2.5 NA/2.5TD Fuel Filter head with NIB Filter. - Defender Source
Old May 14th, 2013, 06:17 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
For sale is a fuel filter head originally fit to 2.5NA (and I think) 2.5TD Rover motors. The head/filter is cross compatible with other domestic diesels (I found the filter widely available at NAPA, etc under "Ford truck diesel"). Use it to replace a leaky one or use it in a side by side arrangement, I just don't need it anymore.
Asking $25 + the ride. Includes the housing and the new filter pictured. I'll ditch the old used one currently installed.
Name:	2013-05-14 18.11.29.jpg
ID:	72333   Click image for larger version
Name:	2013-05-14 18.11.38.jpg
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 1st, 2013, 12:40 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
If this directly bolts in place of the stock filter head, I will buy it. Please describe any modifications if needed.
I assume this will fit in a medium USPS Priority Mail box?
Do you want check or PayPal or do you directly accept credit cards?
Old June 1st, 2013, 11:26 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
That prime pump at the filter is sweet, but I think if I upgrade it will be to a 1 piece filter so you can fill the bad boy up, screw it on and loose minimal prime...
Old June 1st, 2013, 11:46 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Sedimenter then 12V pump then spin-on
The optimal setup is a sedimenter that will trap water, sludge, and particulate, then a low pressure 12V pump, then a spin-on filter... The spin-on picture shows a 12V heater that you won't need. Then you will never have to prime the system again.
We change the filter, switch on the key, wait a few minutes, then start the engine, then drive away. It takes longer to walk to throw the old filter away, then it does to bleed the system.
We have some sedimenters and spin-on filter heads if anyone is interested.
ID:	73586   Click image for larger version
RDavisinVA
fuel, nib
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
