FS: 1995 Land Rover Discovery 1 300 TDI Diesel 5-speed Manual 7 Passenger NC - Defender Source
Old August 5th, 2014, 07:07 PM
Wolfrubicon
Hunter
1995 Disco 1 300 TDI
Been lurking this forum for years, but I'm just a creeper and research w/o posting! Anyways, I had been searching for this vehicle for a while and finally came across it last year. I've spent the last year prepping her and getting things ready for expeditions but life has taken a turn as of late and we must let her go. I'm going to link my for sale thread on expo portal (I think this is okay and not against forum rules!) so you can check out all the photos. On to the nitty gritty…
http://www.expeditionportal.com/foru...7-Passenger-NC
1995 Land Rover Discovery 1 300 TDI 5-speed manual (7 passenger). Arles Blue w/ white roof, Gray interior. A/C is fully functional after swap and is cold! This Discovery 1 has a new re-stained dash w/ no airbags, no ABS. The gauges read in KM/H as this has all the correct glow plug lights and no unleaded logo. This Rover has ZERO rust issues. The doors and frame have been coated with Crest Honey Coat. Truck was repainted in 2012. No body damage or dents, and again, no rust. Headliner and interior are in great condition. This truck has no sunroof (bonus as it has no leaks)! It has a cloth interior and 94 style manual seats.
Have all documents on the conversion. Some of photos show truck with white wheels, they are now a semi-matte black to match the hood blackout decal.
Professionally converted in 2011 from V8 to 300 TDI by Cityside garage located in Holliston, MA. http://www.citysidegarage.com/ TDI had 78K when installed and has covered just over 22K since conversion.
Engine:
New Dayco Timing belt kit, new injectors, glow plugs, glow plug timer, new tensioner bearing, water pump, lift pump, PS pump, power steering box, all belts and hoses were replaced, silicone turbo hoses, new rear main seal and front cam seal, new battery June 2014, rebuilt injector pump, rebuilt alternator, full stainless steel exhaust, new engine and gearbox mounts. New Mantec snorkel!
Drivetrain:
New rear U-joint style driveshaft. Rebuilt double cardan front driveshaft with aluminum adapter. F swivel balls filled with one-shot grease. All new wheel bearings, races, and hub seals, freshly packed. All but rear shaft were done Spring 2014 along with brake overhaul.
Gearbox:
New clutch kit, resurfaced flywheel, throw out bearing and fork lever.
Brakes:
All new remanufactured brake calipers, brake rotors, and Ferodo brake pads on all four corners. +40mm stainless steel brake lines F&R. Fresh fluid. Brake overhaul done Spring 2014.
Suspension:
Brand new OME Heavy Duty springs F&R, new OME Nitrocharger shocks F&R, new F tubular shock towers, new Terrafirma lowered rear upper shock mounts, new F&R spring retainers, all installed Winter 2013.
General:
Safety Devices low profile roof rack w/ custom matte aluminum diamond plate (removable)! New rear door ladder. 5 new wolf military steel wheels, BFG A/T's 235/85R16. Rovertym rock sliders with extra side step and Rovertym winch bumper w/ steering guard. UK spec trailer mount (not currently installed). New gaskets on rear windows. Saudi Spec Front Grill! Hood blackout decal. Rear CB antenna mount and RG-58 coax ran to behind passenger dash, ready for radio/antenna install.
Interior:
All 5 doors have new actuators. Front doors have new window lift arms. Both front seats have new Exmoor Trim foam. All door handles have been replaced. New dash was installed and re-stained due to typical dash curl. Full set of matching factory seat covers. New ignition key tumbler, custom rear load space mat, and new rear aluminum door panel. New clutch and brake pedal pads. Entire floorpan has been covered with Monstaliner in matching grey color.
Lots of extra parts included: a set of matching front seats no rips or tears. All 4 door panels, all 4 windows and rails etc. rear wiper motor and arm, door actuators, A/C heater controls, plastic sill trim, door locks and hinges, extra switches and dash parts, etc. Have receipts for pretty much everything!
$17,000
wolfrubicon at g mail
Email/PM with any questions or if you'd like to see more photos. I have plenty! Thanks!
Name:	Photo Apr 02, 5 32 04 PM.jpg
Old August 5th, 2014, 09:11 PM
monktonrover
Tyler C.
D90 200TDi
What kind of MPG are you averaging?
Old August 5th, 2014, 10:09 PM
Wolfrubicon
Hunter
I'm getting around town about 22ish, give or take 1-2 depending on driving conditions and quality of diesel. On the highway I'm usually around 30mpg. Hwy mileage will really vary depending on your driving style. Trying to run 75-80 will drop the mileage a good bit, but I can run 65-70 and turn good numbers. I've tried hyper-miling it a few times running like 60 on a 80 mile trip to my parents, pretty flat hwy, and I swear the fuel gauge hardly budged!
Old August 26th, 2014, 09:22 PM
Wolfrubicon
Hunter
Option for purchase, I keep the roof rack and drop $800 off the price.
Old August 26th, 2014, 11:22 PM
rovertrader's Avatar
rovertrader
Dale
For those that don't know Hunter, he is a great fella, and a very knowledgable 'car' guy. This was Scott's Disco previously (from Nashville), and as stated above, the motor work was done by Cityside. It is an awesome, very well done Discovery and has tempted me since Scott had it for sale initially.
GLWS!!
Old September 11th, 2014, 04:27 PM
Wolfrubicon
Hunter
Thanks Dale! TTT!
Old September 25th, 2014, 10:51 AM
Wolfrubicon
Hunter
Ttt!
Old October 13th, 2014, 12:01 PM
Wolfrubicon
Hunter
Up!
Old October 31st, 2014, 04:23 PM
Wolfrubicon
Hunter
Sold!!!!
Old October 31st, 2014, 04:26 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Congrats, awesome truck
Old October 31st, 2014, 09:25 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I have one at half the price
good luck with your search
Old October 31st, 2014, 09:41 PM
rovertrader
Dale
Congrats Hunter!?,
Old November 1st, 2014, 05:49 AM
Originally Posted by rovertrader View Post
For those that don't know Hunter, he is a great fella, and a very knowledgable 'car' guy. This was Scott's Disco previously (from Nashville), and as stated above, the motor work was done by Cityside. It is an awesome, very well done Discovery and has tempted me since Scott had it for sale initially. GLWS!!
Thought I recognized it!!!
The Saudi grill started life on my D1 before I sold it to Scott.
Old November 1st, 2014, 06:33 AM
rovertrader
Dale
Small world when individual parts history are known!!
How's the truck running- get her dialed in??
Old November 1st, 2014, 06:44 AM
Running good working on getting Nigel ready for winter. Heater works great even without the fan or heat controls in place. It's a Kodiak I bought from Scott!.
1995, 300 tdi, 95, cover, diesel, disco, discovery, fs, land rover, manual, tdi
200tdi 300tdi LAND ROVER TURBO DIESEL ENGINE KITS DEFENDER 200 300 TDI squeaky For Sale - Parts 0 July 31st, 2014 02:16 PM
1995 LWB RANGE ROVER CLASSIC 300 tdi TURBO DIESEL SOFT DASH 5 SPEED squeaky For Sale - Vehicles 11 May 17th, 2014 10:31 PM
1998 discovery tdi 5 speed diesel silvercreekmotors For Sale - Vehicles 4 September 15th, 2013 08:40 AM
1995 Land Rover Discovery TDI Clean 5 Speed bitz For Sale - Vehicles 5 November 12th, 2012 09:49 PM
1997 Discovery SD 5-speed manual Screehopper For Sale - Vehicles 0 July 20th, 2005 01:07 AM
