equipe Bumperettes tebby Wanted 1 November 27th, 2009 09:57 PM
Equipe Swivel Recovery Points RedRhinoProducts For Sale - Parts 7 March 17th, 2006 06:01 PM
Scorpion Bumperettes w/ Shrockworks Tire Carrier? oldscratchggf Defender Technical Discussions 4 October 17th, 2005 08:40 PM
Equipe 4x4 NashvilleRedD90 Misc. Chit-Chat 2 June 22nd, 2005 11:40 AM
Scorpion Racing Bumperettes Krna Defender Technical Discussions 6 May 26th, 2004 02:18 PM
