3.9L with blown head gasket F/S - Defender Source
Old June 28th, 2010, 09:13 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
When my 3.9L blew the passenger-side head gasket I decided to convert to diesel. I wanted a diesel anyway and I'm not putting another dime into the gas hog motor.
About the motor:
- ~ 10K miles on a rebuild
-new cam, lifters, fuel injectors, rebuild heads (one is good, one w/ blown gasket - who knows. I looked for visible cracks but it appears to just be coming from the head gasket - see photos).
-stupid expensive nearly new bosch platinum quad plugs
-new cap and plug wires
-new TPS
-ran and idled smooth until the gasket blew
-the guy who rebuilt it used metal gaskets - possibly the reason it blew?
-including power steering pump and A/C compressor/bracket, all pulleys, air flow sensor
-exhaust manifolds included
I will consider separating it for parts. Maybe all it needs is a fresh set of composite gaskets, or maybe the head is messed up and it needs more internal work. I drove it to the place where I pulled it out and dropped in the diesel. Oil pressure was normal and there's no knock or rough noise aside from the misfiring due to loss of compression through the head gasket.
Make an offer if interested. Will not include the alternator or starter.
ID:	28895   Click image for larger version
ID:	28897   Click image for larger version
Old June 29th, 2010, 04:12 PM
grnthng's Avatar
grnthng
Luis A. Costa
'93 Range Rover County LWB
That might be why you blew the head gasket on a rebuild... when you used those plugs, they get the heads to hot..... you got to go with copper dude!
Old June 29th, 2010, 06:20 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I have never seen one truly run/idle well with those plugs even.
Old July 19th, 2010, 03:47 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Well, I don't know about the plugs... the motor ran very smooth until the blow gasket. I think the problem was that the guy who rebuilt it used the tin head gaskets and not the composite... but at this point I'm not worried anymore, my 300TDI is installed...
Anyway, it was running great right until it wasn't. Now that I'm converting to diesel this is just taking up space. Anyone want some good parts? At least one good head, injectors, etc. Heck the injectors cost me $400. I'll take $300 to get it out of my way.
Old July 21st, 2010, 09:49 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
Sent a pm
gas
Place your bets, Blown head gasket, or cracked manifold? Hans Defender Technical Discussions 12 March 20th, 2008 08:02 PM
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
