97 D90 NAS Any comments appreciated - Page 2 - Defender Source
Old December 28th, 2013, 10:50 AM
Don't get emotionally attached until you drive it home...
Most I would pay is in the low 40's... Bring a member with you to look at it, there are plenty in your area.
Old December 28th, 2013, 02:15 PM
aquatiger's Avatar
aquatiger
S
none
So I sent some of you PMs. But then I did a search on the guy selling this Defender and found him here. He seems to check out based on the community here on this board. It sounds like he is legit, has been to local roundup events, and does some vetting for other cars for sale.
I still think his price is high. But I will keep you guys posted. I really can't say enough about how much I appreciate your input. Regardless, I think if the price is right I'll be driving a Defender. If it's not this one, then I'll keep looking.
Thanks again guys
Old December 28th, 2013, 02:54 PM
Welcome to the addition...
Old December 28th, 2013, 04:20 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Originally Posted by Jymmiejamz View Post
That's a Land Rover part. The old style clothe ones deteriorate, so they came out with a rubber version that is much better.
Interesting... I may be in need of one of these. Do you happen to have the Genuine LR part#? I couldn't find anything on this. Thanks in advance.
Old December 28th, 2013, 05:32 PM
I think there is a Land Rover Technical Bulletin on it and it gives the part numbers for the hose, two clamps, and a zip tie IIRC. I'll check the parts catalogue when I'm back at work, but I'm on vacation for the next two weeks and won't be back at work until the 13th.
Old December 28th, 2013, 07:29 PM
ESR1316
Looks like it's made of unobtanium ... Probably any flexible hose that has re-enforcement so it doesn't collapse under intake vacuum would be fine.
Old December 28th, 2013, 09:55 PM
ESR1316
I've ordered one and I know one of my coworkers has ordered at least two through the dealership. They had them in stock in the NJ warehouse. They may be NLA, but this was less than a year ago.
Old December 29th, 2013, 08:35 AM
It's still expensive for a flexi hose ... What we need is a bling silicone version!
Old December 29th, 2013, 09:33 AM
It definitely wasn't that expensive. I think I paid around $100. It is overpriced for what it is, but you'll likely never need to replace it again. Also, I'm pretty sure that the air box and plenum have different sized holes, so you can't use a generic piece of hose without adapters.
Old December 29th, 2013, 09:53 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
The PO of my truck went this route after the steering shaft knuckle cut through the original hose. The resulting air leak didn't manifest itself until north of 3000 rpms. Just about every part on the ignition and fuel systems were replaced in an attempt to troubleshoot. It's documented here on forum.
Old December 29th, 2013, 10:25 AM
Let's be honest. For the price of this truck I should have a perfect plenum hose ...
Old January 9th, 2014, 02:28 PM
aquatiger's Avatar
aquatiger
S
none
Just wanted to update you guys on this truck. I took someone to look at it, and they said the rear main seal was "wet". So he advised against it. It was a great looking truck though.
Anyway, still searching...
Thanks for all the input guys.
Old January 9th, 2014, 03:25 PM
87 D110 (Ruby)
good luck finding a "non-wet" Land Rover
Old January 9th, 2014, 03:33 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Kinda what I was thinking. Good luck with that.
Old January 9th, 2014, 03:35 PM
jafir's Avatar
jafir
Jafir Elkurd
Had this someone seen a British car before? They all leak from somewhere. If it was just wet, and not marking the pavement, it's a good one. ;-)
Old January 9th, 2014, 03:37 PM
101stAirborne's Avatar
101stAirborne
Battle Ewing
1997 D90 LE 255/300
They all drip at some point. I wouldn't let that deter you. Let the price deter you
Old January 9th, 2014, 03:45 PM
Amen to that. When they stop dripping they need to be refilled.
90, 97, 97 d90, d90, nas
97 NAS D90SW - FOR SALE! (Giant post & lots of photos) HeloBubba For Sale - Vehicles 61 January 12th, 2014 07:36 PM
1997 NAS D90 soft top Beluga Black 86K hlamar For Sale - Vehicles 30 July 24th, 2013 11:11 AM
97 D90 NAS Soft Top Available davidr For Sale - Parts 0 January 30th, 2009 02:53 PM
'95 NAS D90: Ready for the Rubicon or rush hour... KG6BGJ For Sale - Vehicles 0 September 17th, 2005 08:23 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
