NATO Black RRC, one more time - Defender Source
Old May 12th, 2005, 02:15 PM
RedRhinoProducts's Avatar
RedRhinoProducts
RedRhinoProducts
Big-Ass Disco
Arrow NATO Black RRC, one more time
Well, I want to try one last time to sell this Rover. It is in great shape, the frame is solid with no major rust. Very little body damage only a few small dents in the hood cowl and some small holes in the fenders from when there were flares installed. Several things have been Rhino Lined eg: hood center, lower sides, roof rack, etc... The truck starts immediately and has seen VERY LITTLE offroading, ask anyone who knows me this truck has sat more then it has been driven. I just yanked out the old 10 spine axles and swapped in some newer 24 spline casing complete with updated brakes and the whole nine. I also have a set of new Rancho adjustables to go with it. This is a last ditch effort before I trade it to someone else for another project that is currently pending so make me a decent offer and give it a good home.
Specs:
  • 1988 Range Rover Classic
  • Fresh NATO Black Paint Job
  • 3.9l Engine [80k miles]
  • 14CUX ECU & Wiring Hardness Installed
  • ZF Automatic Transmission [88k miles]
  • LT-230 Transfer Box [22k miles]
  • Stock 3.54 gears [24 spline]
  • 16x8x4.00"BS Black Steel Wheels w/ 34x9.50x16 Military Super Swampers
  • QT Front & Rear Differential Guards
  • RoverTym HD Front & Rear Links [Adjustable for 1-5” Lift]
  • Raised Breather Lines
  • RoverTym Adjustable Pan-Hard Rod
  • RoverTym Steering Stabilizer Relocation Kit w/ OME Defender Style Damper
  • Rebuilt Swivel Balls w/ New CV Assemblies
  • Stainless Steel Brake Lines
  • 5” RoverTym Lift
  • Scorpion Racing Front Dislocation Cones
  • RoverTym Rear Dislocation Cones
  • RoverTym HD Rear Upper Loop Style Shock Mount
  • RoverTym Front & Rear Lower Loop Style Shock Mounts
  • Discovery II Loop Style Upper Shock Mounts
  • 9 Way Adjustable Rancho Shocks w/ In-cab Controller
  • Bearmach Adjustable Rear Ball Joint
  • NRP Exhaust
  • Front & Rear custom 30 degree shafts
  • 2” Polyurethane Body Lift
  • Red Rhino HD Rock Sliders
  • Voyager front bumper w/ skid plate
  • 8,000lb Winch w/ 150’ Dynaflex Synthetic Winch Line [All New]
  • Hi-Lift Jack
  • Limb Raisers
  • Hella Fog Lights [1 is broken]
  • CAT Side Lights & Reverse Lights
  • Red Rhino Snorkel w/ Camel Trophy Style Snorkel Top
  • Voyager Roof Rack System
  • Hella H4 Upgraded Headlight System
  • Red Rhino Products Rear Tubular Bumper
  • Hellroaring Technologies Dual Battery System
  • Dual NAPA regular batteries
  • Discovery Series I Front Manual Seats
  • RRC Rear Folding Seats
  • Pioneer Stereo System
  • CB Radio w/ Firestick
  • Discovery Series I Automatic Shifter Mechanism
  • More…
Replaced OE Parts:
  • Vehicle Speed Sensor
  • Distributor
  • Plugs & Wires
  • MAS Sensor
  • Injectors
  • Motor Mounts
  • Bushings
  • Fuel Pump
  • Fuel Filter [Converted to New Style Thread On/Off]
  • Hoses
  • Belts
  • Clutch Fan [Upgrade to Metal]
  • Coil [Relocated Inside Cab]
  • ECU [Relocated Inside Cab]
  • Starter
  • All Wiring in Engine Bay & Positives & Grounds Re-ran
  • Radiator Boiled
  • All Windows Serviced and Working
  • All Door Locks Serviced and Working
  • Wood Trim Interior Professionally Refinished
  • More…
You can see photos of it here: http://www.get-rhino.com/classifieds/whiterangie.htm
Email me direct if your interested – jason@get-rhino.com
, Jason Michaels
Old May 12th, 2005, 03:01 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
I'll start the bidding at $2500.00
Old May 12th, 2005, 03:05 PM
RedRhinoProducts
RedRhinoProducts
Big-Ass Disco
thanks Jimmy.
Old May 24th, 2014, 04:24 PM
Moparman83
Bumps Mcgee
The Link no longer works is this still for sale and want to see some pics if it is! Thanks ~MLW\
Old May 24th, 2014, 09:06 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Moparman83- please get a clue and stop bumping threads from 2, 5,7, 9 years ago...
and Red Rhino got out of Land Rovers in 2007...sheesh
Rent my
Old May 28th, 2014, 01:37 PM
Moparman83
Bumps Mcgee
Nomar or Jeff, You and the welcoming committee really rolled out the red carpet, Thanks asshole!
Old May 28th, 2014, 01:58 PM
New rule: You can only bump a thread from as far back as your registrations on this site...? :-)
Old May 28th, 2014, 01:59 PM
Moparman83
Bumps Mcgee
JSBriggs that was not directed at you. You just coincidntally had the same name as Nomar! Another lesson learned: use User-name when commenting! Got it
------ Follow up post added May 28th, 2014 08:01 PM ------
Woldd90, I'm new to the Forum scene! I will check dates before posting anything. But here is my question, if this shit is sold or really F'en old they why is it not removed?
Old May 28th, 2014, 02:05 PM
It was all in fun...
We don't delete old posts here... You can always see past parts and prices...
Old May 28th, 2014, 02:32 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Michael/moparman, sorry if I sounded harsh, but in one night you were jumping all over the forum bumping up ancient old threads.
Read the dates.
It's not hard.
If a Range Rover was listed here for sale in 2005, chances are it's gone by now.
You could send the OP(that's Original Poster) a PM(private message) and ask if his sale from 2005 ever went through or if the truck is still available.
Hope that helps.
Rent my
Old May 28th, 2014, 02:41 PM
Moparman83
Bumps Mcgee
Nomar, I get it, its not hard! But I wasn't looking at posting dates I was simply searching for the specific vehicle I want and those were the ones popped up. No worries man this Noob won't inconvienience you any more to read my ancient bumps. I know that your time is precious and my 3 sentence bump threw your day out of wack so much that you had to say something abt it. I will stick to PM to avoid the riff raff! Thanks for the heads up!
Old May 28th, 2014, 02:49 PM
You should change your username to "Ancient Bumps"
That would be 10x more fucking awesome than moparmanwhatever.
Old May 28th, 2014, 02:54 PM
Shuswap's Avatar
Shuswap
Nicholas
1985 D110
All cool Michael
Michael, I visit a few forums just to read never post.
The reason is just this instance where someone (Nomar) somewhere (SC) has a bug up their ass.
In Canada that person would quickly apologize for rude and crass comments but down south they gots different rules of behavior.
Please do not be bullied by folks, you have every right to be here and make whatever comments.
Imagine the shit if you were posting on a Porsche or Ferrari website
Groupies can still have a mediocre of manners and goodwill towards others.
:i con_peace:
You're all right buddy.
Have a great day.
Moparman83
Bumps Mcgee
Thanks RingChengdouchebag . . . your "Wisdom" has been duly noted!
------ Follow up post added May 28th, 2014 08:57 PM ------
Nicholas, I guess there is always a learning curve and asshole where ever you go but the South is Def full of them! Lol
Old May 28th, 2014, 02:59 PM
Shuswap's Avatar
Shuswap
Nicholas
1985 D110
Red ching
No kidding " Born in the USA"
Perfect example of my prior post. thanks!
The internet is full of hubris and arrogance.
Looks like "they" are trying to run you off.
Not enough posts or not enough of a defender.
Old May 28th, 2014, 03:00 PM
I don't think you liked my suggestion. Sorry just trying to help with a cool moniker for you to fit in better on this distinctly non-mopar forum and make light of your faux pas and your detractors. In response, you resorted to adding disparaging terms onto the end of my username. That was not very nice, Mr. Bumps.
Old May 28th, 2014, 03:02 PM
Shuswap's Avatar
Shuswap
Nicholas
1985 D110
Red ching
Sorry I need more coffee and I got up on the wrong side of bed, plus its raining outside.
Old May 28th, 2014, 03:06 PM
Moparman83
Bumps Mcgee
I figured if you didn't have enough respect to get my name right why should I attemp to get your right either MasterYoda! For being born in America I figured you would have a better grip on the 1st Amendment but as a reminder it doesn't matter what my name is! But I guess being an internet Forum badboy is more your Motif! I'm Very Impressed . . .
Old May 28th, 2014, 03:11 PM
LOL...
The Born in the USA comment is a remnant of an inside joke here that I don't even recall now, something to do with the Bruce Springsteen album of the same name since I am from New Jersey hence the nickname Chingsteen underneath my username.
And an example of being able to laugh at one's own mistakes and screw-ups. Etc etc.
Both of you guys are welcome here as is everyone else being a public forum. Being quick to respond with vitriol won't win you any friends or make people eager to help you.
More to the point it does occur to me that I have a 1988 RRC that could use a new home if moparman/bumps is interested. Seriously.
Old May 28th, 2014, 03:20 PM
Moparman83
Bumps Mcgee
I can take ribbing and joking in stride but when you attack me directly or going out of your way to talk down to me then this is what you get in return! I'm very aware that my Vitriol will not win friends or easy help on a forum but that help should be offered as a show of respect but I will not be pushed around just because I'm new. I think we can all get along just fine with a certain level of professionalism. Not what I expected for my first forum! Thanks for finally coming around
ac
NATO Wolf Black Tubless Steel Wheels WLDKGDM For Sale - Parts 7 May 21st, 2009 02:06 PM
95 RRC black swb draaronr For Sale - Vehicles 29 June 19th, 2008 07:55 PM
DII LT-230 in Old RRC, HELP Please. RedRhinoProducts Defender Technical Discussions 1 November 6th, 2004 02:24 PM
