4.2 Hotrod Rover V8 Project Absolutely Must Go - Defender Source
Old March 6th, 2015, 09:24 PM
madcowdungbeetle
Carter
So in what has been a pretty shitty week all around I just got word my shop is being demolished to make room for high-rise luxury apartments and condos. I'm sure you can imagine the joy this brought into my week. So needless to say I'm going to have to pack it up and move shops. To make this as easy as possible I'm going to sell off as many of my spares as I can.
This is the first of many parts and spares to be sold.
4.2/3.9 Engine Block - good condition, grease coated cylinders, ready to go back together, 2 bolt mains
V8 heads, reworked and rebuilt to D&D specs, everything new, grease coated, ready to go
D&D Polished Crank with Matched Bearings, grease coated
NEW set of 8 Pistons .030 w/ NEW rings, and Rods
Powder coated front cover V-belt
Black Powder coated Oil Pan
Red Powder coated Valve Covers
4.2 ECU
Intake Manifold
4.2 Plenum
NEW Timing Gears and Chain
NEW Crower lifters
NEW Vally Pan Gasket
NEW Head Gasket Set
NEW Oil Pump Housing & gears (non-serp)
NEW Seal Kit, Water Pump, Oil Pan, Front Cover, etc....
$1000 obo
ID:	115427   Click image for larger version
ID:	115429   Click image for larger version
ID:	115431   Click image for larger version
ID:	115433   Click image for larger version
ID:	115435   Click image for larger version
Old March 6th, 2015, 09:25 PM
madcowdungbeetle
Carter
More pics
ID:	115437   Click image for larger version
ID:	115439   Click image for larger version
Old March 6th, 2015, 10:07 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Pm sent
Old March 7th, 2015, 11:15 AM
madcowdungbeetle
Carter
In addition to everything listed I will also include:
Spare MAF
Powdercoated black V-belt Ancillary brackets
Powdercoated black V-belt pulleys
Any other spare engine parts I have laying around.
Old March 7th, 2015, 11:20 AM
madcowdungbeetle
Carter
Pics
ID:	115462   Click image for larger version
Old March 8th, 2015, 01:48 PM
madcowdungbeetle
Carter
I am open to offers, but I don't want to part this out, I don't the have time, just come get and as always cash talks.
Old March 8th, 2015, 02:46 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Man wish you where closer I could use the motor .
85 D110 3.5 3 DR
Old March 10th, 2015, 06:42 PM
madcowdungbeetle
Carter
I can ship it! Freight ain't no thing
Old March 11th, 2015, 03:47 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Can you give me a quote to 98390 sumner Washington .
Also what's the deal on the block , is it resleeved to fit the .030 Pistons ?
Thanks Ed
85 D110 3.5 3 DR
Old March 25th, 2015, 12:05 PM
lightwriter's Avatar
lightwriter
Carlos Ascencio
'84 One Ten
Hi, is this still available? Sent PM but no response, is there an email perhaps?
Old March 25th, 2015, 12:35 PM
madcowdungbeetle
Carter
Sorry, I must have missed your PM in the all the craziness the last couple weeks.
The motor is SOLD.
Old April 10th, 2015, 08:18 PM
madcowdungbeetle
Carter
This motor is back up for sale, as I'm helping the buyer sell it as he has found it will not suit his needs.
The fine details:
This is a V-BELT Rover motor, NOT serpentine, and as such is has the short crank shaft snout.
The block is a Range Rover 3.5 block bored over per D&D machine, making it a 4.2
The rockers are machined per D&D Machine spec to use a higher lift Buick cam.
All that this motor needs to be built is a Cam and matched set of lifters.
A new set of lifts is INCLUDED with the motor, just not a cam matched to them. D&D can help you with this.
I am not sure of all of the applications and cross-compatability of these parts so please do your homework, and make sure this will work for you.
This would be IDEAL for an early RRC, Series Rover to RV8 conversion, or an Early 90/110 with the Rover 3.5 motor.
The motor is now located at a very competent engine builder's shop in Allentown, PA who has gone through all of the parts and can give you a full assessment of what is there. If you are interested in this motor I will put you in touch with it's current owner.
Old April 22nd, 2015, 10:59 PM
madcowdungbeetle
Carter
I now have this motor back in Charlotte.
I have several receipts totaling over $800 from D&D included with the engine. In addition I have the PO's information, and Craig at D&D is familiar with this engine and everything that has been done to it, machining, setup, etc... Just add the cam and lifters of your choice, Craig at D&D can walk you through what you need, and you will have a serious Rover motor.
If you're wanting to put some ass into your Early RRC or Defender for not a lot of money, this is a great engine.
Now because this is a project engine, it is sold AS IS so ask all the questions you want to.
$1000
Old June 18th, 2015, 05:59 PM
lightwriter
Carlos Ascencio
'84 One Ten
Still available?
Any chance you still have this? Let me know.
Old June 18th, 2015, 06:03 PM
madcowdungbeetle
Carter
Sorry it's long gone.
Old June 19th, 2015, 02:19 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
If whomever bought this needs a buick cam let me know. I have two out of buick 340's.
v8
Hotrod style gearstick. Cube II Smaller Projects 13 March 6th, 2013 03:48 PM
absolutely incredible, AOL subscriber numbers hillstrubl Misc. Chit-Chat 2 January 24th, 2011 02:52 PM
absolutely dead this morning... snosrfr Defender Technical Discussions 4 February 28th, 2010 06:06 PM
An absolutely marvelous way to waste a little time d90-110 Misc. Chit-Chat 5 October 29th, 2008 12:07 PM
absolutely hammered Mike Hippert Misc. Chit-Chat 5 October 19th, 2004 12:03 PM
