1.66 transfer box - Defender Source
Old July 19th, 2012, 07:17 PM
the rover shop
shayne young
1.66 transfer box
Any interest in a 1.66 transfer box...was keeping it for my truck in case i needed it for a different gearing but going another route...so its for sale..
Old July 20th, 2012, 03:40 PM
aka rover's Avatar
aka rover
ed angel
95 D90
P.m me a price please
85 D110 3.5 3 DR
Old July 20th, 2012, 04:07 PM
the rover shop
shayne young
sorry Ed...the bloody Alaska train has left already...shipping will be a pain..
Old July 20th, 2012, 04:29 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
How much you asking for it?
Old July 20th, 2012, 10:44 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
Will this fit a 300tdi?
Old July 20th, 2012, 10:51 PM
Should...just bolt in. But why do you want a 1.6 in a 300? 1.4 would fit nicely, that's what I run in mine. Not crapping on Shaynes' FS thread just sayin...
Old July 20th, 2012, 11:23 PM
triple9music
Chad Davis
1984 Defender 90
Shayne, what do you have on your 300? Got a 1.4 for sale?
Old July 21st, 2012, 08:17 AM
the rover shop
shayne young
I have a 1.4 in my 200 tdi.. Sometimes people want a different transfer box when they install different tyres or gears in the diffs.. I can just never remember which way the whole gearing thing goes when you want better torque vs better top end speed... If you can't tach out your engine at terminal velocity (as fast as you want to go) then you are wasting gearing and can go lower gears.. If you tach out then you need higher gears because you are wasting engine revs.. That is of course if you are a highway driver.. It also changes your spacing between gear shifts one way or the other.. If you put oversize tyres on and still want to maintain a high highway speed I believe you can go to a lower ratio box.... Think of ratios like your 10 speed bicycle... In the low gears you had to turn your pedals (a.k.a engine or input shaft..also referred to as driver) twice as much to turn the rear wheel ( differential, output shaft..also referred to as the driven..)..think of it as a 2 to 1 ratio... In the higher gear you could turn your pedals once to turn the rear wheel once..that's a 1:1 ratio...in the lower gears you have better torque (easier to climb hills) but not a great top speed...go into the higher gears and you have reduced torque but higher top speed... It also depends on the torque curve and maximum engine rpm of the engine.. Generally speaking a gas engines tach higher than a diesel engine..but diesels have a better torque... I rode bicycles with a buddy who's legs could go much faster than mine (his engine tached higher at redline) than mine so in the same gearing he could beat me..but if I went to a higher gear I could beat him coz my engine had a better torque curve...I was stronger...sooooo to paraphrase ratios are like this...correct me if I am wrong guys... On a 1.66 ratio box it takes 1.66 turns of the input shaft to produce 1 turn of the output shaft.... On a 1.22 ratio it take 1.22 turns to produce the same result...meaning the 1.66 is a lower ratio and will give to better torque but lower top end...or alternatively make your engine turn faster to produce the same top speed...it seems like a very small difference 1.66 turns to 1.22 but when your engine is doing 3000 rpm it makes a difference.. Low gears give you low top speed and higher gives you higher top speed...Now..aren't you glad you asked...????...
Old July 21st, 2012, 08:22 AM
the rover shop
shayne young
And yes I do have a 1.4 i could sell..I could drop the 1.4 out of my 2.5 non turbo diesel with lt77 trans I put into the series 2a and put the 1.6 in it..I don't fancy driving a series at 70 to 80 mph down the highway anyway so I could use a lower ratio..but due to the amount of work I would have to get a decent price for it... Hence the feeler bit in the ad...whats it worth guys...
Old July 21st, 2012, 07:56 PM
Jarek M
Jaroslaw Maras
D1 OM617, S3 88, S3 FFR, D2 04'
PM...ed
Old July 30th, 2012, 11:46 AM
the rover shop
shayne young
Still available..
Old August 21st, 2012, 11:20 AM
the rover shop
shayne young
well I blew up my lt77 trans 2nd gear so I am using the trans from this combo but not the transfer box...1.66 box for sale...
Old August 21st, 2012, 02:37 PM
ItsNotAJeepThing's Avatar
ItsNotAJeepThing
Charles Essex
1995 Disco
Price?
Old August 21st, 2012, 04:10 PM
the rover shop
shayne young
oops.. hows $500 plus shipping or reasonable offers..wanna move it..
Old August 31st, 2012, 03:19 PM
the rover shop
shayne young
Bump and price drop.. $460..
Old August 31st, 2012, 03:40 PM
triple9music
Chad Davis
1984 Defender 90
how much for shipping to 29464?
Old August 31st, 2012, 03:51 PM
the rover shop
shayne young
bloody hell chad...you again...LOL..I will have to figure it out....let's say its $80.. I will pay anything additional...hows that for a kick ass deal...
Old August 31st, 2012, 04:18 PM
triple9music
Chad Davis
1984 Defender 90
at least you didn't use a bunch of exclamation marks!!!!! haha!! You know I want everything in your shop!!! I'm overusing those !! by the way........ haha
I do want it, but I think I'm selling ol blue to get a 110 now. Still might be able to use it down the line. Let you know asap. Fark! decisions......
------ Follow up post added August 31st, 2012 04:18 PM ------
and I tried to buy that air filter canister directly from you.
Old August 31st, 2012, 10:52 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
so right now I am running 1:4 transfer and 4:11 diffs with 33's. If I go to 35's should I go with lower diffs or will the 1:6 tranfer work better?
Old August 31st, 2012, 11:06 PM
Rugbier's Avatar
Rugbier
Gustavo
Well Dana, it will take you back to OH and the Farming days ( feeling John Deere? )
NO SIGNATURE
Transfer Box oil filler mod jhhorse Defender Technical Discussions 5 December 9th, 2010 05:47 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
Transfer Box Fill Plug matthewwcarey Defender Technical Discussions 5 February 18th, 2008 04:21 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
