300tdi Full Setup True Defender 46K Miles $7000 - Defender Source
Old January 26th, 2011, 10:31 AM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
Selling my 300tdi conversion setup. Kit includes everything you will need to the swap including
-1995 16L Non EGR 300tdi with 46k miles
-Matching R380 with 1.2 T-Case
-Radiator and intercooler including frame and all tubes
-Fuel filter holder and plastic fuel lines
-All wiring/relays etc.
-All motor mounts, frame mounts as well as trans crossmember
-Air filter box including tubes
-Exhaust downpipe
-Engine Sound Cover
When the engine was being loaded the oil pan got a dent in the middle. You will need to either take this one off and bang the dent out or get a new pan.
The parts below also go with the deal. The new rear main seal and gasket are already installed on the motor as well as the new clutch disc and pressure plate.
Oil filter - genuine ERR3340G
Fuel filter element and seal AEU2147L
Timing Belt Kit TIMINGKIT300E
AP Driveline (formerly Borg and Beck) Clutch Kit (plate, cover and release bearing) STC8358
Crankshaft rear oil seal - OE Manufacturer LUF100430G
Crankshaft rear oil seal gasket ERR6811
Water pump and gasket - OE supplier - 300TDI STC1086G
Price is $7000
Old January 26th, 2011, 10:49 AM
mattarm's Avatar
mattarm
Matt
1993 D110
Interested PM sent
Old January 26th, 2011, 10:54 AM
grbec22's Avatar
grbec22
Roger Ramjet
1985 "90" no defender's back then.
Am I reading that right as it is a non computer engine?
Old January 26th, 2011, 10:58 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
All the 300 Tdi's were manual injection, no computer to my knowledge.
The "no EGR" refers to the Exhaust Gas Recirculation, a system that burns off a small amount of Nitrogen Oxide by piping exhaust back in to the intake to be used as air for the engine again. Of course, it also has much less oxygen at than point, which means less "bang". It's common practice to disable that system for more HP.
Old January 26th, 2011, 01:02 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Unfortunatly this is incorrect. There were fly by wire 300 tdi's in Automatic transmission equipped Land Rover Discovery. It is important to determine if engines have the manual pump before purchase. Because purchasing the needed parts to return back to manual operation can be very costly.
legend in my own mind
Old January 26th, 2011, 01:20 PM
bitz's Avatar
bitz
Jon
Thanks for all of your input guys. Just to clarify for any potential buyers this motor is fully mechanical, non drive by wire, and non egr. The best of the best in my opinion.
Old January 26th, 2011, 01:54 PM
what Jim said....
Old January 27th, 2011, 05:19 AM
rovertrader's Avatar
rovertrader
Dale
what Doug said Jim said... good luck Jon, did the 110 sell?
Old January 27th, 2011, 10:00 AM
bitz's Avatar
bitz
Jon
Thanks Dale. Yeah she's gone. It was a sad day. Sorry the 300GD didn't work out.
Old January 27th, 2011, 10:26 AM
navydevildoc
Neill Thornton
Thanks guys... learn something new every day!
Old January 27th, 2011, 11:14 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Thats the joy this place can bring
Old January 27th, 2011, 11:29 AM
navydevildoc
Neill Thornton
I am just wondering why they did it at all... I mean if it's not broke, don't fix it kind of mentality. Was there a problem with the 300 Tdi Injector pumps?
Old January 27th, 2011, 11:43 AM
pendy's Avatar
pendy
jim pendleton
89'd90
It was a performance thing to match the 300tdi to an automatic transmission. If I remember right the stock power output was a little bit higher and the power curve changed as well. Injection pump is very similar to the ones used on VW jettas sold here, 2001 for instance. A lot of sensors and injection hardware/software to support the diesel fuel injection. As complicated, or more then V8 fuel injection. Also fly by wire fuel pedal.
More joy?
Old January 28th, 2011, 02:43 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
I know this wouldn't be my ideal setup. As I would rather have an all mechanical setup... But does this mean there is an ECU/OBDII 300Tdi configuration, that I could horse shoes in my 97 and still be able to register in California???
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old January 28th, 2011, 03:00 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I could be wrong, but if you do a diesel swap in CA doesn't the engine need to be newer than the original, and EPA certified?
Old January 28th, 2011, 07:39 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Jim, I think they also had a few Defender, very few, Automatics with the 300 Tdi. I remember reading that they had to modify the injection pump to put out a little more HP to compensate for the Automatic robbing some power. I have one of the engines not that it is any different than a regular one. The engine had been rebuilt and a manual injection pump fitted.
------ Follow up post added January 28th, 2011 07:40 PM ------
Oh, forgot..the EGR trucks do have a computer, for the EGR that is.
Land Rover 110
Old January 30th, 2011, 03:16 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
More joy?
Yeah it is very similar cause i remember seeing someone use the Injector pump off a 300tdi on a VW ALH engine to make it manual injection cause they were running it in a 80's rabbit to rally it.
Old February 3rd, 2011, 02:23 AM
manchester
sloan
1994 D90 ST and 1997 D90 ST
Interested and I Pmd you...
Old February 5th, 2011, 07:57 PM
bitz's Avatar
bitz
Jon
I promised this to a gent that was very interested but after a week with no deposit I'm putting it back on the market. Let me know if you are interested.
Old February 6th, 2011, 12:09 AM
manchester
sloan
Motor and Trans
Pmd you again!
300tdi, tdi
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
defender full roll cage for sale soon. mountainviewrover For Sale - Parts 5 January 22nd, 2007 02:26 PM
1999 Defender 110 300TDi Best Offer Frankie Carbone For Sale - Vehicles 10 December 9th, 2006 02:09 PM
1995 Yellow Defender 81k Miles for Under $24k gamberik For Sale - Vehicles 9 December 3rd, 2005 09:47 AM
94 defender 90 w/ 27k miles ebanks For Sale - Vehicles 5 September 8th, 2004 01:05 PM
