3.54 Diff Rebuild Kit, NEW bearings/seals, 2 R&P's, Housing, Carrier, etc - Defender Source
Old June 24th, 2016, 12:45 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
I was getting set to rebuild this diff but ended up not needing it. The original pinion is shot. I have a second R&P out of a low mileage diff in excellent shape.
NEW PARTS: (Were $211.70)
FTC5258: Oil seal
539706: Inner pinion bearing
539707: Pinion flange bearing
RTC2726: Carrier bearing
FRC8220: Pinion seal
USED PARTS: (Everything has been hot tanked already)
Original R&P (pinion is the threaded-female end type)
Low mileage virgin R&P (pinion is the threaded-male end type)
Diff housing, carrier, flange, etc
This was a rear diff and is interchangeable with the front. If you want to debate the directional wear of the R&P then create a new thread. Compatible with RRC and Disco 1 as well.
$200 for everything plus shipping. Any used components that you don't need I can put back on the shelf to save the buyer on shipping and discount the parts accordingly. I won't break up the new parts, that's a package. Really just trying to get my cost on the new parts back and hopefully help someone out.
ID:	152505   Click image for larger version
carrier, kit, rebuild, seals
Pair of new ARB RD128 lockers with bearings, etc. 1953lr80 For Sale - Parts 3 June 12th, 2013 09:42 PM
New parts - Rotors, pads, links, bearings, etc.. pmd For Sale - Parts 12 March 13th, 2012 12:19 PM
Wheel Bearings and stub bearings Naplm00 Defender Technical Discussions 9 March 11th, 2011 10:17 PM
diff carrier bearings-school me Uncle Douglas Defender Technical Discussions 3 August 31st, 2010 11:25 PM
wheel bearings and seals Uncle Douglas Defender Technical Discussions 8 August 20th, 2010 08:18 PM
