4.11 third member open carrier - Defender Source
Old November 29th, 2009, 10:01 PM
abraded
Shams Helminski
'71 IIa Hybridized
Hi,
Changed ratios around and I have a left over third. Came out of a front axle, unkown mileage 4.11 gears on a stock rover open carrier. The bad is that two of the bolts holding the crownwheel to the carrier had loosened and backed out. So, one of the holes in the carrier that the bolt goes through got a little marred up. The threads in the crownwheel are still fine. I replaced the two bolts and it's all in one piece. There is no obvious damage to the surface of the crownwheel or pinion. Given all that I would be most comfortable keeping this as a trail spare for someone with 4.1 gears. Just a cheap stopgap if needed.
$225 plus shipping.
Let me know if you have any other questions. Thanks.
--Shams
ps. also have a pair of rear tail lights for a non NAS defender. Plugs are for for three wire, S/T/T. Red lenses. $15 for the pair.
ID:	23292   Click image for larger version
ID:	23294   Click image for larger version
Old March 25th, 2010, 05:34 PM
abraded
Shams Helminski
'71 IIa Hybridized
Still available.
--Shams Helminski
Old May 20th, 2010, 08:34 AM
abraded
Shams Helminski
'71 IIa Hybridized
bump
Old June 4th, 2010, 11:26 AM
abraded
Shams Helminski
'71 IIa Hybridized
sold. thanks.
--S
carrier
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
4.11 3rd member Anyone? TDI Guy Defender Technical Discussions 6 March 3rd, 2008 07:49 AM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
