Arles Blue NAS '95 SW Up For Grabs... - Defender Source
Old November 26th, 2011, 05:06 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
All parts are new and genuine unless otherwise stated. Replaced in the last 7K: transmission(R380), clutch kit, master cylinder and slave, transfer box(1.4w/Maxi-drive 50% low crawler gears), front/rear differentials w/ truetracs(new bearings and flange), GBR double-cardon driveshafts front/rear, GBR axles front/rear(last of the Maxi-drive stuff), HD steering links w/ serviceable ends, custom rear links, RTE adjustable pan-hard rod, entire suspension rebushed, A-arm ball joint, brakes(pads,rotors,master cylinder), wheel bearings/seals, D130 rims w/ 285/75/16 SSR's(x5), custom front bumper w/Warn 8274w/Viking synthetic line, Safari Gard sliders, custom rear bumper w/ spare tire and jerry can holder, Brownchurch roof rack/ladder, alloy gas tank skid plate, SS extended brake lines, RTE 2in suspension/steering stabalizer, RTE spring retainers, genuine waterproof seat cover, genuine rubber floor mats,seat risers, Mammoth hood plate, genuine snow cowl, military spare tire hood mount(in box), ENGINE: new bearings through-out w/rebuilt heads, total reseal of entire engine, shortened trumpets, timing chain/gears, custom grind cam/lifters(little more top end), water pump, radiator, hoses, belts, pulley bearings, PAS pump/lines,distributor/coil/amplifier, full service(fluids, filters, plugs, K&N air filter, Magnacore wires, all sensors, headlight wiring harness upgrade, injectors, fuel pump/relays, zero rust on frame/outriggers/cross members/bulkhead, slight rust on bottom of front door frames, 3 of the rear jump seats have been removed for storage bins, all kind of extra parts are included(belts,hoses,relays,ect), and last but not least a new "hotrod" 4.0 V8 on an engine stand ready to go in whatever you want(ported heads,double roller chain/gears, custom ground cam/lifters, serpentine set-up, timing cover, h2o pump, ac compressor, brackets, belt,fan. Everything you would need to drop in a distributor driven serpentine engine into an old v-belt set-up Rover. The rest of the Rover has 114,xxx on it. $40k obo, I can't remember everything I've done to this Rover over the last 2yrs so feel free to ask. I built it for my Daily-Driver. I can't count the hours I have in this rig and I'm not even trying to get what I have invested in it. It needs nothing except a good new home and some new speakers...starting to get fuzzy.Thanks for look'n!
Old November 26th, 2011, 05:13 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Sorry...I'll get some interior pic's tomorrow.
ID:	44105   Click image for larger version
ID:	44107   Click image for larger version
ID:	44109   Click image for larger version
ID:	44111   Click image for larger version
ID:	44113   Click image for larger version
Old November 26th, 2011, 05:18 PM
Wow nice looking rig Jake!
Old November 26th, 2011, 05:20 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Say it isn't so, Jake!
I still need you and the Mrs. to come and visit VA Beach in the spring when I get back from the desert. Then you can help me put the 4.6 serp setup in my 94. Any plans for a replacement?
Good luck with the sale, Jake, and for anyone considering his cool truck, I cannot recommend Jake's work or work ethic any more highly.
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old November 26th, 2011, 05:21 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
It also has NRP stainless exhaust and new cats.
ID:	44115   Click image for larger version
ID:	44117   Click image for larger version
ID:	44119   Click image for larger version
ID:	44121   Click image for larger version
Old November 26th, 2011, 05:23 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Thanks for the kind words Murphy! We will come see you as soon as things slow down abit. Happy holidays!
------ Follow up post added November 26th, 2011 07:35 PM ------
I just remembered that I haven't changed my location status...we are in San Clemente,CA now if that makes it easier for anyone interested.
Old November 26th, 2011, 06:39 PM
asking 40 for that makes me feel better about mine less bumpers and driveline.
Old November 26th, 2011, 06:59 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Just cause I'm asking $40k doesn't mean I'm gonna get it. It'a good starting point with all that is involved.
Old November 26th, 2011, 11:22 PM
achampagne's Avatar
achampagne
Adrian Champagne
06 LR3 HSE
Very nice truck man...
Old November 26th, 2011, 11:28 PM
What rear bumper is that?
Old November 27th, 2011, 12:02 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
It's mine...same as the front one. There was nothing on the market that looked write to me so I made one. I know how to use a "Hotglue" gun pretty well. Jason...if you buy my 90 I'll build you one for your 110 since i know you need another Rover in your stables.
Old November 27th, 2011, 02:16 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Here's some interior shots.
ID:	44147   Click image for larger version
ID:	44149   Click image for larger version
ID:	44151   Click image for larger version
ID:	44153   Click image for larger version
Old November 27th, 2011, 02:20 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
And a few more....! I tried to keep the interior simple but clean.
ID:	44155   Click image for larger version
ID:	44157   Click image for larger version
ID:	44159   Click image for larger version
ID:	44161   Click image for larger version
ID:	44163   Click image for larger version
Old November 27th, 2011, 02:30 PM
bjf's Avatar
bjf
barry f
94 ST #395
Really a sick truck. Great bumper. Usually the ones for that style winch aren't great lookin but you did a great job. Goo luck with the sale. Too bad it isn't conniston. It would be worth a ton.
Old November 27th, 2011, 02:33 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Come on Barry...I know you like blue and I think you need a SW to match your ST don't you?
Old November 27th, 2011, 02:43 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
I think it's worth it just for the Steal Your Face sticker on the back window!
Old November 27th, 2011, 03:00 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
It's actually one of the old metal ones. It's gonna hurt to let it go with that on there.
Old November 27th, 2011, 03:40 PM
n_maher's Avatar
n_maher
Nate
None (68 IIA long gone)
Quite literally my dream truck, best of luck with the sale.
Old November 27th, 2011, 09:04 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Your dream can come true...! The blue SW's have always been my favorite too.
Old November 28th, 2011, 09:57 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Start throw'n more offers so I have a reason to lower the price and keep the extra hotrod motor. Thanks!
95, arles blue, nas
1997 Arles Blue SW Raleigh D90 Wanted 7 February 16th, 2010 10:23 AM
1994 Arles Blue Campbell For Sale - Vehicles 6 October 17th, 2005 08:30 AM
Seeking Arles Blue, Yellow, Green, Red ST under $23k treydub Wanted 4 September 10th, 2005 08:02 AM
Repainting 95 AA Yellow to Arles Blue Helihntr Defender Technical Discussions 36 May 4th, 2005 02:01 AM
97 D90 SW Arles Blue For Sale timcd90 For Sale - Vehicles 12 February 20th, 2005 05:24 PM
