Cummins 4bt, SIIA 109 5-door - Page 2 - Defender Source
Old July 28th, 2011, 02:43 PM
Naplm00
Matthew
Where do you source a 4bt that clean?
Old July 28th, 2011, 03:20 PM
That 4BT makes me drool.
If a 200tdi is a quarter pounder, the 4BT is like a double quarter pounder with cheese.
Noisy as balls, that is a hairy man's diesel
Old July 28th, 2011, 06:30 PM
gallf1
Felix
1971 SIIA 109 5-door
picx
Name:	LRside view1.jpg
ID:	40668   Click image for larger version
Old August 1st, 2011, 08:45 AM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
Sweet truck!
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old August 5th, 2011, 01:51 AM
redrockrover's Avatar
redrockrover
Russell Phillips
1994 Defender 90
I love it!!!
Wish I had the $25k.
Russ
'94 AA Yellow
# 891
Old August 5th, 2011, 09:37 AM
grnthng's Avatar
grnthng
Luis A. Costa
'93 Range Rover County LWB
These 4bt's are everywhere, plenty available... you'll have to degrease them though or pay alittle more for a rebilt and freshly painted unit! If you know anyone at FedEx, they are in their breadvans! Find out their source and you'll find a shitload of them!
Old August 5th, 2011, 10:56 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
4btswaps.com is a good site to check out if you're at all interested in the Cummins 4bt. Lots of good tech info also links to sources for finding the motors. Quite a few folks have purchsed old frito lay vans from "DoveBid" ( go-dove.com) with the 4BT motor and sold the rest of the truck for scrap.
Old August 8th, 2011, 02:52 PM
gallf1
Felix
*** SOLD ***
August 8,2011
Old August 8th, 2011, 03:11 PM
redrockrover
Russell Phillips
1994 Defender 90
Glad you were able to sell it but I hate to see it go. Please tell us it went to someone on the list and they will put it to good use.
Russ
'94 AA Yellow
# 891
Old June 30th, 2015, 09:02 AM
Way of Life's Avatar
Way of Life
1988 Defender D110
What was the noise line inside the truck.
I'm looking at using that engine in my Rebuild for the D-130 lengthen frame for a longer D110 box. Looked good I'm on the Cummins 4BT & Diesel Conversions Forums.
What was the power like at 65 mph?
Thanks for your time,
Cheers,
randy
Old June 30th, 2015, 09:16 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
When it was back up for sale a few months later:
Cummins Power: 1971 Land Rover Series IIA 109 | Bring a Trailer
http://www.defendersource.com/forum/...eferrerid=7814
Video from the driver's perspective: https://vimeo.com/54712783
Old June 30th, 2015, 09:51 AM
whitelandy33
Pecos
hyundai
I remember this one. Didn't the transmission go bad on the trip home?
Old June 30th, 2015, 02:19 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
You sound like me. I'd be skeptical that there is all that much there. The current LRO Magazine teased a Cummins swap feature coming in next month's issue. And there's a small shop in Sisters, Oregon who supposedly has done some LR 4bt swaps for customers. He shot down my inquiry re a minimal lift 6bt Defender swap, of course. <sigh>
Old June 30th, 2015, 02:40 PM
cowboy
steven
Yes, he's famous: 14 Companies That Specialize In Diesel Conversions
Old June 30th, 2015, 03:10 PM
oilburner's Avatar
oilburner
JL
large pile of parts
There are now dozens of 6BT conversions in the UK, and videos and pics all over the net. Some are pretty crude but they definitely seem to be able to get the engines in with low lifts.
JL
Old July 1st, 2015, 08:11 AM
Way of Life
1988 Defender D110
Thanks for the links, Down_Shift or he links I didn't come across then ones.
I'm just no wanting to use good money for a shit set up.
I'm not sure which way to go 4bt or the 6bt, I will keep looking and reading and bugging people with more brain power than me. It does sound nice better than the 2.4 puma.
Old July 1st, 2015, 02:42 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Does anyone know how the "military selector" switch for dual fuel tanks work on a diesel? (Original post for this truck mentioned it had the switch.)
Does it somehow keep the line for the tank not in use pressurized so you don't have to bleed the pump when you switch over?
Or is the supply in the bottom of the tank? In that case wouldn't you still get a little air when you switched?
I am looking at options for dual tanks in my 300tdi 90. Currently leaning towards matching under seat tanks with t's in the feed and return so it draws simultaneously off both tanks at the same rate. Might have to use fuel cells to try and keep the level close to the same on both sides when leaning off road. Or just never let it drop bellow half full I guess.
Old July 1st, 2015, 07:06 PM
BigWalker's Avatar
BigWalker
Pete Ricci
1965 Series 109 V8 Automatic
I would stay with the 4BT, about 400 lbs lighter, the 4bt can produce very good power with out a lot of work and if your right foot has a brain not tear up most of your drive train. Suggest a Pump version if you really want to play with more power. Turbos and pump work, Keep the boost down and you won't need to do much of anything to then engine it self, stock they can handle a lot. They are noisy and vibrate quite a bit at the low RPM's but you can improve that a bunch with careful installation, a fluid damper and tuning. Remember anything Cummins = $$$. Rebuilding one is not cheap
I have been working on my 72 FJ40 cummins for over two years but my Endurance horses and wifes 109 keep getting in the way,
Old July 9th, 2015, 10:32 AM
Neon fx
Jeff
Are you interested in any trades my daughter is turning 16 in 2 weeks be a great first car
Old July 9th, 2015, 11:44 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Not sure about the great first car thing, but cool first car yeah.
109, door
109 5 door "T" pieces slorocco Wanted 0 September 23rd, 2009 09:01 AM
1967 SIIA 109 5 door leafsprung For Sale - Vehicles 0 December 30th, 2008 07:43 PM
Sprung-over 109 Cummins Diesel Project Relk For Sale - Vehicles 2 February 26th, 2008 03:36 PM
Gaguing Interest: Immaculate 109 Wagon with Vortec V6 or a Cummins 4BT diesel dieselcruiserhead For Sale - Vehicles 6 October 29th, 2006 12:32 AM
67 Series IIA 109 5 Door C-Delta For Sale - Vehicles 1 August 10th, 2006 02:40 AM
