Sprung-over 109 Cummins Diesel Project - Defender Source
Old February 21st, 2008, 11:25 PM
Relk
Relk
A big ol' pile
I have been collecting parts and working on this project for the last couple years in Eugene, Oregon and I have come to the sad realization that I just don't have the time, money and resources to finish this project, not to mention I now live in Portland (100 miles of separation), with no shop space. This project still needs full assembly and some fabrication but the vast majority of parts (at least the difficult ones to corral are here). This is a hard thing to let go but I must pass the torch. Sprung-over 109 Rover ( military frame from ambulance, 88 springs in front, 63" Chevys in the rear, 1/8" plating along the entire underside of frame rails, burly rear custom cross-member, chassis is sprung and on FJ60 axles with Swamper Q78 (90%+), drivetrain is NOT in chassis, Cummins 6AT (runner, fresh paint and recent rebuilt injection pump), NP435 (disassembled) with new-in-box rebuild kit from Novak, custom (Ike Goss) NP435/Rover T-case mainshaft and adaptor, low milage Ashcroft high-ratio T-case. 3 door boby, new old stock late style fenders, deluxe hood with dished spare (separated from frame and frame acid dipped), bulkhead acid dipped with one passenger footwell and dog house removed for alteration and repair, 2A doors (frames acid dipped) with series 3 skins (hole for key lock), late style radiator panel acid dipped, three door tub with previous owner addition of rear tank filler (exposed rivets but looks good and could easily be touched up, rear panel removed for replacement), rear safari door with frame separated and acid dipped, really sweet van sides that originally say "Security: British Aerospace", pick-up cab top rough back has no round glass but has shroud for 3/4 canvas, seat box is good, floor boards, 2 set of bulkhead vents, two windscreen frames early and late style, NO door tops, all hinges, grab handles, battery tray, splash guards, rear spare carrier and a bunch of other stuff is acid dipped. Late 2A grill, front and rear lamp guard, military hood latches, series 2 vent lifter (round dial type), vent screens, classic steering wheel, turn signal, military glass screw-in lamps (full set, turns, indicator, tails), military head lamp setups, standard headlamp surround, aux. under seat fuel tank, rebuilt (disassembled and POR-15) clutch pedal tower and custom power brake Rover pedal tower and adaptor plate for hydroboost with booster NICE!, Scout 2 power steering box (POR-15) with custom pitman arm with appropriate drop. Tons of cool Rover bits and pieces like hand throttle and ashtray. Basically there are a lot of parts here, these are just off the top of my head.
Thanks, Relk
$7,500/?
Not interested in parting it out.
Name:	Photo Library - 1441.jpg
ID:	12280   Click image for larger version
Name:	Photo Library - 1442.jpg
Name:	Photo Library - 1437.jpg
Old February 24th, 2008, 09:41 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Awesome... love that rear crossmember.
good luck w/the sale
~Steve
Old February 26th, 2008, 03:36 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Oh man, I hate to see you selling that. I'm mid project myself with a cummins 4bt into a '63 109 Station Wagon. Your project is a whole lot cleaner than mine. If I wasn't all the way across the country I'd be tempted to come buy yours. You're farther ahead than I am. I'm just cutting and extending the front frame horns this week.
BTW, if you have a source for the hydroboost mod on the brake pedal assy, and for the modified scout pitman arm, I could use both of those.
I think I've seen some of this rig on Pirate 4x4
109, diesel
FS new galv. 109 coil sprung frame ECR For Sale - Parts 7 July 7th, 2009 10:59 AM
Rover Hybrids OPEN HOUSE! See a Cummins diesel D90! Shane@EVS Trips, Trails and Events 16 February 1st, 2008 12:37 PM
Gaguing Interest: Immaculate 109 Wagon with Vortec V6 or a Cummins 4BT diesel dieselcruiserhead For Sale - Vehicles 6 October 29th, 2006 12:32 AM
Coil sprung series vehicle w/ diesel engine geneseemtn Misc. Chit-Chat 19 February 26th, 2006 09:52 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
