Fs: 1995 d90 st #2213 - Defender Source
Old January 19th, 2014, 03:44 PM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
Arrow Fs: 1995 d90 st #2213
Can't believe I'm doing this, but "Tessa" is for sale- 95' Defender ST #2213. Long story short- I'm in need of an extra 20 inches of wheelbase (D110) in order to continue enjoying these trucks as a hobby. Considered keeping her and just adding another vehicle, but here in N Arlington- I'm unfortunately out of real-estate.
The truck has been used regularly over the course of it's life with 157k currently on the odometer (8k/yr). It's been mainly used as fair-weather transportation, but there have been periods where I've driven it to work daily. A few times a year, it's seen "scenic" off road trail rides, but deep cleaned, detailed, and garaged afterward. The bodywork and paint is in excellent condition, but not without some minor scratches, dents, and dings expected from 19 years of normal wear and tear.
In the past 3 years alone, over $26k (documented in receipts) has been spent in performing scheduled and unscheduled maintenance. You'd be hard pressed to find one in better condition- regardless of the mileage. The following is a sampling of the maintenance actions performed, and/or parts replaced:
LR Windshield
LR Windshield Gasket
Bridgestone Dueler A/T D693 II Tires
LR Sun Visors x 2
Drive Belt Kit Replacement
Tie Rod Ends Replaced x 3
Rebuild Drop Arm Swivel
Steering Dampner Replaced
Power Steering Pump & both resevoir lines replaced
Engine Mounts Replaced x 2
Rear Brake Pads Replaced x 2
Bilstein Shock Absorbers x 4
Oxygen Sensor Replaced
Flush & Replace Brake Fluid
Flush & Replace Clutch Fluid
Flush & Replace Trans Fluid
Flush & Replace Front/Rear Differential Fluid
Flush & Replace Transfer Case Fluid
Replace Air Filter
Stainless Steel Oil Cooler Line Upgrade
Front Radius Arm Bushings Replaced (Poly) x 2
Rear Trailing Arm Bushings Replaced (Poly) x 2
Speedometer cable replaced
Repair Wiring to Auxiliary Fans
Front & Rear Differential Pinion Seals Replaced x 2
T304 SS Trailhead Y-pipe w/RT Cats
T304 SS Custom Cat-Back Exhaust (TIG)
Custom Badger II GK (TITAN GREY)
LR Heater Core Replacement
LR Heater Blower Motor Replacement
Water Pump Replaced
Badger Top Installation
LR Fan Clutch Replaced
LR ECU Replaced
Lamp Assemblys Replaced
Hella Lamp Vision Plus 7" HB2 Headlamps Installed
LR Loadspace Mat Replaced
MISC Interior Part Replacement
MISC Interior Part Replacement (RovaFarm)
Hella 4000 Ralleye Series 9" Pencil Beams x 2
Hella Wiring Harness
Install/Wire Lights
LR Upgraded Door Hinges
Interior Stainless Steel Hardware Kit
Exterior Stainless Steel Hardware Kit
Clean/Repaint Seatbox & Door Hinges
LR Galvanized NTO SW Doors
YRM Utility Box
YRM Auxilliary Box
Magneti Marelli 120 AMP Alternator
Tuffy Center Console
Optima Yellow Top Battery Replacement
Billet Wingtop Vents
Rear Window Retaining Clips (Lavender's)
Galvanized RN Fuel Tank Guard
Galvanized Crossmember w/Extensions
LR Black Leather 36-Spline Steering Wheel (NLA)
LR Steering Wheel Pad
MB Quart PVM216
MB Quart PVM116
MB Quart RLP-254
MB Quart RM740.5
NVX XKIT44
NVX XIV25
Xscorpion PE200X
Metra 81-4300
HushMat
Pioneer DEH-X8500BS
Install Audio Equipment (Hurley's)
POR-15 Black Paint Kit (crossmember)
Galvanized Fuel Tank mounts (aka Ears)
Stainless Steel Hardware (Crossmember/Step)
Fuel Pump Replacement
Braided Stainless Steel Fuel Lines
Center Linkage Ball Joint Replacement
Rust. As primarily a Southern truck, it had very little rust when I bought it. The footwells had begun to show light rust thanks to the original acoustic foam matting (sponges), and the rear crossmember had developed a small hole in the center that was creatively covered using a thick diamond plate. None of these needed to be replaced yet, but as an "idealist", I knew I'd sleep better at night once they were taken care of. The foot wells were repaired (bulkhead is solid), and as you'll see- the crossmember was recently replaced with a galvanized version (w/extensions). The only rust you'll see today is superficial, with a few spots on the original bumper, and a few on the bed caps (easy repair if desired).
$40k
Several members have seen the truck up close and can attest to it's condition; maybe they'll chime in. Otherwise, I'm glad to go over the truck with any serious, prospective buyers: (eight five eight) 539-5307 or ross.simpson22@gmail.com.
Lastly- you'll find additional info and pictures on the truck's registry: http://www.defendersource.com/forum/...ad.php?t=48009
and here: http://s903.photobucket.com/user/Hol...0Defender%2090
Old January 19th, 2014, 03:51 PM
Abrooks's Avatar
Abrooks
Tony Brooks
It's a really, really clean truck. GLWS
Old January 19th, 2014, 03:57 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Ross is the price missing or did I miss it? GLWS looks great!
Old January 19th, 2014, 04:11 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
X2 on the cleanliness and I would not be deterred by the mileage given Ross' attention to detail.
Clay
Old January 19th, 2014, 04:12 PM
Holiday's Avatar
Holiday
Ross Simpson
Thanks, Gents. Price was hidden at the bottom in bold- asking $40k.
Old January 19th, 2014, 04:23 PM
Ross, what color is the truck?
Old January 19th, 2014, 04:24 PM
Bill Larson
Bill Larson
Sheza White.....http://www.defendersource.com/forum/...ad.php?t=48009
Old January 19th, 2014, 05:26 PM
Holiday's Avatar
Holiday
Ross Simpson
Alpine White, Ed. (Thanks, Bill)
Old January 19th, 2014, 07:09 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've driven this truck 200 miles (thanks Ross!) and it drove straight, no issues with tranny, tcase, motor, or anything for that matter. In addition, I helped rebuild the seat box and did some other work to it. Definitely a nice, well sorted, clean truck.
Semper Fi!
Old January 19th, 2014, 10:34 PM
Holiday's Avatar
Holiday
Ross Simpson
Thanks! Now get yourself Stateside.
Old January 22nd, 2014, 10:07 AM
Holiday's Avatar
Holiday
Ross Simpson
Snow bump
Old January 22nd, 2014, 09:24 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Do you still have the truck?
Old January 22nd, 2014, 10:38 PM
Holiday's Avatar
Holiday
Ross Simpson
I do, Nate. Feel free to give me a shout if you're interested. My contact info is in the original post.
Old January 23rd, 2014, 12:22 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Sounds good. I have a hectic schedule in the morning but will shot for sometime tomorrow. Any particular time work for you?
Old January 23rd, 2014, 09:28 AM
Holiday's Avatar
Holiday
Ross Simpson
Should be available to take a call after 2:30pm. Call you back if I miss you.
Old January 24th, 2014, 04:02 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Sucks to hear that you are selling this... I definitely wish I had the money!
I was a passenger in this D90 after my Range Rover Classic was experiencing some "technical issues" due to my great off roading skills. So I can honestly say its a great one!
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old January 24th, 2014, 06:38 PM
Holiday's Avatar
Holiday
Ross Simpson
Thanks, Max- we need to get together soon, now that I'm in VA.
I think everyone would agree that you crushed it last year on the trails…
------ Follow up post added January 24th, 2014 04:46 PM ------
Quick update:
The third brake light bar (not pictured) is back from the powdercoater and will be bolted on this weekend.
Also, I'm somewhat negotiable on the price for a forum buyer. Spent a lot of time, money, and energy on this truck, so would like to be able to keep track of it.
Give me a shout if you're looking for a turn-key truck that you can enjoy as is for many, many years.
Old January 25th, 2014, 07:47 AM
well sorted, good luck with sale. Its getting harder and harder to find "clean" trucks.
Old January 25th, 2014, 11:01 PM
Holiday's Avatar
Holiday
Ross Simpson
Thanks- they are getting tough to find. This is one of them.
Old January 27th, 2014, 04:16 PM
wow this is almost a twin of mine (Badger II GK, new doors, matting, white, etc)
Really like the look of the grey top (Mine is black)
GLWS
95' D90 - daily driver..
1995, 90, 95, d90, fs
1995 D90 ST for sale LRover For Sale - Vehicles 22 May 21st, 2012 10:05 PM
Rear ST bench seat from 1995 D90 dave_lucas For Sale - Parts 2 March 28th, 2010 10:52 AM
White 1995 Land Rover D90 ST (located in Dallas) defender_rd For Sale - Vehicles 1 November 9th, 2004 11:27 AM
1995 ST and SW brochure mpodgorski For Sale - Parts 1 June 25th, 2004 02:14 PM
Wanted: 1997 D90 ST regulator-26 Wanted 0 March 14th, 2004 10:42 PM
