Defender 90 - Defender Source
Old July 21st, 2016, 09:11 AM
JohnnyO
John Oberlin
1995 D90 SW
Defender 90
LHD, 300Tdi, R380, no rust, power steering
- In running order on an excellent, rust free chassis. Currently registered and insured, and used as a daily driver in summer.
- Low mileage Defender 300Tdi engine with all of the correct LHD fittings, having had a full rebuild after suffering a timing belt failure. Has updated timing belt installed new rings, bearings, valves etc.
- Low mileage R380 with matching 1.4 ratio transfer case
- New clutch, pressure plate, throw out bearing and arm
- New master and slave for the clutch
- D90 300 Tdi power steering system, correct pump, reservoir, lines etc.
- 300Tdi exhaust system, front to rear
- 300 Tdi seat box
- Almost all of the cooling, intake, intake lines etc. are new
- New U joints on front and rear drive line
- New axle seals and bearings
- New brakes 3000 KMs ago
- Esbar coolant heater installed
- Body is in tidy condition but needs paint
- Good BFG AT rubber all around
Needs TLC on the door adjustment, paint work and seat backs.
Currently configured as a soft top with roll bar. Station Wagon hard top is available.
Price: $20,000 (Canadian)
For sale in Calgary, Alberta, Canada. Importing to USA would be a challenge as VIN indicates 2.5NA.
Old July 21st, 2016, 09:14 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
What year is it?
Do you have the 2.5 NA still?
~ Semper Fidelis ~
Old July 21st, 2016, 11:39 AM
JohnnyO
John Oberlin
1995 D90 SW
The VIN indicates 1986. It's actually registered as a 1982. Early 90's were first available in 1983. This is an ex-military vehicle previously used at a British training base here in Alberta. It was sold at a public auction and I suspect that's where the discrepancy occurred. I'll go through the paper work to correct the registration if it's an issue.
The original 2.5NA is long gone but one can always be refit to allow for US import.
Old July 22nd, 2016, 02:58 PM
JohnnyO
John Oberlin
1995 D90 SW
34,000 original kilometers having only ever driven around the British army training base. Station Wagon hard top also available.
ID:	154293   Click image for larger version
ID:	154297   Click image for larger version
Old August 10th, 2016, 07:06 AM
JohnnyO
John Oberlin
1995 D90 SW
Sold
Old August 11th, 2016, 06:38 PM
Chowbird's Avatar
Chowbird
Tim
'84 D90
That was a good looking truck, congrats!
1984 D90 LHD 3.5 V8
2010 Range Rover Sport
90, defender, defender 90
