Fs: 1994 nas d90 - Defender Source
Old September 9th, 2015, 10:47 PM
ionfender's Avatar
ionfender
IO
94 NAS D90, #1379 (SOLD)
Fs: 1994 nas d90 st
Selling my 1994 NAS 90 ST. Alpine White. Has 94,500 miles. I hate to get rid of it because itís a solid truck, but now that Iíve had it for a bit Iím thinking Iíd like something a little different. More on that later.
The truck lived in Utah for the first ten years, then southern California for about 5 years, Pittsburgh for 5 years, and I have had it for less than a year. Pretty confident this truck has not seen salt as the Pittsburgh owner did not drive it in the winter.
The engine/drive train is the stock 3.9L --> R380 trans.- -> 1.22 TC --> 3.54 differential gearing. Trutrac limited slip in the rear diff. The truck rides and drives really well. Alignment is good, and no vibrations at highway speeds. Has 5 matching Michelin LTX M/S tires (285/75/16). The spare and the two rear tires are like new tread, the fronts have 75% tread. Flowmaster exhaust that sounds great.
The Good:
-About as rust free as they come without a restoration
-I have three tops for the truckÖTickford, Surrey and a bikini. All in good condition. No rips/tears or stains.
-Trailhead 4x4 SS oil cooler lines installed in June 2015
-Engine is strong with no known issues. In 2007 when the vehicle had 87,000 miles the engine was given a significant overhaul. See below for details on what was done.
-Clutch master cylinder replaced in 2011
-New alternator in 2014
-New pads and rotors at 87,000 miles
-New plugs and wires sometime in the last two years
-No leaks with the exception of a small leak on the transfer case. The leak is so slight it doesnít even drip to the floor.
-New galvanized fuel tank guard in 2015 from Rovers North
-New shocks and springs (Pro Comp) in 2014 from Rovers North.
-New Terra Firm front radius arms and bushings in 2015 from Rovers North. I still have the stock radius arms as well.
The less than good:
-No rear sway bar
-There is some rust in the seat boxes
-The rubber boot/cover for the transmission tunnel is cracked
-The rear rubber floor mat is cracked on both sides where the wheel well makes a 90 degree corner
-The driver and passenger doors were resprayed at some point and the color match isnít perfect
-No catalytic convertors
-The Hella lights on the brush guard are not hooked up, but the wiring harness will go with the truck
The engine work at 87,000 miles included the following:
-Replaced the heads
-Replaced the crank bearings
-New valve seals, cylinder head gasket, intake manifold gasket, valve cover gasket, crankshaft bearings,
-Other miscellaneous work at this time: new engine mounts, exhaust manifold gasket, thermostat, new U-Joints, front axle swivels replaced, and balanced the rear drive shaft.
-There were a number of other smaller things done as well, but this list includes the primary stuff. Iím happy to share the receipts for the workÖit totals $7,000.
Let me know what questions you have, and if there are any specific pictures you would like to see. Asking $49,500
I would consider a trade for a well sorted 110 EX-MOD (RHD or LHD). Upgraded engine from the 2.5 is strongly preferred with preference to a Tdi.
ID:	129317   Click image for larger version
ID:	129319   Click image for larger version
ID:	129321   Click image for larger version
ID:	129323   Click image for larger version
ID:	129325   Click image for larger version
ID:	129328   Click image for larger version
ID:	129330   Click image for larger version
ID:	129332   Click image for larger version
ID:	129334   Click image for larger version
Old September 9th, 2015, 11:02 PM
ionfender's Avatar
ionfender
IO
More pics.
ID:	129337   Click image for larger version
ID:	129339   Click image for larger version
ID:	129341   Click image for larger version
ID:	129343   Click image for larger version
ID:	129345   Click image for larger version
ID:	129347   Click image for larger version
ID:	129349   Click image for larger version
Old September 9th, 2015, 11:10 PM
ionfender's Avatar
ionfender
IO
Frame pics.
ID:	129352   Click image for larger version
ID:	129354   Click image for larger version
ID:	129356   Click image for larger version
ID:	129358   Click image for larger version
ID:	129360   Click image for larger version
ID:	129362   Click image for larger version
ID:	129364   Click image for larger version
Old September 9th, 2015, 11:15 PM
ionfender's Avatar
ionfender
IO
Engine pics
ID:	129366   Click image for larger version
ID:	129368   Click image for larger version
ID:	129370   Click image for larger version
Old September 9th, 2015, 11:27 PM
NAS Addict's Avatar
NAS Addict
Jeff
95 D90 ST #2617
Nice truck! Good luck
Old September 10th, 2015, 07:43 AM
You may not have owned it very long but you've certainly learned how to put a nearly perfect ad together!! Good job, and best of luck.
Old September 10th, 2015, 02:57 PM
ionfender's Avatar
ionfender
IO
Thanks guys. I picked up a few sale posting tips by watching others.
Old September 11th, 2015, 11:21 AM
Rdh74
Ricky Harris
I just sent you an email
Old September 14th, 2015, 09:11 PM
ionfender's Avatar
ionfender
IO
BUMP. Clean and straight 94 NAS looking for a new home.
Old September 22nd, 2015, 12:25 PM
ionfender's Avatar
ionfender
IO
Bump
Old September 26th, 2015, 11:40 AM
ionfender's Avatar
ionfender
IO
Bump. Reasonable offers considered. I don't NEED to sell it, but would like to before purchasing a new toy.
Old October 4th, 2015, 08:44 PM
ionfender's Avatar
ionfender
IO
Price drop to $48,000
Old October 13th, 2015, 01:10 PM
ionfender's Avatar
ionfender
IO
Received a deposit. Inspection pending.
Old October 13th, 2015, 01:30 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
congrats that was a pretty 90.
Old October 26th, 2015, 05:38 PM
Dorado34698
Steve
2013 LR4
Did it sell?
Old October 26th, 2015, 05:57 PM
ionfender's Avatar
ionfender
IO
Originally Posted by Dorado34698 View Post
Did it sell?
Should have an answer in a day or two.
Old November 24th, 2015, 09:44 AM
ionfender's Avatar
ionfender
IO
Sold. Truck is relocating to the southeast US. New owner seems like a great guy.
d90, nas, 90, fs, 1994
Beefeater - 1994 D90 NAS :: 1994 Land Rover Defender 90 Raz Defender & Series Truck Registry 2 August 6th, 2015 12:22 PM
1994 D90 # 1646 :: 1994 Land Rover Defender 90 gmuiter Defender & Series Truck Registry 0 June 25th, 2015 09:30 AM
NAS D90 :: 1994 Land Rover NAS D90 Sned Defender & Series Truck Registry 0 April 27th, 2014 12:55 PM
1994 Land Rover 1994 D90 ST mountainviewrover Defender & Series Truck Registry 0 March 3rd, 2013 01:01 PM
1994 D90 :: 1994 Land Rover Defender 90 tgraham Defender & Series Truck Registry 0 September 25th, 2012 05:18 PM
