(5) Wolf wheels w/265/75/16 tubed KM1s ($650) - Page 2 - Defender Source
Old December 2nd, 2013, 12:41 PM
On the remote chance that someone wants to buy these and separate....I'm looking for 5 Wolf wheels.
Now when you say they are tube-type; do they have to have tubes?
I plan on using Staun internal beadlocks with whatever rims I end up with.
Jeff the difference between tubeless and tubed on these wheels is the size of the valve stem hole and a slightly different shape to the outer lip of the wheel. I have run the tube type wheels- tubeless with zero issues and I aired down to 10 psi with a 130.
Old December 2nd, 2013, 09:00 PM
Rugbier's Avatar
Rugbier
Gustavo
Any chance they can make it their way to MD/DC/NoVA ?
NO SIGNATURE
Old December 2nd, 2013, 09:07 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I would imagine that somebody would be running down there at some point.
Like I said, I could meet somebody closer to the interstate west of Boston if that made RURR easier for somebody.
Also, I'm not in an incredible hurry though I could use the garage space and would like to put the money towards an Alisport full length intercooler.
Try to arrange something over the next month or two.
Old December 4th, 2013, 03:12 PM
Jackie Treehorn
A
1985 (legitimately)
see.....
http://www.defendersource.com/forum/...4&goto=newpost
don't know if he's got the room, but I could meet him somewhere on I-495 on his way from NH.
Old March 11th, 2014, 07:49 PM
Jackie Treehorn
A
1985 (legitimately)
price drop to $600
Pre-Spring bump and price drop to $600
Also, I mistakenly wrote the tread depth as 16ths, instead of 32nds (surprised nobody called me out for that) tread is good though on all tires and no dry rot and are as clean as you see them in the pictures.
Old March 18th, 2014, 06:15 PM
bump for posters looking for wolf wheels
Old March 18th, 2014, 10:54 PM
rtcgb's Avatar
rtcgb
Richard Crouch
61 11a 'Lloyd', 87 130 'Big D',
PM Sent
PM Sent
Old March 19th, 2014, 08:34 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Most tube type rims do not have a safety flange to prevent the bead from moving too far inward on the rim. It has nothing to do with holding in air unless something pushes the bead to the center of the rim. This can happen when you are running low on air pressure, hitting a rock or pot hole hard enough to push the bead. Many people run these rims, with out a problem, while not using tubes. I personally, will not take a chance.
If you choose to run a tube make sure it is a radial tube. There is a difference.
Jeff, if you are planning on running the Stauns I would not see a problem using these wheels. The Stauns will hold the bead in place not allowing it to move to the center of the wheel. (acting like the safety flange, but better) You can get a larger valve stem to go into the hole if it has the larger diameter valve stem hole.
Old March 19th, 2014, 08:38 AM
Abu Buckwheat
Malcolm
2005 Defender 110 TD5 Station
Registered User
PM sent. Next in line.
Old March 19th, 2014, 09:29 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I ended up getting a set of the Wolfs right here in town!
Same kind, tubes, but with Stauns I didnt think I would need to worry.
Rent my
Old March 19th, 2014, 02:04 PM
Jackie Treehorn
A
1985 (legitimately)
Sold pending funds.
Funny how the anticipation of springtime mud re-energized this FS thread!
Old March 24th, 2014, 07:58 PM
Jackie Treehorn
A
1985 (legitimately)
SOLD
Thanks D90 and good to meet you Richard.
wheels, wheel
tubless tires on tubed wheels asurover Defender Technical Discussions 2 February 3rd, 2005 01:30 PM
Want Wolf Wheels wicks Wanted 7 January 14th, 2004 03:56 AM
Wolf wheels kellymoe Misc. Chit-Chat 3 October 18th, 2003 04:16 AM
Wolf wheels kellymoe For Sale - Parts 1 October 17th, 2003 12:35 AM
Got Wolf Wheels? wicks Wanted 0 October 8th, 2003 04:47 PM
