200tdi with mated lt77 - Defender Source
Old December 18th, 2013, 11:40 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
For sale in located in upstate New York. Both were in fine working condition when I removed them from the vehicle. I can have them delivered on the east coast just about anywhere for a pretty cheap rate. Asking $4000 for the whole caboodle. Thanks
Old December 19th, 2013, 01:21 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Looks like a Disco 200tdi to me.
Old December 20th, 2013, 07:32 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
Could be I'm just regurgitating what I was told how can I tell the difference
Old December 20th, 2013, 09:06 PM
tpond
Toby Pond
110
#1 super easy way: 300TDI = Multi rib v-belt (serpentine) to run the accessories. 200TDI = Conventional V-belts.
Old December 20th, 2013, 09:08 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
then I shall check, thanks.
Old December 20th, 2013, 11:26 PM
correct and the trans is a discovery one that doesn't work in a defender- the shifter would come up through the seat box. Also notice how short the shift lever is. This would be great for someone with a 94/95 disco looking to go tdi.
Old December 21st, 2013, 08:27 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I would have one of the administrators switch the title to 200TDI with LT77.
It is hard to tell from the pictures, but it looks to me like the LT77 is a short belhousing defender model, but could be wrong because the pictures come up smallish on our ToughBook.
RDavisinVA
Old December 21st, 2013, 08:44 AM
Roving Beetle
Doug
I don't think so.... the bellhousing is short and the shifter is fwd of the transfer case lever. It certainly wouldn't fit into a disco. That's a Defender set up I think.
Anyway - nice set.
Doug
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old December 21st, 2013, 08:46 AM
looked @ it again- you guys are right the front nub is where the defender removable shift attaches. Disco engine with defender box.
Great setup-especially if the trans is an s suffix.
Old December 21st, 2013, 10:47 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I think it's a r380 stumpy.
Old December 21st, 2013, 12:19 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It looks like an LT77 not an R380
Am no expert, but...
The rear shaft has a threaded end that I have only seen on LT77s.
All the stumpy R380s have a main shaft without the threaded portion at the very end that I have seen.
Am installing a Stumpy R380 today... finally.
RDavisinVA
Old December 21st, 2013, 03:00 PM
solarguy's Avatar
solarguy
Abraham Bell
I didn't have the transmission in front of me but I would bet on you being right Robert
Old January 20th, 2014, 07:27 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
It is a 200tdi but it's definately an lt77 and to a defender as stated that's what it was in until I removed it. If an admin could change the thread to be 200tdi with mated lt77 that'd be great and open I'll drop the price $1000
------ Follow up post added January 20th, 2014 07:27 PM ------
So $3000 is new asking just to be clear
Old January 22nd, 2014, 12:09 PM
kzack's Avatar
kzack
Keith Zack
none
I might have an opportunity at a 95 disco with factory V8 and R380. Just for curiosity sake, am I correct in the following ...
The LT77 could not be used in the disco
The original R380 could not be used with this engine
The original air conditioning compressor could not be used with this engine
Thanks for any advice. And sorry for being too lazy to search these points.
Keith
Drive the Best - Drive a Hammond
Old January 22nd, 2014, 12:48 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
PM sent.
Old January 22nd, 2014, 01:02 PM
I changed the title. With all the fun confusion, I would suggest posting a photo of the serial numbers. with the gearbox especially, it affects value and application. There are different strengths and gear ratios depending on serial.
I assume this was in a RHD truck? Not sure it will fit LHD.
Old January 22nd, 2014, 02:32 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Cats out of the bag... Keith some answers
Keith
Keith:
You asked:
The LT77 could not be used in the disco? ~Correct not without a lot of changes that are not easy (long belhousing and Disco RR shifter swap.~
The original R380 could not be used with this engine. ~Correct, but I am working on a conversion kit to mate the 300TDI engine up to the Disco manual V8.
Will also use the large hydraulic filled Mercedes motor mounts for this conversion which will be prototyped this summer.~
The original air conditioning compressor could not be used with this engine. ~Not unless you have the correct adapter.~
RDavisinVA
Old January 22nd, 2014, 03:15 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
Spoken for, thanks guys
Old January 30th, 2014, 09:56 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
If not sold I am interested. If so let me know if you can find another one for that price. Thank you
Old February 13th, 2014, 12:20 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
It's sold being picked up tomorrow I'll let you know
Defender 200tdi and 300tdi engine kits w/ LT77 or R380 ZombieMotors For Sale - Parts 0 September 10th, 2013 03:42 PM
200tdi / LT77 clutch issue kjva Defender Technical Discussions 11 May 29th, 2012 10:41 PM
bolting 200Tdi to LT77 question Gkase Defender Technical Discussions 9 September 12th, 2009 12:23 AM
LT77 & LT230 from 200TDI ajh For Sale - Parts 5 July 23rd, 2009 01:44 PM
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
