200tdi engine kit with everything to convert from auto to manual gearbox - Defender Source
Old February 28th, 2013, 11:11 AM
ZombieMotors
Zak Mosieur
1987 Defender 110/300tdi
I just received two excellent-running 200tdi engine kits this week, and can sell one at this time. Engine has just over 120K miles on it, and comes with a healthy LT77 gearbox and LT230 transfer case. Kit comes with everything you may need for a diesel conversion, and everything you would need to go from automatic to manual transmission as well. I also have one complete 300tdi auto kit here too if anyone is interested in staying automatic. The kits come with engine and all ancillaries still bolted on, radiator/ intercooler/ rad frame, air and diesel filters and under-hood fuel lines, engine harness, exhaust down pipe from the turbo, motor mounts in place, gearbox, transfer case, shift 'sticks' knobs&boots, pedal box assembly with clutch pedal, rear crossmember, tdi set of clocks (instruments) so you can make a working tachometer with this setup - All for $4700 , and these are here ready to ship or pick up in person. I also have extra parts for these engines like injector pump, cylinder heads, injectors, and new parts like timing belt kits/ filters/ accessory belts/ motor mounts/ gaskets/ etc. Message me if you have any questions, and you can follow my diesel conversion projects and new vehicle arrivals here : http://laughsandlashings.blogspot.com/ Thanks 503-505-7113
ID:	67136   Click image for larger version
ID:	67138   Click image for larger version
200tdi, engine, kit, manual, tdi
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
1991 RHD - Defender 90 Station Wagon - 200tdi AUTO - CDN$18,000 globallandrovers The Vendors Loft 0 March 4th, 2009 08:39 PM
engine oil chart from owners manual Eric_S Defender Technical Discussions 3 November 21st, 2003 10:40 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
Why can't I disconect the engine from the trany? kit Defender Technical Discussions 6 October 22nd, 2003 07:40 PM
