90 Project feeler - Defender Source
Old November 14th, 2008, 12:22 PM
90 Project feeler
Debating which way to go with my project. I'd be willing to sell for exactly what I have in it. Basically it is a complete RHD 90 SW minus the following:
engine
transmission
radiator
*radiator support/slam panel
fan shroud
exhaust
*seats
*steering intermediate shaft (between upper column and box)
*steering wheel
*headlight switch
*ignition switch
*wiper switch
*turn signal switch
It is currently broken down to a rolling chassis with the tub resting in place. Parts are divided between DC and New Jersey.
Chassis condition: Typical rust areas are 90% solid. I have been over every inch of it with a hammer and there were two small soft spots in the underside just in front of the rear axle. Rear cross has been replaced and engine mounts removed.
Bulkhead is solid with perfect footwells and doorposts. Upper corners repaired with new panels but there are 2" long gaps on the top edge where the repair panels did not cover.
Right side (UK driver) door is a replacement and solid. Left side needs help but i have a good shell that can be used to repair it. Rear door is solid. Seatbox is good with surface rust in the battery box.
Rear bed has a 2" x 1" hole in the ledge in front of the bulkhead where the DS seatbelt bracket came off. Horizontal cappings should be replaced or repaired if you have that ability.
I have the missing pieces marked * and can provide them if necessary.
$3500 US. No title just the parts. I've tried to describe all the bad points as best as I can. Let me know what you want to see. This is an easy rebuild I am just looking at other ways to achieve my ends.
Some pics can be found here. more can be provided on request.
http://www.fourfold.org/daveb/ETHAB/
Ren
A few pics
ID:	16378   Click image for larger version
ID:	16380   Click image for larger version
Old November 14th, 2008, 02:27 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
IF someone is interested in your truck, I will have a complete engine with harness, rad, exhaust, etc. available shortly to complete the package. In NJ as well
Legend in My Own Mind.
Old November 14th, 2008, 02:41 PM
Cool, thanks Randy. What type of engine?
FYI this had a 300tdi/R380 installed before I got it. AFAIK was born as a 2.5TD
Old November 14th, 2008, 02:45 PM
*radiator/recored V8 one
*steering wheel
*ignition switch/w key
*wiper switch
I have this stuff
Old November 14th, 2008, 02:54 PM
I'm worried about Ren. He's not acting very Ren like.... I think he lost his Ching.
Old November 14th, 2008, 02:56 PM
his bidding finger is on his mouse and his screen is pointed east
but it's still a circling vulture scenario
maybe I should change it to Cha Ching
Old November 14th, 2008, 04:02 PM
Not unless you are going to make a profit on all that stuff you horded
Old November 15th, 2008, 08:45 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a 3.9 from a 95 d-90 that I will be removing to install a 300tdi soon so it will be up for grabs. So the entire setup is available with engine mounts, etc.. It runs like a champ.
Old January 19th, 2009, 04:02 PM
bump
lots of good stuff here. basically a complete truck minus and engine and trans.
Old January 19th, 2009, 04:28 PM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
was that truck sitting behind ab for a while?
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old January 19th, 2009, 04:32 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'd be interested in the back half of the frame, the tub, and rear axle if anyone wants to part it out with me.
Semper Fi!
Old January 19th, 2009, 08:25 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I don't know why I lust after roll-up doors so much . . .
Old January 19th, 2009, 11:44 PM
yup, that is the one.
tony, with the shell I got from you you could have two very nice doors.
the drivers side has been cahgned already and is in in VGC. passenger side needs your shell to be happy.
jon, pm'ed you back
Old January 19th, 2009, 11:52 PM
Abrooks's Avatar
Abrooks
Tony Brooks
jon, pm'ed you back
As you saw yesterday, I have bigger issues right now. I do wish I could justify this as a project, though, its a hell of a deal.
Old January 20th, 2009, 08:39 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I also have the steering parts to convert that to LHD. That looks like a good starting point for a custom truck.
Old January 20th, 2009, 03:22 PM
Indeed, I was going to build this into a tdi trail rig. have other plans now.
Old January 28th, 2009, 01:28 PM
I'm considering parting this out, let me know if you are looking for anything.
Dave
Old January 30th, 2009, 01:23 PM
That would be a mighty small trailer.
& I have the dash and missing steering column etc
Old January 30th, 2009, 07:08 PM
Wolf Fabrication
Sterling Archer
'08 D3
Very perceptive. I would be making it into something similar to an adventure trailer. Tent on top, storage, drawers, etc. I didn't plan on hauling lumber or cars. Maybe Rover parts though....
Semper Fi!
D90 Project (Feeler) J.5 For Sale - Vehicles 8 February 1st, 2008 11:18 AM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 08:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
90/110 project wanted (NAS or import) mlepisto Wanted 13 June 22nd, 2004 08:56 PM
