2.5NA - LT77 and Small Part Out - Page 3 - Defender Source
Old March 24th, 2015, 01:04 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Thanks Dave.
Don, ill P&P if still available.
Old March 24th, 2015, 01:09 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Hey Don, I was thinking about using the ball joint style steering arm (instead of the drop arm) on my Defender. Did you do this to your truck? Are you using a custom steering stabilizer mount? Did the conversion give you more clearance under the steering arm? By how much?
I did the work but my 110 is still in the build stage so I haven't tried it out. It does look good and I really like how it uses a TRE. There are pics on my build thread and I could take some others if you want too.
------ Follow up post added March 24th, 2015 01:09 PM ------
Originally Posted by roverman2010 View Post
Pm sent licked pending reply pics
Will PM back soon.
------ Follow up post added March 24th, 2015 01:10 PM ------
Originally Posted by 1of40 View Post
Thanks Dave. Don, ill P&P if still available.
Clay - all yours - will work out details via email - thanks!
Old March 24th, 2015, 08:55 PM
Don, I need the tunnel and adapter and lt77 floors for an auto conversion on a 130 that had an lt95.
Old March 24th, 2015, 09:00 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Sorry - the floors I am using - they are at the powder place getting Line-X'd. But, if you still want the tunnel and adapter let me know.
Old March 24th, 2015, 09:41 PM
I do. Make floors often so no worries there.
I line x'd the floors in my 130 in 2010 and it was a great choice. Another thing I did was put vaseline on the screws before screwing them down so they came back out easily.
Old March 24th, 2015, 09:50 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I do. Make floors often so no worries there. I line x'd the floors in my 130 in 2010 and it was a great choice. Another thing I did was put vaseline on the screws before screwing them down so they came back out easily.
I was going to say there isn't much to the floors if you have a set to trace a pattern.
Good tip on Vaseline on the screws - anti-seize for plastic, haha
Old March 25th, 2015, 07:58 AM
1of40's Avatar
1of40
1of40
Doug, there was a guy a little while back in ebay selling a set of lt77 floors cheap.
Old April 10th, 2015, 10:50 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The 2.5NA is back on the market. $300 and includes radiator, air intake, I'll cut the motor mounts if you need them too. Still in the chassis but just need motor mount bolts taking off to remove.
LT77 - $250
Rovers North Front Lower Spring Retainer SRP105 - $8
RHD Blower heater housing with motor - $25
RHD - pitman fork - $25
Tie Bar (ANR2994) - $25
Drop Arm - Adwest - pretty sure this is LHD but will confirm STC1045(needs rebuild) - $25
Flat Arm off Discovery - $25
Steering column Tie Rod - $15
RHD Bulkhead with screens - $500
LT77 tunnel and bulkhead adapter. Adapter is a little crusty and might need a patch - $30
Front doors - $100
Fender flares - $75
Fuse box holder for the glass fuses. $15
MRC8377 - Hose - $10
346576 - OPERATING LEVER VENTILATOR - Britpart - NIB - I just bought this and realized I could make the missing bracket just as easily. $35
Bulkhead Brackets Galvanized - bought from the UK - ended up getting the original's galvanized and I am going to use them. These are a little thick than stock. On ebay for $65 shipped - $40 shipped.
NRC5220 - throttle pedal bracket - new - was going to use but decided on just keeping the one out of the donor truck - - $20
Freshly Galvanized LH inner fenderwell - $75
Old April 10th, 2015, 11:28 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Some pics I have on my computer:
ID:	117973   Click image for larger version
ID:	117975   Click image for larger version
Old April 10th, 2015, 11:29 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Door pics:
ID:	117977   Click image for larger version
ID:	117979   Click image for larger version
Old April 10th, 2015, 01:33 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Pic of vent lever
Old April 10th, 2015, 01:34 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Bulkhead brackets
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Inner fender
Old April 13th, 2015, 02:09 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Monday Bump
Old April 19th, 2015, 06:21 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Fuse box with fuses and cover - $75
Old April 19th, 2015, 06:23 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Dash pad - $40
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Dash pad crack area
Old April 19th, 2015, 06:24 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another crack on dash pad
Old April 19th, 2015, 06:26 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thick 110 load mat with DEFENDER etched/written on it. 53" long. $150
Old April 19th, 2015, 08:32 PM
Whidbey's Avatar
Whidbey
86' 110
Hey Don, I'll take the left front door.
part
Diesel Injection Pump - ERC6761 - Small Parts - Leak 2.5NA xjahx Defender Technical Discussions 7 August 22nd, 2014 10:37 PM
Feeler: 1987 Tithonus 110 (sort of) rolling chassis w/ 2.5NA, LT77, and LT230 chris snell For Sale - Parts 19 February 17th, 2014 05:55 PM
NAS (mostly) small bit clean out from the 94 Part Out and others SafariHP The Vendors Loft 7 August 6th, 2012 09:26 AM
2.5NA diesel,LT77 and 1.4 lt230 transfer case Apocalypse Vehicle For Sale - Parts 0 July 17th, 2012 03:34 AM
2.5na/lt77/lt230 Ash For Sale - Parts 4 February 25th, 2012 05:59 PM
