2.5TD Running Engine Interest - Defender Source
Old July 31st, 2016, 08:29 AM
richord
Richard Ordowich
1987/D90
I am about to pull my 2.5TD engine and replace it with a 200Tdi.
This engine has about 100K miles on it but suffers from the pressure build up that causes oil leaks. It runs great and pulls fine and smokes a little when I start it but not after a minute or so. It does not consume a lot of oil but drips some oil when I park it.
It has:
1. New timing belt and idlers.
2. New water pump
3. New glow plugs
4. New boost diaphragm
I can video it starting and running if there is any interest.
Not sure if there is any interest or what the price would be. Also maybe the parts are worth more than the whole engine. The turbo works fine, injector pump as well.
Any suggestions?
"Slow down and smell the diesel"
Old July 31st, 2016, 01:33 PM
heatxcape
Matt Hete
1971 Land Rover IIa newbie
2.5 Engine
PM Sent to you on the 2.5
Old July 31st, 2016, 01:54 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Do a compression test before you pull the motor - will help with your sales price if you have strong and consistent compression with little blow-by.
Old July 31st, 2016, 04:30 PM
richord
Richard Ordowich
1987/D90
Good idea. I will do another compression test. I did one last year and they were good.
engine
2.5TD Turbo / 2.5TD Air Box and Bracket LakeLBJ For Sale - Parts 1 May 20th, 2016 10:05 PM
2.5TD engine with parts TDI Guy For Sale - Parts 1 March 29th, 2015 12:42 PM
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 06:16 PM
Engine oil leak 2.5TD richord Defender Technical Discussions 4 July 26th, 2014 01:32 PM
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
