4.6 V Belt engine with tuned ECU - Defender Source
Old March 27th, 2016, 02:15 PM
Abrooks's Avatar
Abrooks
Tony Brooks
This lingering project hasn't advanced in too long.
4.6 long block with v belt front cover
Block is from a P38. PO set it up for his RRC with a crower cam. He got some water through the intake, shut it down, evacuated water from #8 cylinder and drove it several hours afterwards, then pulled it for a cummins swap. Motor is purported to have @110k on it total, 5K with cam. When I got it the compression showed the following:
8--160
6--182
4--192
2--190
7--190
5--185
3--180
1--180
I stripped the heads (finding a slightly loose head bolt between 8 and 6) and found no obvious damage to pistons/rods etc. I had the heads rebuilt (they were filthy), had the intake bead blasted, took an inch off the intake trumpets and installed a new water pump. The liners all appear good with no sign of slipping. The engine is currently disassembled, which seems like a good time to sell it so that the next owner can see the liners, etc.
This includes the distributor, alternator, remote ignition module and all brackets and an OBD1 Computer that has been reflashed for the 4.6. Only thing than needs to be done before assembly is to install the included cruciform seals. Also includes a complete top end gasket kit.
Will drop in to a 94-95 defender, RRC or D1 and will make the loud pedal a lot more exciting. Throw a carb on it and make your ROW V8 seriously fun.
Located in Arlington, VA. Pickup is highly recommended. $3900 or reasonable offer (though it can easily stay in the garage and I can pick away at assembling it).
Happy to answer questions, will post pictures.
Old March 28th, 2016, 12:02 PM
Abrooks's Avatar
Abrooks
Tony Brooks
More coming
Old March 28th, 2016, 01:46 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Intake
Old March 29th, 2016, 09:20 AM
Abrooks's Avatar
Abrooks
Tony Brooks
It appears that I may have been optimistic on price (thanks for the calibration, Ray). Let's say $2750 all in as is where is.
Old March 30th, 2016, 08:53 AM
Abrooks's Avatar
Abrooks
Tony Brooks
PMs returned
Old May 18th, 2016, 08:36 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Bump.
Old May 19th, 2016, 10:03 AM
Abrooks's Avatar
Abrooks
Tony Brooks
$2900
Old June 2nd, 2016, 02:15 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Buyer dropped out. Let's get this gone!
Old June 2nd, 2016, 04:50 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I know a guy (of the grumpy variety) who's V8 in his RRC just died....
1985 Land Rover 110 3-door ST
Old June 3rd, 2016, 08:00 AM
Abrooks's Avatar
Abrooks
Tony Brooks
I believe the LS1 bug bit him.
Old June 4th, 2016, 01:33 PM
Abrooks's Avatar
Abrooks
Tony Brooks
$2800
Old June 8th, 2016, 11:04 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Looks like the house is going on the market and I'd prefer not to move this. $2700/reasonable offers
Old June 8th, 2016, 11:35 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
What's the interest rate on a payment plan???
Old June 8th, 2016, 11:58 AM
Abrooks's Avatar
Abrooks
Tony Brooks
0%!
Can happily work something out in all seriousness.
Old June 8th, 2016, 11:59 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
U staying local?
I can store it under the hood of my 110 :-)
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 8th, 2016, 12:20 PM
Abrooks's Avatar
Abrooks
Tony Brooks
If everything works out we are headed to Waterford.
Old August 23rd, 2016, 03:25 PM
Abrooks's Avatar
Abrooks
Tony Brooks
now includes all the bottom end bearings --$2200.
Old August 24th, 2016, 08:07 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Reasonable offers considered before it gets built up.
Old September 7th, 2016, 09:00 AM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
PM Sent. the want is relatively strong. Why not buy two engines in the same week? it's only money.
'95 RRC CountyLWB - Swapped to a 4.6L, and now working on a 6.0L LQ4
'83 110 HCPU - in "progess"
'90 RRC Truggy - loud and proud, but mostly ugly
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old September 7th, 2016, 11:34 AM
Abrooks's Avatar
Abrooks
Tony Brooks
PM Returned!
ecu, engine
Rear Seat Belt Y-Belt from D1 tebby For Sale - Parts 4 May 27th, 2014 12:42 PM
releasing belt tension on '85 v8 fan belt Chris Velardi Defender Technical Discussions 6 January 13th, 2014 05:18 PM
2 4.2 ECU's 1 3.9 ECU eliaschristeas For Sale - Parts 3 June 19th, 2013 03:15 PM
Head Gasket, Timing Belt, Drive Belt - What else? GreenRover Defender Technical Discussions 5 July 16th, 2010 12:23 PM
Need an ECU... looking for the ECU out of a 95 Disco or equivalent IPSC_GUY Wanted 7 February 16th, 2010 04:36 PM
