1.66 transfer box - Page 2 - Defender Source
Old August 31st, 2012, 11:06 PM
the rover shop
shayne young
In my opinion the transfer box is much easier and cheaper to change...unless of course your diffs are lockers and then we can trade..LOL..
Old October 18th, 2012, 02:04 PM
the rover shop
shayne young
still have this 1.66 tranny...hehehe,,, he said TRANNY.. actually I guess its a transfer box... but that doesn't make me giggle like saying tranny...
Old November 5th, 2012, 10:29 PM
the rover shop
shayne young
BUELLER......BUELLER....$400 anyone..plus shipping, I can place it in a tote and it ships pretty easy..
Old March 8th, 2013, 12:29 AM
the rover shop
shayne young
Bump to top.. How's $370.
Old March 19th, 2013, 04:49 AM
the rover shop
shayne young
$300....
Old March 19th, 2013, 10:54 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Originally Posted by Hammertime View Post
so right now I am running 1:4 transfer and 4:11 diffs with 33's. If I go to 35's should I go with lower diffs or will the 1:6 tranfer work better?
Dana, remeber that the 1.6:1 transfer case will only effect your gearing in high range. Low range will still be the same in all the LT230s. If you are going to 35s and want to keep your end to end "gearing" roughly the same off road as well as on the highway, you may want to consider making the change in the diffs.
Old March 19th, 2013, 11:20 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
What is stock in a NAS110? I may be interested in this.
Old March 19th, 2013, 11:42 AM
slorocco
Dan Prasada-Rao
I don't know for sure, but I doubt it is the 1.6:1 t-case. I'm told the 1.6:1 was used in the early 2.5 na diesel 110s. Not sure where else it was used.
Old March 19th, 2013, 12:10 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
1.4 came stock
Old March 20th, 2013, 05:09 PM
the rover shop
shayne young
Correct.. 1.6 was stock in early smaller non turbo diesel and gas engined vehicles.. If you were to go to bigger tyres I would suggest for road use to go to this transfer box.. Correct about it not changing low range gearing.. But low 1st is usually low enough already especially with e 4:1 gears.. The 1.6 will just make it better on the road.... If you can't pull 5th gear on the road this will aid you in doing that.. Ideally you should be able to max engine rpm at the same time you max your road speed... Otherwise your wasting revs or gears..if you find yourself wishing you had a 6th gear then you need to go to a higher ratio.. Ie.. From a 1.4to a 1.2
Old May 6th, 2013, 09:15 PM
the rover shop
shayne young
Still available..
Old May 6th, 2013, 09:22 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
If your heading to CA again I maybe interested.
Old May 6th, 2013, 09:30 PM
the rover shop
shayne young
I'm heading back in. Few days.. But it's too big for carry on..)
Transfer Box oil filler mod jhhorse Defender Technical Discussions 5 December 9th, 2010 05:47 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
Transfer Box Fill Plug matthewwcarey Defender Technical Discussions 5 February 18th, 2008 04:21 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
