'97 NRP Cats and Y pipe and 02 sensors - Defender Source
Old July 21st, 2004, 10:22 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Used NRP Y pipe. Comes with all four O2 sensors. Only on the truck for 1.5 years. Only driven a handful of times in the winter. Some dried VA mud on them from MAR. Less than 10K miles.
$350 plus shipping. Located in Maine for local pickup.
Name:	103_0366 (Small).JPG
Old February 11th, 2005, 11:29 PM
Northface
John/Osborne
1993 Defender 110
Do you still have the cats for sell?
Regards,
for sale LOL
Old February 12th, 2005, 07:34 AM
kiphartzell's Avatar
kiphartzell
Kip Hartzell
'95 4.2L NAS D90
David, I am interested in the NRP Y-pipe if it will fit a '95 3.9L. I know the oxygen sensors are different but not sure the Y-pipe is?!? Thanks. khartzel@us.ibm.com
Old February 12th, 2005, 08:20 AM
mattdh's Avatar
mattdh
Matt Hurst
may be a dumb question-but is it the heat that discolors them?they look rusty?stainless steel right?are all stainless exhaust going to loolike that after time?
Old February 12th, 2005, 08:27 AM
No thats what they look like after mud has been burnt onto them. My Borla looks the same.
Old February 12th, 2005, 11:23 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Won't fit a '95. Only the 97 due to the OBD II.
Mike is right. That's some charred VA mud.
Old February 12th, 2005, 02:27 PM
mattdh's Avatar
mattdh
Matt Hurst
david-it wont work with 95-becuase it has two set of o2s? if that is the reason could you just plug the second set of holes?
Old February 13th, 2005, 01:47 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
No, I also meant to say that either the placement of the cats or the flanges don't fit a 3.9. Can't remeber which.
Old February 14th, 2005, 01:19 PM
kiphartzell
Kip Hartzell
'95 4.2L NAS D90
David. I am doing an automatic conversion on my '95 D90 and the '97 Y-pipe should clear the ZF better. The rear oxygen sensor buns can be blocked off. I think the '97 is the same length since they use the same tailpipe as the '95. The cats may be in a slightly different place and I believe the pipe is bent a little different to clear the ZF. With moving to an AT, I would like to make arrangements to get this Y-pipe from you if it is still available. Also, The dry clay mud is not a problem since I will be adding to it (nothing but sticky clay in NC : ) khartzel@us.ibm.com
Old February 14th, 2005, 03:17 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Sent an email.
Old March 11th, 2005, 10:25 AM
kiphartzell
Kip Hartzell
'95 4.2L NAS D90
Hey David, What is the latest on this one? I still would like to work something out since this Y-Pipe should work with my AT swap. Thanks.
97, sensor
