Lots of Unique Toyotas - Defender Source
Old June 22nd, 2016, 01:05 PM
eco 45's Avatar
eco 45
Scott Oncken
running or non?
I know not Defenders, but still very unique vehicles. Have a shop expansion happening this summer and need to make some room to build it. So below will be a quick and dirty list of vehicles for sale along with prices and photo links. All vehicles are RHD so if not for you please don't post up about it. All vehicles have free and clear Oregon Titles. If you need more details send me an email or PM. Thanks
1990 75 Series Fire Truck
1990 very low KM
Body has some rust in front fender, and rear door jams
doors are in excellent shape
floors and firewall are good
truck runs well, but needs exhaust
More photos:
https://oncken.smugmug.com/Fire-Truck
Asking $12,000.00 and truck is located in Central Oregon with Oregon title.
1990 Troopy 1HZ
Shows 315000KM, but engine only has around 70000 miles as it was rebuilt to turbo specs. Older gentleman owned the truck killed the first engine with a turbo, had the engine rebuilt to turbo specs, but was then too scared to add a turbo back onto the engine so ran it NA.
Custom front and rear bumpers
Dual fuel tanks
Front seats only
Original paint
All fluids done
New tires
New timing belt and tensioner
A/C not working and haven't had time to find out why
More photos:
https://oncken.smugmug.com/1990-White-Troopy-1HZ
Located in Central Oregon and has Oregon title. Asking $20,000.00
1983 Double Cab, RHD diesel Hilux
1983 RHD diesel Hilux
All fluids changed
Rebuilt injectors
New glow plugs
Will have new fuel cutoff valve once the part arrives
New front window regulators come with the truck
New timing belt
Not the fastest truck but a blast to drive
a/c not working
More photos:
https://oncken.smugmug.com/83-Hilux
Asking $12,000.00 Truck is in Central Oregon and has Oregon title.
4 Door 75 Series
Quite obvious this vehicle received quite a bit of love over the years and well taken care of. Drives really well and a/c blows cold.
The spec for this truck are:
2H Diesel Engine
A/C--works very well
Power Steering
5 Speed Manual Transmission (H55)
Full Floating Rear Axle
LED Rear Lights
Ute Style Bed With Drop Down Sides
Two New Batteries
New Lower Radiator Coolant Heater
All Fluids Changed and Filters
New Thermostat and Gasket
New Exhaust
New Drive Line Carrier Bearing
New Wiper Blades
New Locking Fuel Cap
Second Set of Keys Made
Inspected Brakes and Tie Rod Ends
Inspected Lights
Little To No Rust
New Glow Plugs
New Oil Pressure Release Valve
New Mechanical Oil Pressure Gauge
New Steering Dampener
Unknown Mileage
Length: 20 Feet
Width: 6 Feet
Wheel Base: 12 Feet
Lots of leg room in the rear seats
More Photos:
https://oncken.smugmug.com/Beige-4-d...Seiries-Toyota
Asking $24,000.00 and has Oregon title
1987 Toyota Troopy 12HT Turbo Diesel
Quite the amazing Troopy with one of Toyota's best diesel engines. Odometer shows just under 312000 KM on the truck, but very obvious a lot of work has gone into the vehicle. The 12HT diesel runs beautifully and has an aftermarket air to air inter cooler on top of the engine.
Rust:
-passenger side bottom has a two inch long area only on the seam. It is not coming through on the outside just shows on the inside of the door where the metal is bent over.
-passenger side floor has an area about 4"X4" near a drain hole that could use a patch
-The rest of the truck if anything only has surface rust if even that.
Paint:
-exterior only respray. I have been around the truck with a magnet and no areas of bondo are showing. The paint shows well.
The truck has some sound deadening glued to the front floors so pictures are not available for those areas. For a 1987 this truck shows quite well and has had a lot of upgrades. Easy daily driver with only a few minor things to play with.
12HT Diesel engine
5speed manual transmission
All fluids changed
Rebuilt front differential and new seals on front axle
A/C system repaired and operational
New thermostat
35 inch tires
Disk brakes on the rear axle
New Factory Turbo
More photos:
https://oncken.smugmug.com/Troopy-with-12HT
Asking$24,000.00 has Oregon Title
Scott Oncken
Sisters, OR
541-550-6300
eco 45 on all forums
Old June 22nd, 2016, 02:16 PM
oilburner's Avatar
oilburner
JL
large pile of parts
12HT troopie. Pretty much the best Cruiser ever! Good luck with the sale!
JL
FS: Unique Lanard Motorized Defender 90 Monster Truck Toy kiphartzell For Sale - Parts 7 June 24th, 2013 01:45 PM
comments on this "unique" rover seriesgarage Misc. Chit-Chat 5 July 14th, 2009 02:24 PM
Unique item for sale. norros For Sale - Parts 1 February 10th, 2006 06:45 PM
Very Unique Item... norros Misc. Chit-Chat 41 January 3rd, 2006 09:16 AM
Unique looking 90 on ebay? Willh Misc. Chit-Chat 8 October 5th, 2003 11:44 PM
