4.6 Crank/Pistons, 3.9L and Main Bearings - Defender Source
Old February 9th, 2015, 09:49 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
4.6 Crankshaft and Pistons. Perfect for bumping up the displacement on your 97 4.0L. Crank has been checked and polished. Pistons and con-rods have been jet washed twice.
$650 plus shipping. Should be under $100 to anywhere in the lower 48. Add another $100 for new main and rod bearings, OEM units if you need them.
3.9L Main bearings, 10 over (RTC171810). Good for:1994 D1, 87-94 RRC (3.5/3.9), 1994 D90, 1993 D110. WILL NOT FIT 1995's. Ended up not needing them after test fitting in a block. So they are open box but never used. $50 shipped.
Thanks gents
Name:	4.6 Crankshaft (2).jpg
ID:	113340   Click image for larger version
Name:	4.6 Crankshaft (5).jpg
Old February 9th, 2015, 09:57 PM
UKmtrsp
Chip
95 RR Classic
bottom end parts
pm sent
Old February 11th, 2015, 06:16 AM
pushngo
Randy Williams
Why are the rod caps not with the appropriate rods? You do have them marked?'
Old February 12th, 2015, 02:37 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
They are all marked, you just can't see the markings in the pics. The con-rods will be shipped with their respective caps bolted back to them.
Using a 4.6 crank and con rods with 4.0L pistons cdb Defender Technical Discussions 27 October 19th, 2014 11:30 PM
4.6 crank,rods and pistons 350 mud ruts For Sale - Parts 5 April 4th, 2012 10:21 PM
Wheel Bearings and stub bearings Naplm00 Defender Technical Discussions 9 March 11th, 2011 10:17 PM
4.6L Pistons and rods themaxx Defender Technical Discussions 3 February 21st, 2008 12:57 AM
For Sale - Brake Calipers And Pistons HUMMER80401 For Sale - Parts 6 May 20th, 2006 11:46 AM
