FS: 1996 Land Rover Discovery SD7 - Defender Source
Old February 17th, 2014, 11:31 PM
no-pistons
Eric
1996 D1
Well I really hate to do this, but I need to sell my 1996 Land Rover Discovery SD7. My work hours have been cut and my commute is up to 55 miles a day due to a recent move. I just canít justify/afford having three 4x4 vehicles anymore, so this one has to go.
This Disco has been one of the most enjoyable vehicles Iíve ever had. Itís very comfortable and drives extremely smooth! Itís also been one of the most reliable vehicles Iíve ever had; been driving it to work every day with no problems whatsoever. It also does NOT leak! It is a California truck with NO rust anywhere. The truck currently has only 102,000 miles on it. It is an SD model with no sunroofs and no power seats.
Iíve done a lot of preventative maintenance and upgrades to the truck also, mainly because I planned on keeping it for a long time, and the fact that Iím a bit OCD . It runs and drives perfectly! I wouldnít hesitate driving this truck anywhere.
What has been done:
  • ~87,000 miles: Defender brake upgrade with New calipers, pads, and rotors. New rear pads. New Genuine Fuel Pump. New Water pump with coolant flush.
  • ~89,000 miles: New Sears Diehard Platinum battery ($175.00), New Kingsborne 8mm spark plug wires ($35). New power steering fluid. Change front and rear differential oils to Mobil 1 synthetic gear oil. Added magnetic drain plugs to diffs. Change transfer case oil.
  • ~90,000 miles: New Bilstein shocks ($350), New engine oil cooler lines ($110), Change engine oil -15/40 Rotella. New fuel filter. Rebuilt rear driveshaft with new rotoflex and U-joint. New rear suspension ball joint. Fresh one-shot grease in swivel housings.
  • ~93,500 miles: New Cooper AT3 tires -215/85R-16 ($800) with new Defender steel wheels ($430) and Genuine Steel lug nuts ($60). Change engine oil -15/40 Rotella. New spark plugs. Transmission drain & fill with Mobil 1 synthetic ATF.
  • ~94,000 miles: Complete cooling system flush and overhaul; all new radiator and heater hoses, new thermostat, new coolant reservoir and cap, and brass radiator plug. New motor mounts.
  • ~97,000 miles: Change engine oil Ė 15/40 Rotella
  • ~98,500 miles: New Terrafirma heavy duty steering rods with new tie rod ends ($200). New OEM rear springs ($100). New pan hard bar bushings. 5 tire rotation. Front end alignment. New OEM mud flaps.
  • ~100500 miles: Change engine oil Ė 15/40 Rotella. Transmission drain & fill with Mobil 1 synthetic ATF.
Iím probably missing a few things in my list, but as you can see Iíve done a lot to the truck. Its ready to go, nothing is needed!
Asking $5900 OBO
Email: no-pistons@cox.net
Old February 18th, 2014, 12:43 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Can you explain the Defender brake upgrade? I've only heard of Defender owners doing Discovery brake upgrades.
Old February 18th, 2014, 12:55 AM
no-pistons
Eric
1996 D1
The Defender calipers are larger and more powerful than the stock D1 calipers. Here is a pic I found on discoweb:
Old February 18th, 2014, 03:08 AM
Zack the later defender uses a vented front rotor and much larger caliper than the disco. Disco rear disc brakes are an upgrade for early 90's that had drum rears.
Old February 18th, 2014, 07:14 AM
very nice, this should go quickly.
Old February 18th, 2014, 09:04 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Eric, sent you an e-mail.
We need to replace our 94 and this looks great.
Old February 18th, 2014, 09:21 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Thanks!
Old February 18th, 2014, 09:52 AM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
Were your photos taken at Cowles mountain? Bump for a clean d1
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old February 18th, 2014, 10:14 AM
no-pistons
Eric
1996 D1
No, but I actually live right down the street from Cowles Mtn. Pictures were taken at a cemetery off of Willow Glenn in El Cajon
------ Follow up post added February 18th, 2014 07:18 AM ------
Emailed back.
Old February 24th, 2014, 08:53 PM
no-pistons
Eric
1996 D1
My wife "convinced" me to lower my price. $5200 OBO
Old March 4th, 2014, 09:24 AM
no-pistons
Eric
1996 D1
Sale Pending
Old March 4th, 2014, 09:38 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Great truck and listing. Your descriptive post was probably worth a $1000 price premium. Congrats w/ the sale. Well done.
Old March 6th, 2014, 12:11 AM
no-pistons
Eric
1996 D1
Thank you for the kind words down shift.
Truck is sold!
Old March 6th, 2014, 08:07 AM
UnfrozenCaveman
Keith Armstrong
Various
Whew! Very glad it sold
cover, disco, discovery, fs, land rover, sd
1996 Land Rover Discovery, not running - Raleigh, NC $750 motap For Sale - Vehicles 13 January 18th, 2014 08:35 AM
FS: 2004 Discovery SE w 35k original miles mpodgorski For Sale - Vehicles 8 November 29th, 2013 02:04 PM
1996 Land Rover Discovery d90boy For Sale - Vehicles 52 February 20th, 2010 09:57 AM
(4) '97 Discovery Wheels FS SafariHP The Vendors Loft 1 October 30th, 2008 12:47 AM
FS: Silver 1996 Discovery in CT J.5 For Sale - Vehicles 2 October 29th, 2008 01:00 PM
