A-Pillar Light Mounts - Defender Source
Old June 5th, 2015, 07:53 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I am developing A-Pillar Light mounts for the D90/D110 for my truck, and would also like to offer it to the members here for those interested.
The mounts come in pairs, for both the left and right side, and are made of 1/8" steel, powder coated black with a 7/16" light mounting hole. All corners will be rounded. It allows mounting a pair of compact offroad lights on the lower A-Pillar.
Here are photos of the work in progress, just to give you an idea where this is headed. The goal is to price the pair at no more than $40.00
Please let me know if this is of interest to you.
Name:	2015-06-05 15.57.10.jpg
ID:	122381   Click image for larger version
Name:	2015-06-05 15.57.13.jpg
Name:	2015-06-05 15.57.21.jpg
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old June 5th, 2015, 08:15 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Don't forget a shim of equal thickness on the door side of the hinge and the both sides of the lower hinge...
Old June 5th, 2015, 08:47 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Already planned, 1 shim needed only for the upper hinge in 1/8" ABS. No shims needed for the lower hinge.
Thank you - Samer
2003 Discovery II
Old June 6th, 2015, 11:09 AM
SidewaysWaffle's Avatar
SidewaysWaffle
Dan Capo
Loading..
Interested for sure
"A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist."
Old June 6th, 2015, 11:47 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I'd be interested as well!
Old June 6th, 2015, 07:18 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
How big of a light can you mount before the vents hit?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old June 7th, 2015, 02:13 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
The mount is designed for the smaller quad lights such as the Rigid D2 series or competitive equivalent, and the maximum width before hitting the flaps is 4 1/2".
For those interested in a bigger light, much bigger as a matter of fact, I am in the process of designing mounts that will accommodate a 50" light bar at the base of the windshield, ABOVE the air flaps. Those mounts will attach to the external windshield hinges and allow you to install a light bar that will stretch across the width windshield/hood.
Please stay tuned!
Thank you - Samer
2003 Discovery II
Old June 7th, 2015, 02:16 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
subscribed, but can these be powder coated black???
uh huh, never mind ....
1994 Silver DEFENDER 90 NAS SW
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
V.2 of the pillar mounts. Apologies for the crappy photos, they were quickly taken with my phone.
Once the mounts are finalized, I will have them professionally photographed and posted on my website.
Name:	2015-06-07 10.43.54.jpg
ID:	122508   Click image for larger version
Name:	2015-06-07 10.44.10.jpg
Name:	2015-06-07 10.44.42.jpg
Thank you - Samer
2003 Discovery II
Old June 8th, 2015, 05:31 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Getting there.... With lights mounted:
Name:	2015-06-08 14.19.09.jpg
ID:	122577   Click image for larger version
Name:	2015-06-08 14.20.21.jpg
Name:	2015-06-08 14.20.49.jpg
ID:	122579   Click image for larger version
Name:	2015-06-08 14.20.02.jpg
Name:	2015-06-08 14.19.17.jpg
Thank you - Samer
2003 Discovery II
Old June 8th, 2015, 08:32 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Nice idea... a couple of pointers.... you might want to add a small gusset between the light tab & vertical bend. Would prevent any stress cracks in the tab bend from vibration. I'd also radius off the front of the light tab too.
Sort of like this.... keep up the good work
Old June 8th, 2015, 08:36 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Thanks Andy. Radiuses will be added everywhere. I don't know if the gusset is needed, after all the steel is 1/8" thick, and the entire bracket feels really stout and solid. I will definitely reconsider it though.
Thank you - Samer
2003 Discovery II
Old June 8th, 2015, 08:38 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Visuals play a lot on things like this... might not need it but if it's there it looks 'solid'... also hides the bolt head and is a nice place to put your logo
Old June 8th, 2015, 09:48 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
All true, all true. Definitely worth considering. Thanks for the tips.
Thank you - Samer
2003 Discovery II
Old June 9th, 2015, 01:11 AM
Spook's Avatar
Spook
Rich
97 Defender 90
What about friction between the mount and the vehicle to protect the paint? Just thinking as you open / close the door it might start to wear. Looks good so far. I'm probably down.
Old June 9th, 2015, 07:14 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
These are very cool. Had these on my cj7 and they were great.
Old June 9th, 2015, 11:02 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
What friction are you specifically referring to, I'm not sure I understand. The bracket itself is fixed, just as the door hinge itself would be, if there were no bracket. When the doors are opened and closed, the light brackets are stationary and there shouldn't be any friction. Please elaborate.
Thank you - Samer
2003 Discovery II
Old June 9th, 2015, 01:30 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Good job ! I have done something similar in the past but at the end of the day I thought it was to jeepish . The squares look better than the round 6" I test fit .
85 D110 3.5 3 DR
Old June 9th, 2015, 01:42 PM
May also have CB aerial potential.
Old June 9th, 2015, 02:19 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
I'm also interested, but these don't look like they would work with the NAS cage. Thoughts?
ht, mount
Tranny Mounts, 4cyl engine mounts, Tub tomaco1 Wanted 0 December 4th, 2010 12:42 PM
ST b-pillar c-pillar and cantrails dave_lucas Wanted 7 May 12th, 2010 11:39 AM
A Pillar Cage and B pillar seat belt holders CDeWan For Sale - Parts 14 December 24th, 2009 07:18 PM
roll cage a pillar wing mounts rgrrvr Wanted 10 January 24th, 2008 10:19 AM
