engine oil - Defender Source
Old April 8th, 2013, 12:11 PM
rawien
rawien
defender td5 2004
engine oil
Hi every one,
i have a question regarding the type of engine oil to use for a defender td5, i'm living in Suriname with a temperature 22 to 30degrees Celsius. Is shell rimula 15w40 oil best suited for these temperatures?
Old April 8th, 2013, 12:39 PM
Any quality diesel engine oil should be good. The Rimula should work well.
Old April 8th, 2013, 01:07 PM
rawien
rawien
defender td5 2004
i just asked the question because I read on the internet that LR recommmended 5w30, thus thinking if i'm not overdoing something
Old April 8th, 2013, 01:16 PM
The larger weight range would be a good idea if it is cold started. With 22 C as the minimum, it won't do much. An xW40 will be better for the engine, IMO, than an xW30.
Old April 8th, 2013, 01:18 PM
Your bigger concern will be making sure it is fed quality fuel. I'm not sure if that is a problem where you live.
Old April 8th, 2013, 01:21 PM
The Dro
Dro
1988 Ninety
It all depends on who you ask... This topic has been beaten extensively.
Here is a good l ink that talks about the subject.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Old April 8th, 2013, 01:38 PM
All of the TD5 manuals I have say "5W30, 5W40 or 5W50". LR uses these number to force a synthetic oil which makes things safer especially when maintenance intervals are not quite waht they should be. For your climate a 15W40 will provide as good a wear protection as a 5W40 with suitable change intervals. If you really want to know for sure, get oil analysis done and you will know for sure.
If you want to get the "best", then choose one of the full synthetic 5W-40 diesel oils (Shell Rotella T6, Mobil Delvac 1, etc...) but I doubt you would see any significant change in wear numbers living near the equator.
Old April 8th, 2013, 01:58 PM
rawien
rawien
defender td5 2004
thanks for the replies, I might just go with full synthetic eventually, might be better for the engine. have this defender for just an year so still figuring things out, leaks for instance
engine
Engine Swap: which one? 200tdi, 300tdi, or something I dont even know about gonzanc Defender Technical Discussions 46 April 2nd, 2013 09:36 PM
ATF and Engine Oil Recommendations? KKilo23 Defender Technical Discussions 10 October 17th, 2009 10:56 PM
Overfilling engine oil Trevor Tarr Defender Technical Discussions 2 February 7th, 2005 02:17 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
engine oil chart from owners manual Eric_S Defender Technical Discussions 3 November 21st, 2003 10:40 AM
