2.5TD 90k miles - Defender Source
Old May 15th, 2012, 12:06 AM
bossman429's Avatar
bossman429
Adrian
1988 90
2.5TD 90k miles
Vid attached - narrating sucks...too bad
I'm in the process of pulling this motor, but figured i'd get this posted ASAP since I dont want it sitting in my garage. This is of course assuming my 200tdi works and I dont have to drop this 2.5td back in lol!
2.5TD w/90k miles on it according to the odometer. I have no reason to beleive this is not accurate.
Engine runs great. No smoke (aside from a little during a cold start but it goes away in seconds). Summer months I give it a second or none of glow plugs and it fires right up. 40-60 degrees i'd give it 5 seconds 0-30 degree a good 20 seconds. Its never failed to start for me. On a cold cold day it will run a little rough for a few seconds but smooths right out after you tap the throttle once. I really have no issues with this motor (makes me question why i'm doing this swap)
The previous owner thought it had a bad case of blow by bc he was getting oil in the airfilter. Well I put a catch can between the breather valve and the air box (why it was routed before the airbox and not after it was beyond me), and in 3k miles I've captured all of 1.5.-2.0 oz of oil and no other issues, airfilter has stayed dry. I dont see this being really abnormal at all, especially for an older turbo diesel motor. All motors have some crank case pressure, thats why they have breather valves in the first place!
For those that were at ROMP and others that know this truck, they can attest it runs fine. Not a lot of power but heck its a good engine for a good price. Comes with all the ancillaries unless i find something that doesn't work on my 200tdi once I drop it in.
I'm swapping b/c I got a great deal on a 200tdi rebuild, and would like a little more power, and have plans to take this on some long trips. not that this motor couldn't do it, but i'd just rather have a tdi for obvious reasons.
Hows a cool $1000 sound? I can help with delivery within a decent distance (say a few hundred miles of NJ?)
Old May 17th, 2012, 07:34 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I love the Defender bonnet. Always sounds like someone dropped something in a tin bucket when they open lol.
Not sure why but I might be interested in this one. Did you see anything at my shop that would be an interesting part trade?
Matt Browne
Old May 17th, 2012, 02:04 PM
Roving Beetle
Doug
So the motor is a '88 with the bigger / better bearings and pistons etc?
Anyone headed to coastal Maine with an empty boot/pickup?
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old May 17th, 2012, 09:44 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Off the top of my head I can't remember much. You happen to have any gutter mount roof racks laying around?
Doug - I do beleive it is the "later" 2.5 TD, Still not the best enginer LR made, but slightly better than the earlier 2.5TD's
Old May 19th, 2012, 07:07 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Haha.......that shop does the same thing to me.....walk in and suddenly I can't remember much.....
I have a Brownchurch Galvy rack that was on a 90 but is currently sitting on an SIII. You parked next to it lol.
Matt Browne
Old May 25th, 2012, 09:14 AM
bossman429's Avatar
bossman429
Adrian
1988 90
A little update on this now that my swap is just about complete
Heres what it comes with:
Engine w/ all front accessories and turbo
Fan shroud, Radiator, Air Box assembly and filter, fuel line from lift pump to filter, and injection pump to return (all fuel lines that are part of the engine itself (from injection pump to injectors etc ARE obviously included)
Heres what it doesn't come with:
Dipstick (needed it for the 200tdi)
Had to steal 2 or 3 studs for the bellhousing that were bent on my 200tdi
Stole 1 copper washer from a fuel line fitting...
Viscous fan
All in all I'd say its pretty complete. Could use a bit of degreasing and power washing but the important stuff is all good
Hope to get this out of the garage ASAP......
Old May 25th, 2012, 09:26 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Looking to sell that car trailer?
Old May 25th, 2012, 09:35 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Haha nope.... infact gonna load the car up tonight got races this weekend!
Old May 25th, 2012, 08:01 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Ok update - airfilter housing not included, as I re-used it. But I have a brand new 200tdi filter and a used filter housing I can give instead, I'm sure it can be made to fit without much hassle
Old May 26th, 2012, 06:39 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Hey, gimme a shout (I lost, or didn't grab, your #)
207 450 2187
Matt Browne
Old May 30th, 2012, 10:11 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Matt, left you a VM the other day, just sent you a PM again
If Matt doesn't want this - its last shot for D-90 guys before it goes on EBAY.
I'll do $750 delivered within 200miles on 07701. Want this out of the garage so I can start building my roof rack (need some room!)
Old May 30th, 2012, 10:23 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
god, if only i still had my 90 this is what i was looking for. by the way Adrian, if you need any help with building a roof rack let me know, i have built quite a few of them!
Old May 31st, 2012, 08:17 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Thanks Dylan,
I'm just making up the gutter mounts now. My goal is to make it as minimal as possible. No basket, flat roof. We'll see how it goes!
Old June 3rd, 2012, 05:38 PM
bossman429's Avatar
bossman429
Adrian
1988 90
On ebay - http://www.ebay.com/itm/270990992630...witem=&vxp=mtr
Old June 3rd, 2012, 05:50 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
damn boat! hope you get that buy it now price!!!
Old January 6th, 2013, 02:57 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Fan Shroud from 2.5 td
Adrian-
Do you still have fan shroud from the motor? If so, would you want to sell it separate from motor? If so, could you send pix? Is this the same as 200 tdi shroud?
Old January 6th, 2013, 08:25 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Sorry that is sold. It's not the same as a 200tdi fan shroud.
Old January 8th, 2013, 07:42 PM
Trooper90
John Capps
1986 ninety
Is the engine still available?
Old January 8th, 2013, 09:04 PM
bossman429's Avatar
bossman429
Adrian
1988 90
No sorry. All is sold
90, d 90
1995 3.9L Defender 90 Engine 90K miles Heath For Sale - Parts 0 September 21st, 2008 11:28 PM
Odometer reads 76% actual miles stevewhitaker Defender Technical Discussions 4 January 21st, 2006 06:07 PM
defender soft top, high miles, trade wrangler ? cafemosaic Wanted 0 December 4th, 2005 08:50 PM
'97 Defender LE - Low Miles Weaver For Sale - Vehicles 1 May 24th, 2005 08:22 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
