$9800 - 1998 Discovery for International MWM HS2.8L Engine / Heavy Duy Parts - Defender Source
Old July 16th, 2016, 09:57 AM
Michael
Michael
Discovery 1998
$9800 takes all for a very limited time, before I start pulling it apart.
See my previous post.
The bad: Body and Frame not good from floor down
The excellent:
International MWM HS2.8L engine w/ M&D kit for NAS Autobox
Rovertracks Heavy duty front axle stuff (CV's, galvnanized and powdercoated steering components)
Kamdiffs Heavy Duty Rear Axle Stuff : Cable operated locker - the one that requires 2" hole drilled in axle housing.
3" Marine Grade (316) Stainless Steel Mandrel Bent Turbo back Exhaust (maybe cut to fit d90??) with EGT bung
Cunifer Brake Pipes
much more, pm mel
Old July 30th, 2016, 07:25 AM
Michael
Michael
Discovery 1998
Bump.
I am sure most are familiar with M&D's kits, but I will mention:
The M&D Adapter Plate and engine mounts are bolt on to most if not all NAS Land Rovers with 3.9 or 4.0 V8 engines, both automatic and manual transmissions
No cutting/welding required.
cover, disco, discovery, engine, part, parts
International MWM HS2.8L TGV Engine Michael For Sale - Parts 16 July 16th, 2016 09:19 AM
FS International HS2.8L Michael For Sale - Parts 10 May 15th, 2007 09:17 AM
International HS2.8L Filters DesertRat Defender Technical Discussions 3 August 7th, 2006 11:51 PM
