2.5NA - LT77 and Small Part Out - Page 2 - Defender Source
Old March 4th, 2015, 12:53 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
RHD - pitman fork - $25
Tie Bar (ANR2994) - $25
Drop Arm - Adwest - pretty sure this is LHD but will confirm STC1045(needs rebuild) - $25
Flat Arm off Discovery - I used a similiar one to move to TRE steering - I am pretty sure these are LHD and RHD compatible and is for Adwest boxes - $25
Old March 4th, 2015, 12:54 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
aster Light Switch - PRC3430 - I replaced recently on my 110 but had to buy the AMR6104 to work with new wire harness. I think this is Lucas but not totally sure - $25
Old March 4th, 2015, 12:55 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I'll take it.
RDavisinVA
Old March 4th, 2015, 12:57 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Tie Rod that goes with steering column to bulkhead - NRC9711 / AHU710480 - $15
Old March 4th, 2015, 01:01 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
VDO Oil Pressure gauge - used this on the 2.5 but had to go mechanic for the Merc OM617.
#350104 - $15
Old March 4th, 2015, 01:02 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
#350104 - $15
I'll take it.
RDavisinVA
Old March 4th, 2015, 01:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by rdavisinva View Post
I'll take it.
Sounds good Robert - got you down for the switches and the oil pressure gauge.
Old March 4th, 2015, 01:06 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
And the LHD Blower Housing.
RDavisinVA
Old March 4th, 2015, 01:08 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The following are hold/sold for Robert:
Blower housing heater LHD blower UTP1258 - $75
Switch PRC3900G - $35
Master Light Switch - PRC3430 - - $25
Cowl Instrument Cluster - plastic - came off the RHD - no cracks - $25
VDO Oil Pressure - $15
Old March 4th, 2015, 01:21 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
PM sent.
RDavisinVA
Old March 24th, 2015, 11:49 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Update on previously listed parts
2.5 - sold
LzT77 - $250
Power steering reservoir- &25
Rovers North Front Lower Spring Retainer SRP105 - $8
Coil relocator - sold
Dizzy - sold
LHD Blower heater housing UTP1258 - sold
RHD Blower heater housing with motor - $25
Switch - sold
Cowl - sold
Flat Arm off Discovery - $25
Master light switch - sold
Steering column Tie Rod - $15
VDO oil pressure gauge - sold
Old March 24th, 2015, 11:51 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
LT77 tunnel cover and bulkhead adaptor - bulkhead adaptor piece is a little crusty on the corners. $50 for the both of them.
Old March 24th, 2015, 11:53 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I have the doors off the 110. Frames are pretty ratty in areas. Skins seem good tho. I can take more pics. $100 for the pair
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Hose - got the wrong size. $10
Old March 24th, 2015, 11:54 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
MRC8377 - another pic of the hose
Old March 24th, 2015, 11:55 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Fuse box holder for the glass fuses. $15
Old March 24th, 2015, 11:56 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Fender flares that came with the truck. I used the old black cut up ones off my NAS90. Will get pics of them - $100
------ Follow up post added March 24th, 2015 11:58 AM ------
I will have the bulkhead ready to pull soon. RHD. Floors need some patching and looks like some patch work done on the upper corners but everything else looks solid. Will take pics. $500
Old March 24th, 2015, 12:30 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Attachment 116797
Pm sent licked pending reply pics
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 24th, 2015, 12:39 PM
Hey Don,
I was thinking about using the ball joint style steering arm (instead of the drop arm) on my Defender. Did you do this to your truck? Are you using a custom steering stabilizer mount?
Did the conversion give you more clearance under the steering arm? By how much?
Old March 24th, 2015, 12:43 PM
Clay Ayers (1of40) needs the PS reservoir. I'll let him know.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
part
Diesel Injection Pump - ERC6761 - Small Parts - Leak 2.5NA xjahx Defender Technical Discussions 7 August 22nd, 2014 10:37 PM
Feeler: 1987 Tithonus 110 (sort of) rolling chassis w/ 2.5NA, LT77, and LT230 chris snell For Sale - Parts 19 February 17th, 2014 05:55 PM
NAS (mostly) small bit clean out from the 94 Part Out and others SafariHP The Vendors Loft 7 August 6th, 2012 09:26 AM
2.5NA diesel,LT77 and 1.4 lt230 transfer case Apocalypse Vehicle For Sale - Parts 0 July 17th, 2012 03:34 AM
2.5na/lt77/lt230 Ash For Sale - Parts 4 February 25th, 2012 05:59 PM
