300 TDi EVO kits, Group buy. - Page 6 - Defender Source
Old February 10th, 2013, 08:39 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Auber ordered! I got the 1/8" sender as well.
Old February 14th, 2013, 12:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
1/4" VDO NPTF sender up top. 1/8" Auber NPT sender at the bottom. Another benefit of the smaller Auber sender is that it is bent so it is less likely to interfere with hoses or manifold. The Auber sender also has a longer braided metal wire.
Old February 14th, 2013, 03:43 PM
Originally Posted by Manimal View Post
Either way I'm going to order the 1/8" fitting just to be sure. I'll probably end up ordering the Auber EGT meter + 1/8" Probe. At 24x48MM its actually quite small. I like the alarm feature as well. Thanks!
If you like the alarm, they sell a nice buzzer/light combination. If you have a good place for it, they work well. I have one for EGT and another for coolant temperature.
http://www.auberins.com/index.php?ma...roducts_id=218
Old February 14th, 2013, 05:38 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Great! Where did you install the coolant sender and which sender/kit did you get to monitor coolant temp? Do you have alarm only or a digital monitor for coolant also?
Old February 14th, 2013, 08:56 PM
I got a VDO sender that included a high temperature switch.
Old February 15th, 2013, 10:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
John, what is your alarm temp set to on your coolant and EGT alarm?
Old February 15th, 2013, 10:32 PM
I think the VDO sender alarm is 210 F. I try to keep the egts below 700C so keep the alarm at 680.
Old February 15th, 2013, 10:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks!
Old February 24th, 2013, 09:10 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm ready to install the kit today.
Question: should I use any Loc-tite (or similar) on any of the studs or bolts? How about the studs that holds the manifold to the engine? Or the bolts that holds the turbo to the manifold? The kit came with a mystery syringe of liquid but nowhere in the instructions does it say what it's for. Is this loc-tite for the turbo/manifold? Does loc-tite even work on parts that get hot?
Old February 24th, 2013, 09:32 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Also calls for priming the turbo once installed. How is that done?
Old February 24th, 2013, 10:26 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Don't know what the mystery fluid is, but I know Loctite Blue is good up to 300 degrees. Don't know about Loctite's other stuff.
Old February 24th, 2013, 12:13 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
This came in the Turbo box. Any idea what it's for?
Old February 24th, 2013, 01:00 PM
tpond
Toby Pond
110
I would take a bet that the syringe is a shot of lube for priming the Turbo.
Old February 28th, 2013, 01:46 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Michele,
How long is the replacement silicone hose you ordered? I also noticed that the one that ships with the kit is the wrong diameter. The shipping list specifies 2 1/3"ID x 2 1/8" long hose. The actual ID 3.2". That makes for a pretty sloppy fit.
Old February 28th, 2013, 02:19 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Forget that.
70x150mm is what I went for.
I didn't trim mine, simply stuffed the pipes up to it to the point that even if the hose clamp fails, it won't move...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 28th, 2013, 02:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thank you. Ordering a new one today.
Old April 26th, 2013, 03:05 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Manimal,
Did you get your kit & where are you in the installation process ?
By the way, is M&D's price of 1295 still current & how much was YOUR freight ?
Old April 27th, 2013, 01:18 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Hi Dennis.
Its up and running! You can check out the install here. I bought my kit from Keith @ Rovertracks so it was already here in the US. If you are seriously considering I would look at the Allard kits.
Originally Posted by Dennis View Post
Manimal,
Old April 27th, 2013, 01:21 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
John. Just looked at this again and I am reading this right? You set your alarm to 210F/99C?
Is the 680 temp you refer to C or F?
Which one is it?
Old April 27th, 2013, 08:04 AM
Carl- pretty sure he meant 1210 f.
300 tdi, kit, tdi
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
SS KITS group buy Sam_rover For Sale - Parts 13 January 23rd, 2006 10:34 PM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
