2 front seat heated seat kit with all wiring $70 shipped - Defender Source
Old August 9th, 2014, 02:20 PM
Ben01
Ben
Defender
Purchased about a year ago, I never ordered the seat covers and just don't need this kit.
What is nice about this kit in particular is it has one switch with dual temperature control, so you only need to make one hole! The switch looks stock.
This is comparable to the exmoor kit and a friend installed this same kit and it came out great. I'm trying to get photos of how he mounted the switch in the cubby.
I paid about $100, asking for $70 shipped. pm me and post here if you want it.
Dual Temperature Control System
Electronic thermostat (built into each pad) regulates the electricity / temperature circulating within the carbon fiber seat heating pad. This system regulates the flow of power and maintains a narrower temperature range whether in a high or low setting. Example: The high setting will have a constant range between 120F to 125F. The low setting ranges between 110F to 115F. These respective temperatures are maintained at these respective levels.
Backrest & Seat Bottom Heating Pads -- 11" x 18"
Pads are approximately 1/32" thick. Either pad can be installed in back or bottom.
Length can be trimmed to any size
The switch dimensions are 1 1/18 inch wide x 1 3/4 inch tall x 1 7/8 inch deep
Electrical Specs
Wattage: 24~36 Watts per Pad, 48~60 Watts per seat
Current Draw: 3 Amps on Low Heat Setting and 5 Amps on High Setting per Seat.
It is a 12 V system.
Old August 9th, 2014, 02:24 PM
i'll take it.
sending pm
PM sent
Paypal sent, thanks!
kit, wiring
Heated Windscreen Kit Mike M The Vendors Loft 8 April 8th, 2013 08:43 PM
Wiring heated seats Campbell Defender Technical Discussions 1 October 19th, 2009 10:45 AM
Exmoor heated seat wiring diagram? dmarchand Misc. Chit-Chat 4 January 25th, 2009 01:46 PM
Heated Windscreen Wiring TDI Guy Defender Technical Discussions 4 August 30th, 2005 12:00 PM
Heated Mirror Kit...never installed P1CR For Sale - Parts 0 July 8th, 2004 04:13 PM
