Nas 110 - Defender Source
Old January 26th, 2008, 12:58 PM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
Arrow Nas 110
Greetings to all,
I am selling for a cleint, his NAS 110.
It shows 29k for miles but its got a Odometer repalcement sticker at 100k.
It has sat for the past year due to a bad ECU. It wouldnt start.
It has a brand new battery, alternator, Distributor and ECU.
It has the typical rust and the headliner is sagging
The airconditioning blows but no cool air, might be leak somewhere.
He bought this with the intention to restore it to a ECR restoration.
It was sent to ECR last winter 06/07and was sent back, it wasnt the price, it was the timing.
He thought it was going to arrive there and it would have gotten worked on right away.
Selling price is 35900 FIRM
questions and additional pictures podgorskim@autonation.com
ID:	11852   Click image for larger version
ID:	11854   Click image for larger version
ID:	11856   Click image for larger version
ID:	11858   Click image for larger version
Old January 26th, 2008, 02:37 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
Is the frame solid?
Looks better than the one I just bought for 30, so its not bottom of the barrel price, or bottom of the barrel quality.
She should sell pretty soon, but I need to know her number!
Old January 26th, 2008, 02:54 PM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
Jim - you caught me, i forgot the number plate 456/500
Here are additional pics of the frame and number plate
ID:	11860   Click image for larger version
ID:	11862   Click image for larger version
Old January 27th, 2008, 09:35 AM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
Calling Mr Tisdale!!
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old January 27th, 2008, 10:56 AM
This will be sold in a week.
Old January 27th, 2008, 11:19 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
I must be loosing it. I do not recall this truck at all.
Oh, FL, now I do... yup that was 100% unrealistic expectations.
I have a full evaluation of this truck if anyone is interested. $50.
Email:
Old January 27th, 2008, 01:01 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
already made a purchase...pictures to come and becoming a member of the "registry" in a few weeks when the vehicle arrives. Thanks for thinking of me!
Tis
Old January 27th, 2008, 02:34 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
Martin,
Email sent for more pics and info.
Mike - email sent as well.
AndrewT
Old January 28th, 2008, 02:15 PM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
No need to pay 50 dollars to knit pick a 15year old 110
Here is the evaluation FREE of charge.
There was a issue with the miles, there is a sticker in the door jam showing 100005 (odometer replaced)
now the truck shows 29xxx. Didnt see why Mike wrote that it had 141k
Schlesinger 141,787 :miles in NAS
Defender 110 #456
SALDH1287PA921843
The following were found to be out of spec. on the Rover as judged
against a new vehicle.:
-Vehicle resprayed very poorly in base/ clear (should be single
stage). Numerous runs and tons of overspray. Terrible paint quality
-Front bumper painted and scratched (should be powder coat)
-LH fender:
-Inner dented
-Vent broken
-Antenna bent
-LH front door:
-Window hits something going down
-Crank plug missing
-Panel plugs missing
-Hinges rusted
-LH T support dented
-LH middle door:
-Dented from hitting T support
-Hinges rusty
-Frame rusted
-Window hits inside door badly
-LH tub side:
-Roofside seal painted over
-Rust in capping and possible body filler in rear corner
-Light box paint faded
-Rear door:
-Through corrosion blisters
-Some frame rust
-Lower window retain is painted black
-Defront grommet pulled through
-3rd brake light grommet not installed
-Frame welded at wiper motor
-Grab handle bent
-Main wire grommet unplugged
-Excess goop in window seal (replacement done poorly)
-Door frame is missing support guide
-Panel loose
-Panel is an incorrect replacement (no tool box)
RH tub side:
Capping rust
-Paint faded on light box
-Step bolts missing
-Roof seal painted over
-Rear crossmember rusted through
-RH middle door:
-Door catch squeeks
-Paint missing on forward edge of window track
-Frame rusted
-Lock will not lock
-Denetd due to T support
-Corrosion on door skin
-Hinges rusty
-RH front door:
-Panel falling off
-Frame rusty
-Hinges rusty
-Paint missing in areas where they hung the door to spray it
-Panel plug missing
-Incorrect panel plug
-Crank plug missing
-Lower door seal missing
-RH fender:
-Dented
-Grill support cracked
-Hood rusty and dented (hail damage?)
-Roof damages (hail)
-Lower windscreen seal bad
-All cage hardware painted over and has numerous incorrect fasteners
-RH dog leg rivets incorrect
-Brake and clutch fluid long overdue for service
-Clucth reservior empty
-Engine 1 quart low
-PS reservior loose
-PS fluid low
-PS reservior missing screen
-Coolant low
-PCV system overdue for service
-Belts loose
-Cap and rotor overdue for service
-Water pump plug wire bracket not attached
-Air filter dirty
-Alternator cover missing
-Small PS leak
-Radiator mount bolt broken
-Rear wheel bearings loose
-Passenger front shock bushing bad
-Drop arm bad
-Drag link tie rod end boot ripped
-Drag link clamp hitting steering stabilizer
-Oil pan leaking
-Oil pump leaking
-Starter heat shield missing
-Passenger cat heat shield rubs driveshaft
-Clucth heat shield missing
-Misc trasfer box leaks
-Rear A arm joint bad
-Battery box rusted badly
-Rear muffler rusted
-RH upper parking light in-op
-LH upper parking light in-op
-LH front signal in-op
-2 bulbs in 3rd brake light in-op
-Windows tinted
-Rear step matt hardware incorrect
-Speedo replaced at least twice TMU
-R seat bases broken
-Headliners sagging
-RH AC fan siezed
-Rear window trim missing
-RH middle belt trim missing
-LF speaker missing
-Pedal pads worn through
-Aftermarket radio
-Cubby box nicked and strap wrecked
-Temp. illumination in-op
-AC illumination in-op
-Handbrake needs adjustment
-RH toe board trim missing
-Heated screen in-op
-AC in-op
-Misc. door striker shims falling out
-Brake pedal low and pulsates
-Engine clatters due to low oil pressure at start up
OVERVIEW:
A 110 that has lived out its duty cycle. Poorly painted and poorly maintained.
ECR
21 Tolman Road, Warren, ME 04864
ph: 207-594-8086 fax: 207-594-8120
http://www.eastcoastrover.com
ECR emails are for information exchange only, they are not quotes or
estimates. All work at ECR is done on a time and materials basis.
Install costs and overall project costs can not be given as used and
vintage vehicles vary greatly in condition.
http://www.eastcoastrover.com/FAQ.html
We suggest all 1993-1995 NAS Defender owners read this page:
http://www.eastcoastrover.com/110oillines.html
Old January 28th, 2008, 02:22 PM
ECR's Avatar
ECR
Very cool. Thats even better when the seller discloses all the info.
50. is small change for me to go routing around in old files to hand out information that nets me zero.
Its great that the info is out there for free.
There is documentation on the car prior to your ownership that adds up to 140K miles roughly.
Email:
Old January 28th, 2008, 02:25 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Yeah, you cant say the seller is hiding anything now. LOL
Chris von C
[/size]
Old January 28th, 2008, 02:44 PM
themaxx's Avatar
themaxx
Ade
94 ST
That just turned into a great 'Check List'!
Old January 28th, 2008, 03:19 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Really now.. with most of our Defenders... do we REALLY need the check list? I was nodding for 90% of it while reading thinking of my own trucks.
Chris von C
[/size]
Old January 28th, 2008, 03:26 PM
I could have written "standard 15 year old land rover" and it would have covered it.
What does the carfax say re: accidents/condition of the title?
Ron
Old January 28th, 2008, 04:45 PM
tommyd's Avatar
tommyd
Tom
LR3
Cheers to Martin for making the evaluation available FOR FREE.
"Handing out" the information may have netted you a customer, Mike. Instead you just lost a potential one . . .
Old January 28th, 2008, 04:51 PM
ECR's Avatar
ECR
Yup, thats how I pay my mortgage and my employees, by working for you for free.
Get a grip folks. Let me come to your place of work and ask for something for nothing and see how long it takes before you tell me to go get lost.
With all the free information I post to this site and the ECR site you are barking up the wrong tree here pal.
Its not my place to spoil sales for others by posting evaluations. Therefore I figured it would weed out the dead-wood and only those serious if it was posted for a fee. The seller should post it like he did, it isn't my place and I'm not here to serve you for nothing.
Ron
Man your good Ron... to see all that from a few images.
I quit... Ron can take over.
Email:
Old January 28th, 2008, 05:08 PM
jessejames4's Avatar
jessejames4
Jesse Parris
1/18 scale LR Def 110
So with all this talk about the 110 after the eval is published by Martin, is it worth $35,900 and will someone here vouch for Martin if I cut him check?
Jesse Parris
1/18th scale Def 110 CSW Tdi
but still looking for larger
Old January 28th, 2008, 05:13 PM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
I cant understand Mike, Scott (owner of the 110) paid you 175 for the evaluation. I cant beleive you had the nerve to ask for another 50 dollars. I am glad that I kept the email with the evaluation.
I hope no one had to pay the 50 dollars,
here is Mike's response to a member for asking for the evaluation for free.
"50. because we spent time and money doing it.
This is a business."
East Coast Rover Co. (staff)
13 Merrill Drive
Rockland, ME 04841
207-594-8086
You were paid for your time and money.
All you need to do is some cut and pasting,
Old January 28th, 2008, 05:35 PM
ECR's Avatar
ECR
No one paid. You did the right thing by posting the info.
So let me get this right...
I'm supposed to leave the shop. Drive to the other shop. Get the file. Re-type the evaluation into the computer (because its in hard copy only now) then post it to the site or to other potential buyers (your buyers not mine) for nothing while you make money on the sale by me doing work and I'm supposed to do all that for nothing.
Man you guys have a screwed up sense of reality.
Also, when we did the evaluation it was all "good info" and now when you are trying to sell the truck it is "nit picking". Funny how things change when your needs change Martin.
Somehow I think the dealership you work at would charge a whole lot more thank 175. for an evaluation on a private sale and then if another customer came in looking at the same truck the dealership would do another evaluation at full whack and not say "Oh yeah, we just did that evaluation for another customer... here it is."
I don't see that happening at your dealership at all... ever.
and I never post any good free information anywhere.... do I?
My blood is boiling here... the double standard where some dealerships and all will rip you off again and again with crazy labor rates, trying to sell a junk truck for big bucks and double talk and all and is all OK because they are a "dealerships" and "salesmen" and its expected, but I am supposed to bend over and suck dick for free all the time when I just asked for a small fee to cover the wasted time (yes WASTED TIME!!)... I've had it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
Apply the double standard to someone else.
Email:
110, nas, nas 110
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
NAS Defender 110 AirConditioning Parts COSteve Defender Technical Discussions 5 May 19th, 2004 03:54 PM
