24 spline conversion bearings for Series Housings - Defender Source
Old August 28th, 2007, 04:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
24 spline carrier conversion bearing sets for converting a series 3rd member to the later 24 spline HD d-90 style carriers or lockers. 4 all together to do the front and rear. $50 plus shipping
Legend in My Own Mind.
Old August 28th, 2007, 05:45 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Randy, to translate.. will this allow me to use my stock D90 diffs, in a Series? I may want them if so.
Chris von C
[/size]
Old August 28th, 2007, 06:11 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
It will let you install a 24 spline d-90, disco or rangie diff carrier or locker into your series 3rd member. You would then be able to run a set of HD 24 spline shafts like a set of Rover Tracks half shafts in the rear and so on up front..
Your series carrier right now is 10 spline and weak along with the rear shafts.
Old August 28th, 2007, 06:27 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Well I have a bunch of stock diffs hanging around, so it sounds like I could use these. I think I will take them.
Can you run stock 90 front and rear half shafts on the Series axles?
If running the diff from a D90 up front, I am assuming this will do away with needing the locking hubs?
Chris von C
[/size]
Old August 29th, 2007, 10:49 AM
chris-
you do not need locking hubs on a series front axle. they are optional.
Old August 29th, 2007, 01:12 PM
Chris, if you want to run D90 differentials in a series you need to:
1. Find 10 spline carriers (1987-mid1993 Range Rover diffs, 1993 110 front diff)
2. Bolt them in (sometimes there is a locating pin in the way but otherwise they just bolt up. In the rear you need to add a fill plug to the diff housing or fill through the breather hole).
10 spline REARS suck in series trucks. Fronts are fine. In reality, the rears are fine as long as you carry a spare set (all series rover guys do this). GBR had some Heavy Duty 10 spline rear axles for series that work fine. 24 spline is the way to go for 35in tires or rocks when locked but the series has so little power the 10 splines break from fatigue not stress/shock load.
What Randy has will allow you to run the series 4.7 gears and carrier with 24 spline axles. This is great if you want to keep 4.7 gears. You could accomplish the same with a stock D90 carrier and a spacer ring (this is what I did).
PS the D-90 inner shafts are too long to run in a series housing.
PPS Tell us what you are trying to do and I can tell you how to go about it.
PPPS Randy, sorry to polute your sale ad with text. I am sure someone who want to run 24 splines with stock series diffs will snap these up.
Old August 29th, 2007, 02:09 PM
chrisvonc's Avatar
chrisvonc
Chris von C
I was really asking in case I need to replace the diffs in the Series. I havent gotten that far with it to even know whats going on there, but I have 2 stock rear diffs (1 from my 94 D90 and another from my 99 D1) and 1 front stock diff from the same Disco. If I needed to replace the ones in the Series and could use the ones I have sitting around, then thats less money I dont have to spend. Seemed like if I could do it, or have it as a "just in case" option, then it might be worth picking them up. But if I read it correctly, if i did that, I would need to buy after market shafts. Seems like maybe too much effort for a street runner and maybe bunny dealer runs.
Dave, mine currently has the locking hubs which is why I asked if I would need them still if going to the newer set up.
So many questions... I wonder if its time for a devoted Series section here.
Chris von C
[/size]
Old August 29th, 2007, 06:50 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
You would need a set of 24 spline series shafts for the rear. Someone like Rover tracks would make them. same as the front.. You can run either the stock 4.7 geras with this or a set of d-90 3.54 gears but they are kind of tall for a series. THese bearings basically conver the series (imperical) housing to a late model (metric) housing like in a d-90 or disco or raingie..
conversion, series
New GBR Heavy Duty CV's (24 Spline) dmarchand For Sale - Parts 4 September 24th, 2009 07:13 PM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
Stock 24 Spline Diffs willtillery For Sale - Parts 0 September 6th, 2004 09:21 PM
TruTrac, 24 Spline Shafts, CVs mudrover For Sale - Parts 6 June 15th, 2004 05:29 PM
