FS: Early 1961-62 88" IIa - Defender Source
Old March 1st, 2014, 06:22 AM
jcasteel
John Casteel
1961 Series IIa
1961 Land Rover Series IIa. (Serial Number 24100020a ) Right hand drive pickup cab. I purchased this rover in the fall of 2006. From 2006 until 2008 I had the rover apart except for the tub. The engine and transmission were removed. Clutch, rear seal, wiring harness, etc. etc. replaced as needed. Repainted with Ful-cryl II acrylic enamel color code “rover 2651”. I wish I had a better place to paint and equipment so that the paint looked better. The breakfast, wing tops and bulkhead look good but the paint on the body sides is not so good. She starts every time unless sitting for long periods and then she needs a few taps of the gas pedal and a little choke. When I got her the brakes had already been converted to dual circuit power brakes using a Series III tower.
I know that the Series IIa is usually 1962 or later but I bought her from South Carolina and the prevous owner used the year 1961. Based on the early serial number the vehicle was built in October 1961 (according to the CALvin calculator). Georgia does not issue titles for cars older than 1963. She is registered here in GA. I do still have the SC title if that is of any value.
Rover located in Savannah, GA
Odometer says 92k.
$9800.
Please take a look and ask questions. She isn't perfect but has only let me down once during the 2013 Christmas parade and that was apparently due to vapor lock.
More pictures: http://s186.photobucket.com/user/seriesiia20/library/
Updates
2007 - 2008
Clutch, Flywheel, pressure plate
clutch slave cylinder
clutch hydraulics changed to DOT 5
Rovers North wiring harness (front and rear)
Hella eCode Headlights run through Bosch relays
crankshaft rear seal replaced
motor mounts and transmission mounts replaced
3 point seatbelt for middle seat, lap belts for outside seats.
2011
Brakes and hubs rebuilt and/or replaced as necessary
Brakes hydraulics changed to DOT 5
Ford Explorer master cylinder installed
Pertronix Ignition (distributor + coil)
2012
Rochester Carb (Orig Solex will be included in sale)
Rocky Mountain Parabolic Springs
Rocky Mountan Pro Shock absorbers
GBR greasable bushings
Seats recovered and refoamed by a local marine upholsterer.
2013
All external lighting converted to LED. Flashers work.
New style Rocky Mountain Spin on oil filter adapter
Rocky Mountain window tracks put in the cab rear window
Extras
Box of magazines and books.
The Bad
Windshield wipers included but not installed
Rear crossmember needs to be addressed (I always planned to replace the frame.)
Left front hub seal leaks
No heater
No Air
Windows (I have windows but you will want to replace them. One piece of glass is broken and the windows are falling apart anyway.)
ID:	90497   Click image for larger version
ID:	90499   Click image for larger version
1961 Series IIa 24100020a
2010 Surly Steamroller
1995 Red D90 (Sold)
Old March 1st, 2014, 06:41 AM
jcasteel
John Casteel
1961 Series IIa
I have the large galvanized piece to mount the spare on the hood. However, I usually carry the spare mounted in the tub. I'll get a picture of that later.
1995 Red D90 (Sold)
Old March 1st, 2014, 08:27 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Neat truck. Glwts.
Old March 6th, 2014, 02:21 PM
jcasteel
John Casteel
1961 Series IIa
I could not see how to edit my original post.
Contact me at jaypee@thecasteels.com.
The rear crossmember needs to be addressed but the rover is perfectly drivable as she is. I left that undone because I was hoping to replace with a galvanized frame someday.
I'm surprised that I haven't had any interest though I know it has been only a week. I felt the price left room for negotiation. I'm willing to listen to thoughts concerning the pricing or if I'm missing something.
Thanks, John
1995 Red D90 (Sold)
Old March 7th, 2014, 12:12 PM
jcasteel
John Casteel
1961 Series IIa
Bump $8800 obo
1995 Red D90 (Sold)
Old April 10th, 2014, 10:12 AM
jcasteel
John Casteel
1961 Series IIa
Lower price
Bump $7500.
1995 Red D90 (Sold)
Old April 14th, 2014, 11:40 AM
jcasteel
John Casteel
1961 Series IIa
Sold
1995 Red D90 (Sold)
fs
FS Pickup Cab Seat Belt Brackets IIA, III NOS NLA $199 rdavisinva For Sale - Parts 12 November 7th, 2016 09:53 PM
FS LHD Ser IIA 300 tdi conversion roverx For Sale - Vehicles 18 March 24th, 2014 09:45 AM
For Sale - 67 Series IIA 88" jabber For Sale - Vehicles 6 February 21st, 2008 02:00 PM
Series IIA 88" body tub Coiler For Sale - Parts 0 November 9th, 2007 12:10 PM
